[fusion-commits] r2614 - in trunk/widgets: . FeatureInfo
svn_fusion at osgeo.org
Thu Oct 4 22:11:02 PDT 2012
Author: jng
Date: 2012-10-04 22:11:02 -0700 (Thu, 04 Oct 2012)
New Revision: 2614
trunk/widgets/FeatureInfo.js
trunk/widgets/FeatureInfo/featureinfomain.php
Feature Info widget tweaks
- #538: Use MapMessage for relaying digitization messages
- Like the Redline widget, clear out any active digitizer and map messages on widget deactivation
Modified: trunk/widgets/FeatureInfo/featureinfomain.php
--- trunk/widgets/FeatureInfo/featureinfomain.php 2012-09-26 07:55:44 UTC (rev 2613)
+++ trunk/widgets/FeatureInfo/featureinfomain.php 2012-10-05 05:11:02 UTC (rev 2614)
@@ -57,6 +57,10 @@
$noLayerInfoLocal = GetLocalizedString('FEATUREINFONOINFO', $locale );
$noFeatureInLocal = GetLocalizedString('FEATUREINFONOFEATUREIN', $locale );
+ $drawPointLocal = GetLocalizedString("REDLINEEDITPOINTHELP", $locale );
+ $drawRectLocal = GetLocalizedString("REDLINEEDITRECTANGLEHELP", $locale );
+ $drawPolyLocal = GetLocalizedString("REDLINEEDITPOLYGONHELP", $locale );
try
$featureInfo = new FeatureInfo($args);
@@ -95,6 +99,10 @@
var session = '<?= $args['SESSION'] ?>';
var mapName = '<?= $args['MAPNAME'] ?>';
+ var DRAW_POINT_HELP = '<?= $drawPointLocal ?>';
+ var DRAW_RECT_HELP = '<?= $drawRectLocal ?>';
+ var DRAW_POLY_HELP = '<?= $drawPolyLocal ?>';
var properties = null;
var results;
@@ -119,11 +127,23 @@
map.clearSelection();
+ function SetMessage(msg) {
+ var map = GetFusionMapWidget();
+ map.message.info(msg);
+ function ClearMessage() {
+ map.message.clear();
function OnDigitizePoint() {
+ SetMessage(DRAW_POINT_HELP);
DigitizePoint(OnPointDigitized);
function OnPointDigitized(point) {
+ ClearMessage();
var tolerance = GetFusionMapWidget().pixToGeoMeasure(3);
var min = {x:point.X-tolerance,y:point.Y-tolerance};
var max = {x:point.X+tolerance,y:point.Y+tolerance};
@@ -132,22 +152,26 @@
SetSpatialFilter(geom);
function OnDigitizeRectangle() {
+ SetMessage(DRAW_RECT_HELP);
DigitizeRectangle(OnRectangleDigitized);
function OnRectangleDigitized(rectangle) {
- var min = rectangle.Point1;
- var max = rectangle.Point2;
- var geom = 'POLYGON(('+ min.X + ' ' + min.Y + ', ' + max.X + ' ' + min.Y + ', ' + max.X + ' ' + max.Y + ', ' + min.X + ' ' + max.Y + ', ' + min.X + ' ' + min.Y + '))';
+ ClearMessage();
+ var min = rectangle.Point1;
+ var max = rectangle.Point2;
+ var geom = 'POLYGON(('+ min.X + ' ' + min.Y + ', ' + max.X + ' ' + min.Y + ', ' + max.X + ' ' + max.Y + ', ' + min.X + ' ' + max.Y + ', ' + min.X + ' ' + min.Y + '))';
- SetSpatialFilter(geom);
+ SetSpatialFilter(geom);
function OnDigitizePolygon() {
+ SetMessage(DRAW_POLY_HELP);
DigitizePolygon(OnPolyonDigitized);
function OnPolyonDigitized(polygon) {
+ ClearMessage();
var points = [];
for (var i = 0; i < polygon.Count; i++) {
points.push(polygon.Point(i).X+' '+polygon.Point(i).Y);
@@ -267,10 +291,11 @@
function OnUnload() {
- var map = GetFusionMapWidget();
- map.deregisterForEvent(Fusion.Event.MAP_SELECTION_ON, SelectionOn);
- map.deregisterForEvent(Fusion.Event.MAP_SELECTION_OFF, SelectionOff);
- map.deregisterForEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, ActiveLayerChange);
+ ClearDigitization(true);
+ map.deregisterForEvent(Fusion.Event.MAP_SELECTION_ON, SelectionOn);
+ map.deregisterForEvent(Fusion.Event.MAP_SELECTION_OFF, SelectionOff);
+ map.deregisterForEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, ActiveLayerChange);
</script>
Modified: trunk/widgets/FeatureInfo.js
--- trunk/widgets/FeatureInfo.js 2012-09-26 07:55:44 UTC (rev 2613)
+++ trunk/widgets/FeatureInfo.js 2012-10-05 05:11:02 UTC (rev 2614)
@@ -42,6 +42,7 @@
isExclusive: true,
uiClass: Jx.Button,
sFeatures: 'menubar=no,location=no,resizable=no,status=no',
+ oTarget: null,
initializeWidget: function(widgetTag) {
var json = widgetTag.extension;
@@ -53,7 +54,7 @@
var url = this.sBaseUrl;
//add in other parameters to the url here
- var map = this.getMap();
+ this.mapWidget = this.getMap();
var widgetLayer = this.getMapLayer();
var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
var pageElement = $(this.sTarget);
@@ -79,12 +80,22 @@
taskPaneTarget.setContent(url);
+ this.oTarget = taskPaneTarget.iframe.contentWindow;
} else {
if ( pageElement ) {
pageElement.src = url;
+ this.oTarget = pageElement;
} else {
- window.open(url, this.sTarget, this.sWinFeatures);
+ this.oTarget = window.open(url, this.sTarget, this.sWinFeatures);
+ deactivate: function() {
+ this.mapWidget.message.clear();
+ //This function exists if MapGuideViewerApi.js was included in
+ if (this.oTarget && this.oTarget.ClearDigitization) {
+ this.oTarget.ClearDigitization(true);
More information about the fusion-commits
