[fusion-commits] r2518 - trunk/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Jan 17 04:29:49 EST 2012
Author: jng
Date: 2012-01-17 01:29:49 -0800 (Tue, 17 Jan 2012)
New Revision: 2518
   trunk/lib/Widget.js
Submitted on behalf of Bruce Li (libr). Fix tickets #505, #512 and #513
Modified: trunk/lib/Widget.js
--- trunk/lib/Widget.js	2012-01-13 05:44:58 UTC (rev 2517)
+++ trunk/lib/Widget.js	2012-01-17 09:29:49 UTC (rev 2518)
@@ -119,11 +119,9 @@
         if (uiObj.addEvents) {
             if (Fusion.Widget.uiInstances[this.type][0].uiObj &&
                 Fusion.Widget.uiInstances[this.type][0].uiObj.options.active &&
-                Fusion.Widget.uiInstances[this.type][0].shouldActivateWith(this)) {
-                uiObj.options.active = true;
-                if (uiObj.domA) {
-                    uiObj.domA.addClass('jx' + uiObj.options.type + 'Active');
+                Fusion.Widget.uiInstances[this.type][0].shouldActivateWith(this) &&
+                uiObj.setActive) {
+                uiObj.setActive(true);
             uiObj.addEvents({
@@ -134,11 +132,9 @@
                     var instances = Fusion.Widget.uiInstances[this.type];
                     for (var i=0; i<instances.length; i++) {
                         var instance = instances[i];
-                        if (instance.shouldActivateWith(this) && instance.uiObj) {
-                            instance.uiObj.options.active = false;
-                            if (instance.uiObj.domA) {
-                                instance.uiObj.domA.removeClass('jx' + instance.uiObj.options.type + 'Active');
+                        if (instance.shouldActivateWith(this) &&
+                            instance.uiObj && instance.uiObj.setActive) {
+                            instance.uiObj.setActive(false);
                     this.deactivate();
@@ -147,11 +143,9 @@
-                            instance.uiObj.options.active = true;
-                                instance.uiObj.domA.addClass('jx' + instance.uiObj.options.type + 'Active');
+                            instance.uiObj.setActive(true);
                     this.activate();
@@ -164,7 +158,7 @@
     shouldActivateWith: function(widget) {
-        return true;
+        return false;
More information about the fusion-commits mailing list
