[fusion-commits] r2549 - sandbox/adsk/2.3r/layers/MapGuide/php
svn_fusion at osgeo.org
Mon Jul 16 23:23:39 PDT 2012
Author: liuar
Date: 2012-07-16 23:23:39 -0700 (Mon, 16 Jul 2012)
New Revision: 2549
sandbox/adsk/2.3r/layers/MapGuide/php/GetSelectionProperties.php
On behalf of: Andy Zhang
We should add geometry name to query property list, otherwise the selection operation maybe fail. This change makes fusion code be consistent with ASP code.
Modified: sandbox/adsk/2.3r/layers/MapGuide/php/GetSelectionProperties.php
--- sandbox/adsk/2.3r/layers/MapGuide/php/GetSelectionProperties.php 2012-07-17 02:03:03 UTC (rev 2548)
+++ sandbox/adsk/2.3r/layers/MapGuide/php/GetSelectionProperties.php 2012-07-17 06:23:39 UTC (rev 2549)
@@ -81,16 +81,18 @@
//the one causing a problem when the properies are limited ?
if (isset($_SESSION['property_mappings']) && isset($_SESSION['property_mappings'][$oLayer->GetObjectId()])) {
$mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
- if (0 && count($mappings) > 0) {
+ if (count($mappings) > 0) {
foreach($mappings as $name => $value) {
$queryOptions->AddFeatureProperty($name);
//echo "$name $value <br>\n";
- $geomName = $oLayer->GetFeatureGeometryName();
- $queryOptions->AddFeatureProperty($geomName);
+ //Add geometry property in all cases.
+ $geomName = $oLayer->GetFeatureGeometryName();
+ $queryOptions->AddFeatureProperty($geomName);
$filter = $selection->GenerateFilter($oLayer, $class);
$queryOptions->SetFilter($filter);
$featureReader = $featureService->SelectFeatures($featureResId, $class, $queryOptions);
More information about the fusion-commits
