[fusion-commits] r2617 - trunk
svn_fusion at osgeo.org
Mon Oct 8 05:41:25 PDT 2012
Author: jng
Date: 2012-10-08 05:41:24 -0700 (Mon, 08 Oct 2012)
New Revision: 2617
trunk/build.xml
#537: Add a new "selfbuild" target that creates a zip file containing the necessary build files required to "re-compile" a new fusionSF.js and fusionSF-compressed.js in a production Fusion installation (that wouldn't have these files)
Modified: trunk/build.xml
--- trunk/build.xml 2012-10-08 12:36:46 UTC (rev 2616)
+++ trunk/build.xml 2012-10-08 12:41:24 UTC (rev 2617)
@@ -77,6 +77,7 @@
<property name="app.version" value="2.0.x"/>
<property name="build.home" value="${basedir}/build"/>
<property name="deploy.home" value="${basedir}/../${app.name}"/>
+ <property name="selfbuild.home" value="${basedir}/selfbuild"/>
<property name="dist.home" value="${basedir}/dist"/>
<property name="docs.home" value="${build.home}/docs"/>
@@ -321,8 +322,29 @@
</copy>
</target>
+<!-- ==================== SelfBuild ========================================== -->
+ The "selfbuild" copies this file and any supporting tools/utilities and creates a zip
+ file containing the required build tools to "re-compile" a new fusionSF.js and
+ fusionSF-compressed.js on a production fusion installation
+ <target name="selfbuild" description="Create zip file containing build tools">
+ <echo message="Deploying to web server"/>
+ <mkdir dir="${selfbuild.home}"/>
+ <delete file="${selfbuild.home}/${app.name}-buildtools.zip" />
+ <copy todir="${selfbuild.home}">
+ <fileset dir="${basedir}"
+ includes="build.xml
+ config_dist.json
+ docs_config/**
+ utils/**" />
+ </copy>
+ <!-- Create source zip file -->
+ <zip destfile="${selfbuild.home}/${app.name}-buildtools.zip">
+ <zipfileset dir="${selfbuild.home}" />
+ </zip>
+ </target>
<!-- ==================== Dist Target ===================================== -->
@@ -366,6 +388,7 @@
<echo message="Removing build directories"/>
<delete dir="${build.home}"/>
<delete dir="${dist.home}"/>
+ <delete dir="${selfbuild.home}"/>
<delete file="${basedir}/lib/${sfName}.js" />
<delete file="${basedir}/lib/${sfName}-compressed.js" />
</target>
More information about the fusion-commits
