[fusion-commits] r2625 - sandbox/adsk/2.3r/layers/MapGuide/php
svn_fusion at osgeo.org
Wed Dec 12 00:21:41 PST 2012
Author: liuar
Date: 2012-12-12 00:21:40 -0800 (Wed, 12 Dec 2012)
New Revision: 2625
sandbox/adsk/2.3r/layers/MapGuide/php/Constants.php
sandbox/adsk/2.3r/layers/MapGuide/php/GetSelectionProperties.php
sandbox/adsk/2.3r/layers/MapGuide/php/Utilities.php
Use API MgSelectionBase::GenerateFilters instead of MgSelectionBase::GenerateFilter to avoid the filter text exceed the SQL length limit.
Modified: sandbox/adsk/2.3r/layers/MapGuide/php/Constants.php
--- sandbox/adsk/2.3r/layers/MapGuide/php/Constants.php 2012-11-06 09:40:50 UTC (rev 2624)
+++ sandbox/adsk/2.3r/layers/MapGuide/php/Constants.php 2012-12-12 08:21:40 UTC (rev 2625)
@@ -1871,4 +1871,13 @@
+/// <summary>
+/// The batch size to use when rendering a selection.
+/// </summary>
+class MgSelectionBatchSize
+ const RenderSelectionBatchSize = 30000 ;
\ No newline at end of file
Modified: sandbox/adsk/2.3r/layers/MapGuide/php/GetSelectionProperties.php
--- sandbox/adsk/2.3r/layers/MapGuide/php/GetSelectionProperties.php 2012-11-06 09:40:50 UTC (rev 2624)
+++ sandbox/adsk/2.3r/layers/MapGuide/php/GetSelectionProperties.php 2012-12-12 08:21:40 UTC (rev 2625)
@@ -60,6 +60,7 @@
/*holds selection array*/
$properties = NULL;
$properties->layers = array();
+ $properties->envelope = NULL;
//process
header('Content-type: application/json');
@@ -93,53 +94,60 @@
$geomName = $oLayer->GetFeatureGeometryName();
$queryOptions->AddFeatureProperty($geomName);
- $filter = $selection->GenerateFilter($oLayer, $class);
- $queryOptions->SetFilter($filter);
- $featureReader = $featureService->SelectFeatures($featureResId, $class, $queryOptions);
+ $filters = $selection->GenerateFilters($oLayer, $class, MgSelectionBatchSize::RenderSelectionBatchSize);
+ $featureReaders = NULL;
+ $featureReaders = array();
+ for ($j = 0; $j < $filters->GetCount(); $j++) {
+ $queryOptions->SetFilter($filters->GetItem($j));
+ $featureReader = $featureService->SelectFeatures($featureResId, $class, $queryOptions);
+ array_push($featureReaders, $featureReader);
//$featureReader = $selection->GetSelectedFeatures($oLayer, $class, true );//this doesn't seem to work but would replace much of the above code
$layerName = $oLayer->GetName();
array_push($properties->layers, $layerName);
- // TODO: Check if computed properties are needed?
+ // TODO: Check if computed properties are needed?
