[fusion-commits] r2566 - in branches/fusion-mg24: . layers/MapGuide lib widgets widgets/QuickPlot
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Aug 6 08:05:26 PDT 2012
Author: jng
Date: 2012-08-06 08:05:25 -0700 (Mon, 06 Aug 2012)
New Revision: 2566
   branches/fusion-mg24/
   branches/fusion-mg24/layers/MapGuide/MapGuide.js
   branches/fusion-mg24/lib/ApplicationDefinition.js
   branches/fusion-mg24/lib/MGBroker.js
   branches/fusion-mg24/lib/MapMessage.js
   branches/fusion-mg24/widgets/BasemapSwitcher.js
   branches/fusion-mg24/widgets/QuickPlot/GeneratePicture.php
   branches/fusion-mg24/widgets/QuickPlot/PreviewDialog.js
#530: Eliminate the use of Xml2JSON.php for QUERYMAPFEATURES (the only operation that calls it). This results in one less request for every selection operation and tooltip request. This requires revision 6935 or newer of MapGuide trunk or 2.4 branch, which supports JSON output for QUERYMAPFEATURES (see: http://trac.osgeo.org/mapguide/ticket/2090).
Property changes on: branches/fusion-mg24
___________________________________________________________________
Modified: svn:mergeinfo
   - /sandbox/jxlib-3.0:1957-2248
   + /sandbox/jxlib-3.0:1957-2248
/trunk:2565
Modified: branches/fusion-mg24/layers/MapGuide/MapGuide.js
--- branches/fusion-mg24/layers/MapGuide/MapGuide.js	2012-08-06 14:27:49 UTC (rev 2565)
+++ branches/fusion-mg24/layers/MapGuide/MapGuide.js	2012-08-06 15:05:25 UTC (rev 2566)
@@ -1136,7 +1136,7 @@
        options.layers,
        layerAttributeFilter);
         var callback = (options.extendSelection == true) ? OpenLayers.Function.bind(this.processAndMergeFeatureInfo, this) : OpenLayers.Function.bind(this.processFeatureInfo, this);
-        Fusion.oBroker.dispatchRequest(r, OpenLayers.Function.bind(Fusion.xml2json, this, callback));
+        Fusion.oBroker.dispatchRequest(r, callback);
     showLayer: function( layer, noDraw ) {
@@ -1226,7 +1226,7 @@
                                                             maxFeatures, persist, selection, filter, layerNames,
         var callback = OpenLayers.Function.bind(this.crtlClickDisplay, this);
@@ -1346,9 +1346,7 @@
                                         sGeometry,
-        oBroker.dispatchRequest(r,
-            OpenLayers.Function.bind(Fusion.xml2json, this,
-                  OpenLayers.Function.bind(this.parseMapTip, this)));
+        oBroker.dispatchRequest(r, OpenLayers.Function.bind(this.parseMapTip, this));
     parseMapTip: function(xhr) {
Property changes on: branches/fusion-mg24/lib/ApplicationDefinition.js
   - /sandbox/adsk/2.4j/lib/ApplicationDefinition.js:2486-2514
/sandbox/jxlib-3.0/lib/ApplicationDefinition.js:1957-2248
/trunk/lib/ApplicationDefinition.js:2469-2485
   + /sandbox/adsk/2.4j/lib/ApplicationDefinition.js:2486-2514
/trunk/lib/ApplicationDefinition.js:2469-2485,2565
Modified: branches/fusion-mg24/lib/MGBroker.js
--- branches/fusion-mg24/lib/MGBroker.js	2012-08-06 14:27:49 UTC (rev 2565)
+++ branches/fusion-mg24/lib/MGBroker.js	2012-08-06 15:05:25 UTC (rev 2566)
@@ -579,6 +579,7 @@
         this.initializeRequest();
         this.setParams( {
             operation : 'QUERYMAPFEATURES',
+            format: "application/json",
             session: sessionId,
             mapname: mapName,
             geometry: geometry,
Property changes on: branches/fusion-mg24/lib/MapMessage.js
   - /sandbox/adsk/2.4j/lib/MapMessage.js:2486-2514
/sandbox/jxlib-3.0/lib/MapMessage.js:1957-2248
/trunk/lib/MapMessage.js:2469-2485
   + /sandbox/adsk/2.4j/lib/MapMessage.js:2486-2514
/trunk/lib/MapMessage.js:2469-2485,2565
Property changes on: branches/fusion-mg24/widgets/BasemapSwitcher.js
   - /sandbox/adsk/2.4j/widgets/BasemapSwitcher.js:2486-2526
/sandbox/jxlib-3.0/widgets/BasemapSwitcher.js:1957-2248
/trunk/widgets/BasemapSwitcher.js:2469-2485
   + /sandbox/adsk/2.4j/widgets/BasemapSwitcher.js:2486-2526
/trunk/widgets/BasemapSwitcher.js:2469-2485,2565
Property changes on: branches/fusion-mg24/widgets/QuickPlot/GeneratePicture.php
   - /sandbox/adsk/2.4jbeta2/widgets/QuickPlot/GeneratePicture.php:2488-2498
/sandbox/jxlib-3.0/widgets/QuickPlot/GeneratePicture.php:1957-2248
/trunk/widgets/QuickPlot/GeneratePicture.php:2469-2487
   + /sandbox/adsk/2.4jbeta2/widgets/QuickPlot/GeneratePicture.php:2488-2498
/trunk/widgets/QuickPlot/GeneratePicture.php:2469-2487,2565
Property changes on: branches/fusion-mg24/widgets/QuickPlot/PreviewDialog.js
   - /sandbox/adsk/2.4j/widgets/QuickPlot/PreviewDialog.js:2486-2528
/sandbox/jxlib-3.0/widgets/QuickPlot/PreviewDialog.js:1957-2248
/trunk/widgets/QuickPlot/PreviewDialog.js:2469-2485
   + /sandbox/adsk/2.4j/widgets/QuickPlot/PreviewDialog.js:2486-2528
/trunk/widgets/QuickPlot/PreviewDialog.js:2469-2485,2565
More information about the fusion-commits mailing list
