[fusion-commits] r2574 - in trunk: text widgets widgets/GoogleStreetViewer
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Sep 4 18:28:53 PDT 2012
Author: liuar
Date: 2012-09-04 18:28:53 -0700 (Tue, 04 Sep 2012)
New Revision: 2574
   trunk/text/en.json
   trunk/widgets/GoogleStreetViewer.js
   trunk/widgets/GoogleStreetViewer/GoogleStreetView.templ
On behalf of Ted Yang.
fix the ticket 2101: http://trac.osgeo.org/mapguide/ticket/2101
The submission is mainly implement the RFC 125:http://trac.osgeo.org/mapguide/wiki/MapGuideRfc125
part 4:
fix the license problem, cannot use GoogleStreetViewer without Google Base Map
Modified: trunk/text/en.json
--- trunk/text/en.json	2012-08-31 07:19:16 UTC (rev 2573)
+++ trunk/text/en.json	2012-09-05 01:28:53 UTC (rev 2574)
@@ -65,6 +65,7 @@
 'quickPlotResolutionWarning':'The current settings exceed the map resolution. Zooming out or increasing the scaling will help create a more legible plot',
 'googleSteetViewCSTransformError':'The CS of Current Map Cannot be transformed to EPSG:4326, which will result in Google Street View fail!',
 'googleSteetViewNotAvailableError':'The Service of Google Street View may not available in this specific location!',
+'googleBaseMapNotOnError':'To use Google Street Viewer, the Google Base Map must be turned on!',
 'noCommercialMapLayers':'NONE',
 'googleStreet':'Google Street',
 'googleSatellite':'Google Satellite',
Modified: trunk/widgets/GoogleStreetViewer/GoogleStreetView.templ
--- trunk/widgets/GoogleStreetViewer/GoogleStreetView.templ	2012-08-31 07:19:16 UTC (rev 2573)
+++ trunk/widgets/GoogleStreetViewer/GoogleStreetView.templ	2012-09-05 01:28:53 UTC (rev 2574)
@@ -218,6 +218,16 @@
                 return null;
+            function hidePage()
+                var pano = document.getElementById("pano");
+                pano.style.visibility = "hidden";
+            if(!window.hidePage) {
+                window.hidePage = hidePage;
             // Callback when body is loaded
             window.onBodyLoad = function() {
Modified: trunk/widgets/GoogleStreetViewer.js
--- trunk/widgets/GoogleStreetViewer.js	2012-08-31 07:19:16 UTC (rev 2573)
+++ trunk/widgets/GoogleStreetViewer.js	2012-09-05 01:28:53 UTC (rev 2574)
@@ -10,7 +10,7 @@
 Fusion.Widget.GoogleStreetViewer = OpenLayers.Class(Fusion.Widget, {
     isExclusive: false,
     uiClass: Jx.Button,
-    windowFeatures : "menubar=no,location=no,resizable=no,status=no,width=500,height=400",
+    windowFeatures: "menubar=no,location=no,resizable=no,status=no,width=500,height=400",
     targetWindow: null,
     GoogleSVPage: null,
     targetCs: null,
@@ -29,7 +29,7 @@
     showDirection: true,
     directionStyle: {
         fillColor: "black",
-        fillOpacity: 0.4,
+        fillOpacity: 0.4,
         strokeColor: "black",
         strokeOpacity: 1,
         strokeWidth: 3,
@@ -42,63 +42,95 @@
     directionLength: 22,
     csTransformErrorMessage: null,
     serviceUnavailableMessage: null,
+    googleBaseMapErrorMessage: null,
- * Constructor: GoogleStreetViewer
- * Parameters:
- * widgetTag - JSON node for this widget from the Application definition
-    initializeWidget: function(widgetTag) {
+    * Constructor: GoogleStreetViewer
+    * Parameters:
+    * widgetTag - JSON node for this widget from the Application definition
+    initializeWidget: function (widgetTag) {
         this.csTransformErrorMessage = OpenLayers.i18n("googleSteetViewCSTransformError");
         this.serviceUnavailableMessage = OpenLayers.i18n("googleSteetViewNotAvailableError");
+        this.googleBaseMapErrorMessage = OpenLayers.i18n("googleBaseMapNotOnError");
         this.targetCs = new OpenLayers.Projection("EPSG:4326");
         var json = widgetTag.extension;
         this.targetWindow = json.Target ? json.Target[0] : "TaskPane";