$bComputedProperties = false;
$bNeedsTransform = false;
$srsLayer = NULL;
if ($bComputedProperties)
- $spatialContext = $featureService->GetSpatialContexts($featureResId, true);
- $srsLayerWkt = false;
- if($spatialContext != null && $spatialContext->ReadNext() != null) {
- $srsLayerWkt = $spatialContext->GetCoordinateSystemWkt();
- /* skip this layer if the srs is empty */
- if ($srsLayerWkt == null) {
- $srsLayerWkt = $srsDefMap;
- /* create a coordinate system from the layer's SRS wkt */
- $srsLayer = $srsFactory->Create($srsLayerWkt);
+ $spatialContext = $featureService->GetSpatialContexts($featureResId, true);
+ $srsLayerWkt = false;
+ if($spatialContext != null && $spatialContext->ReadNext() != null) {
+ $srsLayerWkt = $spatialContext->GetCoordinateSystemWkt();
+ /* skip this layer if the srs is empty */
+ if ($srsLayerWkt == null) {
+ $srsLayerWkt = $srsDefMap;
+ /* create a coordinate system from the layer's SRS wkt */
+ $srsLayer = $srsFactory->Create($srsLayerWkt);
- // exclude layer if:
- // the map is non-arbitrary and the layer is arbitrary or vice-versa
- // or
- // layer and map are both arbitrary but have different units
- $bLayerSrsIsArbitrary = ($srsLayer->GetType() == MgCoordinateSystemType::Arbitrary);
- $bMapSrsIsArbitrary = ($srsMap->GetType() == MgCoordinateSystemType::Arbitrary);
- if (($bLayerSrsIsArbitrary != $bMapSrsIsArbitrary) ||
- ($bLayerSrsIsArbitrary && ($srsLayer->GetUnits() != $srsMap->GetUnits()))) {
- $bComputedProperties = false;
- } else {
- $srsTarget = null;
- $srsXform = null;
- $bNeedsTransform = ($srsLayer->GetUnitScale() != 1.0);
+ // exclude layer if:
+ // the map is non-arbitrary and the layer is arbitrary or vice-versa
+ // or
+ // layer and map are both arbitrary but have different units
+ $bLayerSrsIsArbitrary = ($srsLayer->GetType() == MgCoordinateSystemType::Arbitrary);
+ $bMapSrsIsArbitrary = ($srsMap->GetType() == MgCoordinateSystemType::Arbitrary);
+ if (($bLayerSrsIsArbitrary != $bMapSrsIsArbitrary) ||
+ ($bLayerSrsIsArbitrary && ($srsLayer->GetUnits() != $srsMap->GetUnits()))) {
+ $bComputedProperties = false;
+ } else {
+ $srsTarget = null;
+ $srsXform = null;
+ $bNeedsTransform = ($srsLayer->GetUnitScale() != 1.0);
- $properties = BuildSelectionArray($featureReader, $layerName, $properties,
+ $properties = BuildSelectionArrayEx($featureReaders, $layerName, $properties,
$bComputedProperties,
- $srsLayer, $bNeedsTransform, $oLayer);
- $featureReader->Close();
+ $srsLayer, $bNeedsTransform, $oLayer);
+ foreach ($featureReaders as $featureReader) {
+ $featureReader->Close();
$result = NULL;
@@ -147,7 +155,7 @@
if ($layers && $layers->GetCount() >= 0)
$result->hasSelection = true;
- $oExtents = $selection->GetExtents($featureService);
+ $oExtents = $properties->envelope;
if ($oExtents)
$oMin = $oExtents->GetLowerLeftCoordinate();
Modified: sandbox/adsk/2.3r/layers/MapGuide/php/Utilities.php
--- sandbox/adsk/2.3r/layers/MapGuide/php/Utilities.php 2012-11-06 09:40:50 UTC (rev 2624)
+++ sandbox/adsk/2.3r/layers/MapGuide/php/Utilities.php 2012-12-12 08:21:40 UTC (rev 2625)
@@ -873,6 +873,147 @@
return $properties;
+ keep all the attributes of selected features in an array
+function BuildSelectionArrayEx($featureReaders, $layerName, $properties, $bComputedProperties,
+ $srsLayer, $bNeedsTransform, $layerObj)
+ if (count($featureReaders) == 0)
+ return $properties;
+ $agf = new MgAgfReaderWriter();
+ $srsFactory = new MgCoordinateSystemFactory();
+ $properties->$layerName->propertynames = array();
+ $properties->$layerName->propertyvalues = array();
+ $properties->$layerName->propertytypes = array();
+ $properties->$layerName->numelements = 0;
+ $properties->$layerName->values = array();
+ $properties->$layerName->metadatanames= array();
+ array_push($properties->$layerName->metadatanames, 'dimension');
+ array_push($properties->$layerName->metadatanames, 'bbox');
+ array_push($properties->$layerName->metadatanames, 'center');
+ array_push($properties->$layerName->metadatanames, 'area');
