[fusion-commits] r2557 - trunk/widgets/QuickPlot
svn_fusion at osgeo.org
Thu Jul 26 03:00:06 PDT 2012
Author: liuar
Date: 2012-07-26 03:00:05 -0700 (Thu, 26 Jul 2012)
New Revision: 2557
trunk/widgets/QuickPlot/QuickPlotPanel.js
trunk/widgets/QuickPlot/QuickPlotPanel.templ
On behalf of Ted Yang.
fix the ticket 2075: http://trac.osgeo.org/mapguide/ticket/2075
The submission is mainly implement the RFC 124:http://trac.osgeo.org/mapguide/wiki/MapGuideRfc124
part 4:
refine the GUI to make the paper list and orientation always enable
Modified: trunk/widgets/QuickPlot/QuickPlotPanel.js
--- trunk/widgets/QuickPlot/QuickPlotPanel.js 2012-07-26 02:00:35 UTC (rev 2556)
+++ trunk/widgets/QuickPlot/QuickPlotPanel.js 2012-07-26 10:00:05 UTC (rev 2557)
@@ -80,8 +80,7 @@
var lastScale = getParent().Cookie.read("QuickPlotLastUsedScaling");
var lastDPI = getParent().Cookie.read("QuickPlotLastUsedDPI");
var lastOrientation = getParent().Cookie.read("QuickPlotLastUsedOrientation");
if (lastPaperSize != null){
document.getElementById("PaperList").value = lastPaperSize;
@@ -118,10 +117,8 @@
function setAdvancedOptionsUI(enabled)
- document.getElementById("PaperList").disabled = !enabled;
document.getElementById("ScalingList").disabled = !enabled;
document.getElementById("DPIList").disabled = !enabled;
- document.getElementById("OrientationList").disabled = !enabled;
var mapCapturer = getParent().Fusion.getWidgetsByType("QuickPlot")[0].mapCapturer;
@@ -304,5 +301,5 @@
function drawCaptureBox()
- mapCapturer.setSize(getPrintSize(), getScale());
+ mapCapturer.setSize( getPrintSize() , getScale() );
Modified: trunk/widgets/QuickPlot/QuickPlotPanel.templ
--- trunk/widgets/QuickPlot/QuickPlotPanel.templ 2012-07-26 02:00:35 UTC (rev 2556)
+++ trunk/widgets/QuickPlot/QuickPlotPanel.templ 2012-07-26 10:00:05 UTC (rev 2557)
@@ -90,16 +90,6 @@
</div>
<div class="HPlaceholder5px"></div>
- <div class="HPlaceholder5px"></div>
- <div class="Label">
- <table cellspacing="0" cellpadding="0">
- <tr>
- <td><input type="checkbox" id="AdvancedOptionsCheckBox" onclick="setAdvancedOptionsUI(this.checked)" /></td>
- <td><label for="AdvancedOptionsCheckBox">__#QUICKPLOT_ADVANCED_OPTIONS#__</label></td>
- </tr>
- </table>
- </div>
<div class="Label">__#QUICKPLOT_PAPER_SIZE#__</div>
<div class="Ctrl">
@@ -115,10 +105,31 @@
</select>
</div>
<input type="hidden" id="paperSize" name="paperSize" />
+ <div class="HPlaceholder5px"></div>
+ <div class="Label">__#QUICKPLOT_ORIENTATION#__</div>
+ <div class="Ctrl">
+ The pre-defined scales. The value for each "option" item is the scale denominator.
+ We can change the html code to extend the pre-defined scales
+ <select class="FixWidth" name="OrientationList" id="OrientationList" onchange="drawCaptureBox(this)">
+ <option value="P">__#QUICKPLOT_ORIENTATION_P#__</option>
+ <option value="L">__#QUICKPLOT_ORIENTATION_L#__</option>
+ </select>
+ </div>
+ <input type="hidden" id="orientation" name="orientation" />
+ <table cellspacing="0" cellpadding="0">
+ <tr>
+ <td><input type="checkbox" id="AdvancedOptionsCheckBox" onclick="setAdvancedOptionsUI(this.checked)" /></td>
+ <td><label for="AdvancedOptionsCheckBox">__#QUICKPLOT_ADVANCED_OPTIONS#__</label></td>
+ </tr>
+ </table>
+ </div>
<div class="Label">__#QUICKPLOT_SCALING#__</div>
<div class="Ctrl">
@@ -133,7 +144,6 @@
</select>
</div>
<input type="hidden" id="scaleDenominator" name="scaleDenominator" />
<div class="Label" id="DPILabel">__#QUICKPLOT_DPI#__</div>
<div class="Ctrl" id="DPICtrl">
@@ -147,23 +157,8 @@
<option value="600">600</option>
</select>
</div>
- <input type="hidden" id="dpi" name="dpi" />
+ <input type="hidden" id="dpi" name="dpi" />
- <div class="Label">__#QUICKPLOT_ORIENTATION#__</div>
- <div class="Ctrl">
- The pre-defined scales. The value for each "option" item is the scale denominator.
- We can change the html code to extend the pre-defined scales
- <select class="FixWidth" name="OrientationList" id="OrientationList" onchange="drawCaptureBox(this)">
- <option value="P">__#QUICKPLOT_ORIENTATION_P#__</option>
- <option value="L">__#QUICKPLOT_ORIENTATION_L#__</option>
- </select>
- </div>
- <input type="hidden" id="orientation" name="orientation" />
<div class="ButtonContainer FixWidth">
More information about the fusion-commits
