[fusion-commits] r2507 - in trunk:
templates/mapguide/standard/images/icons widgets
svn_fusion at osgeo.org
Wed Jan 4 02:30:36 EST 2012
Author: jng
Date: 2012-01-03 23:30:36 -0800 (Tue, 03 Jan 2012)
New Revision: 2507
Added:
trunk/templates/mapguide/standard/images/icons/out-of-range.png
trunk/widgets/Legend.js
#510: Fix HideInvisibleLayers extension property not working when set to false. The problems were:
- The tree item replace() function had the parameters in the wrong order.
- No icon is passed to tree items representing layers outside the current scale.
Added: trunk/templates/mapguide/standard/images/icons/out-of-range.png
(Binary files differ)
Property changes on: trunk/templates/mapguide/standard/images/icons/out-of-range.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js 2012-01-04 06:09:23 UTC (rev 2506)
+++ trunk/widgets/Legend.js 2012-01-04 07:30:36 UTC (rev 2507)
@@ -74,6 +74,12 @@
defaultGroupInfoIcon: 'images/icons/group-info.png',
+ * Constant: outOfRangeIcon
+ * {String}: The default image for layers outside the current visible scale range
+ outOfRangeIcon: 'images/icons/out-of-range.png',
initializeWidget: function(widgetTag) {
// TODO: maybe it's a good idea to do a function like Fusion.Widget.BindRenderer.. for limit the code
// duplication if we plan to apply this pattern to others widgets
@@ -636,9 +642,9 @@
layer.legend.treeItem = null;
} else {
- var newTreeItem = this.createTreeItem(layer, {legendLabel: layer.legendLabel}, null, !layer.isBaseMapLayer);
+ var newTreeItem = this.createTreeItem(layer, {legendLabel: layer.legendLabel, iconOpt: { url: this.oLegend.outOfRangeIcon } }, null, !layer.isBaseMapLayer);
if (layer.legend.treeItem) {
- layer.parentGroup.legend.treeItem.replace(newTreeItem, layer.legend.treeItem);
+ layer.parentGroup.legend.treeItem.replace(layer.legend.treeItem, newTreeItem);
layer.legend.treeItem.finalize();
} else {
layer.parentGroup.legend.treeItem.add(newTreeItem);
More information about the fusion-commits