+ array_push($properties->$layerName->metadatanames, 'length');
+ $featureReader = $featureReaders[0];
+ $mappings = $_SESSION['property_mappings'][$layerObj->GetObjectId()];
+ foreach((array)$mappings as $name => $value)
+ $propType = $featureReader->GetPropertyType($name);
+ array_push($properties->$layerName->propertynames, $name);
+ array_push($properties->$layerName->propertyvalues, $value);
+ array_push($properties->$layerName->propertytypes, $propType);
+ $srsXform = null;
+ //$envelope = new MgEnvelope();
+ while ($featureReader->ReadNext())
+ $properties->$layerName->values[$properties->$layerName->numelements] = array();
+ $properties->$layerName->metadata[$properties->$layerName->numelements] = array();
+ $dimension = '';
+ $bbox = '';
+ $center = '';
+ $area = '';
+ $length = '';
+ if ($bComputedProperties)
+ $classDef = $featureReader->GetClassDefinition();
+ $geomName = $classDef->GetDefaultGeometryPropertyName();
+ if ($geomName != '') {
+ $geomByteReader = $featureReader->GetGeometry($geomName);
+ /* is this needed? We declare one outside the loop too?*/
+ $geom = $agf->Read($geomByteReader);
+ $envelope = $geom->Envelope();
+ $ll = $envelope->GetLowerLeftCoordinate();
+ $ur = $envelope->GetUpperRightCoordinate();
+ $bbox = $ll->GetX().','.$ll->GetY().','.$ur->GetX().','.$ur->GetY();
+ $centroid = $geom->GetCentroid()->GetCoordinate();
+ $center = $centroid->GetX().','.$centroid->GetY();
+ /* 0 = point, 1 = curve, 2 = surface */
+ $dimension = $geom->GetDimension();
+ if ($geom->GetDimension() > 0) {
+ //conver the geometry to UTM auto so that local measurements
+ //are accruate in meters
+ if ($bNeedsTransform && $srsTarget == null && $srsXform == null) {
+ $wkt = getUtmWkt($centroid->GetX(),
+ $centroid->GetY());
+ $srsTarget = $srsFactory->Create($wkt);
+ $verMajor = subStr(GetSiteVersion(), 0,1);
+ if ($verMajor == '1') {
+ $srsXform = new MgCoordinateSystemTransform($srsLayer, $srsTarget);
+ } else {
+ $srsXform = $srsFactory->GetTransform($srsLayer, $srsTarget);
+ if ($srsXform != null) {
+ try {
+ $ageom = $geom->Transform($srsXform);
+ $geom = $ageom;
+ } catch (MgException $ee) {
+ echo "/*transform exception:";
+ echo "ERROR: " . $ee->GetExceptionMessage() . "\n";
+ echo $ee->GetDetails() . "\n*/";
+ if ($geom->GetDimension() > 1) {
+ $area = $geom->GetArea();
+ $length = $geom->GetLength();
+ array_push($properties->$layerName->metadata[$properties->$layerName->numelements], $dimension);
+ array_push($properties->$layerName->metadata[$properties->$layerName->numelements], $bbox);
+ array_push($properties->$layerName->metadata[$properties->$layerName->numelements], $center);
+ array_push($properties->$layerName->metadata[$properties->$layerName->numelements], $area);
+ array_push($properties->$layerName->metadata[$properties->$layerName->numelements], $length);
+ $numproperties = count($properties->$layerName->propertynames);
+ for($j=0; $j<$numproperties; $j++) {
+ $propname = $properties->$layerName->propertynames[$j];
+ $propType = $properties->$layerName->propertytypes[$j];
+ if ($propname == '')
+ continue;
+ if ($propType == MgPropertyType::Geometry) {
+ $geomEnv = $geom->Envelope();
+ $properties->envolope->ExpandToInclude($geomEnv);
+ else {
+ $value = GetPropertyValueFromFeatReader($featureReader,
+ $properties->$layerName->propertytypes[$j],
+ $propname);
+ $value = htmlentities($value, ENT_COMPAT, 'UTF-8');
+ $value = addslashes($value);
+ $value = preg_replace( "/\r?\n/", "<br>", $value );
+ array_push($properties->$layerName->values[$properties->$layerName->numelements], $value);
+ //$properties->$layerName->values[$properties->$layerName->numelements][$propname] = $value;
+ $properties->$layerName->numelements= $properties->$layerName->numelements+1;
function getUtmWkt($lon, $lat) {
$siteVersion = explode(".",GetSiteVersion());
if ((integer)$siteVersion[0] > 2 || (integer)$siteVersion[0] == 2 && (integer)$siteVersion[1] > 0) { //v2.1.x or greater
More information about the fusion-commits
