[fusion-commits] r2544 - in trunk: . lib lib/OpenLayers
svn_fusion at osgeo.org
Sat Jul 7 05:08:15 PDT 2012
Author: jng
Date: 2012-07-07 05:08:15 -0700 (Sat, 07 Jul 2012)
New Revision: 2544
Added:
trunk/lib/OpenLayers/OpenLayersGMapsPatch.js
trunk/build.xml
trunk/lib/fusion.js
#529: Patch our internal copy of OpenLayers to remove the "Map Data" popup on every move in a TOS-compliant manner (source: http://trac.osgeo.org/openlayers/wiki/Release/2.11/GoogleMaps37)
Modified: trunk/build.xml
--- trunk/build.xml 2012-07-07 11:51:06 UTC (rev 2543)
+++ trunk/build.xml 2012-07-07 12:08:15 UTC (rev 2544)
@@ -214,6 +214,7 @@
fusion.js
Proj4js/proj4js-compressed.js
OpenLayers/OpenLayers.js
+ OpenLayers/OpenLayersGMapsPatch.js
OLpatch.js
jxLib/jxlib.uncompressed.js
IE9patch.js
Added: trunk/lib/OpenLayers/OpenLayersGMapsPatch.js
--- trunk/lib/OpenLayers/OpenLayersGMapsPatch.js (rev 0)
+++ trunk/lib/OpenLayers/OpenLayersGMapsPatch.js 2012-07-07 12:08:15 UTC (rev 2544)
@@ -0,0 +1,54 @@
+ * OpenLayersGMapsPatch.js
+ * This is a TOS-compliant patch to remove the "Map Data" popup that gets displayed on each map move.
+ * Source: http://trac.osgeo.org/openlayers/wiki/Release/2.11/GoogleMaps37
+ * TODO: When we move to OpenLayers 2.12, the patch is built in and this file will no longer be needed
+OpenLayers.Layer.Google.v3.repositionMapElements = function() {
+ // This is the first time any Google layer in this mapObject has been
+ // made visible. The mapObject needs to know the container size.
+ google.maps.event.trigger(this.mapObject, "resize");
+ var div = this.mapObject.getDiv().firstChild;
+ if (!div || div.childNodes.length < 3) {
+ this.repositionTimer = window.setTimeout(
+ OpenLayers.Function.bind(this.repositionMapElements, this),
+ 250
+ return false;
+ var cache = OpenLayers.Layer.Google.cache[this.map.id];
+ var container = this.map.viewPortDiv;
+ // move the ToS and branding stuff up to the container div
+ // depends on value of zIndex, which is not robust
+ for (var i=div.children.length-1; i>=0; --i) {
+ if (div.children[i].style.zIndex == 1000001) {
+ var termsOfUse = div.children[i];
+ container.appendChild(termsOfUse);
+ termsOfUse.style.zIndex = "1100";
+ termsOfUse.style.bottom = "";
+ termsOfUse.className = "olLayerGoogleCopyright olLayerGoogleV3";
+ termsOfUse.style.display = "";
+ cache.termsOfUse = termsOfUse;
+ if (div.children[i].style.zIndex == 1000000) {
+ var poweredBy = div.children[i];
+ container.appendChild(poweredBy);
+ poweredBy.style.zIndex = "1100";
+ poweredBy.style.bottom = "";
+ poweredBy.className = "olLayerGooglePoweredBy olLayerGoogleV3 gmnoprint";
+ poweredBy.style.display = "";
+ cache.poweredBy = poweredBy;
+ if (div.children[i].style.zIndex == 10000002) {
+ container.appendChild(div.children[i]);
+ this.setGMapVisibility(this.visibility);
\ No newline at end of file
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js 2012-07-07 11:51:06 UTC (rev 2543)
+++ trunk/lib/fusion.js 2012-07-07 12:08:15 UTC (rev 2544)
@@ -1398,6 +1398,7 @@
if (!Fusion._singleFile) {
var coreScripts = ['lib/OpenLayers/OpenLayers.js',
+ 'lib/OpenLayers/OpenLayersGMapsPatch.js', /* Remove when we base off of OL 2.12 */
'lib/OLpatch.js',
'lib/jxLib/jxlib.uncompressed.js',
'lib/IE9patch.js',
More information about the fusion-commits