-        if(json.SymbolLayerName != null && json.SymbolLayerName[0].length != 0) {
+        if (json.SymbolLayerName != null && json.SymbolLayerName[0].length != 0) {
             this.symbolLayerName = json.SymbolLayerName[0];
-        if(json.ShowDirection != null && json.ShowDirection[0] != null) {
+        if (json.ShowDirection != null && json.ShowDirection[0] != null) {
             this.showDirection = (json.ShowDirection[0].toLowerCase() === "false") ? false : true;
-        if(json.DirectionLength != null && json.DirectionLength[0] != null && json.DirectionLength[0] != "") {
-            try{
-                   var length = parseInt(json.DirectionLength[0]);
-                   this.directionLength = length;
-               }catch(e){
+        if (json.DirectionLength != null && json.DirectionLength[0] != null && json.DirectionLength[0] != "") {
+            try {
+                var length = parseInt(json.DirectionLength[0]);
+                this.directionLength = length;
+            } catch (e) {
         this.additionalParameters = [];
         if (json.AdditionalParameter) {
-            for (var i=0; i<json.AdditionalParameter.length; i++) {
+            for (var i = 0; i < json.AdditionalParameter.length; i++) {
                 var p = json.AdditionalParameter[i];
                 var k = p.Key[0];
                 var v = p.Value[0];
-                this.additionalParameters.push(k+'='+encodeURIComponent(v));
+                this.additionalParameters.push(k + '=' + encodeURIComponent(v));
-        if(!Fusion.Widget.GoogleStreetViewer.prototype.enable) {
+        if (!Fusion.Widget.GoogleStreetViewer.prototype.enable) {
             this.disable();
+        this.getMap().oMapOL.events.register("changebaselayer",this, this.baseMapChanged);
+    baseMapChanged: function (layer){
+        if(!this.isGoogleBaseMapOn()) {
+            if(this.activated){
+                this.deactivate();
+                alert(this.googleBaseMapErrorMessage);
+    isGoogleBaseMapOn: function(){
+        var maps = this.getMap().aMaps;
+        for(var i=0; i < maps.length; i++){
+            if(maps[i].oLayerOL === this.getMap().oMapOL.baseLayer){
+                if(maps[i].layerType === "Google"){
+                    return true;
+        return false;
     activate: function() {
-        if(this.activated) return;
+            if (this.activated) {
+            return;
+        if (this.activated) return;
         //it seems this does nothing
         this.setGoogleSVPage(null);
-        if(!this.symbolLayer) {
+        if (!this.symbolLayer) {
             this.symbolLayer = Fusion.SymbolLayer.CreateOrGet(this.symbolLayerName, {
                 map: this.getMap().oMapOL,
                 symbolStyle: this.symbolStyle,
@@ -108,36 +140,36 @@
                 directionLength: this.directionLength
         this.symbolLayer.registerListener(this);
         this.symbolLayer.activateDragControl();
         this.activated = true;
         var url = Fusion.getFusionURL() + 'widgets/GoogleStreetViewer/GoogleStreetView.php';
         var aimTarget = Fusion.getWidgetById(this.targetWindow);
         var pageElement = $(this.targetWindow);
         var params = [];
-        params.push('ts='+new Date().getTime());
-        params.push('locale='+Fusion.locale);
+        params.push('ts=' + new Date().getTime());
+        params.push('locale=' + Fusion.locale);
         if (aimTarget || pageElement) {
             params.push("popup=false");
         else {
             params.push("popup=true");
         params = params.concat(this.additionalParameters);
         if (url.indexOf('?') < 0) {
             url += '?';
         else if (url.slice(-1) != '&') {
             url += '&';
         url += params.join('&');
         if (aimTarget) {
             aimTarget.setContent(url);
@@ -148,90 +180,96 @@
             window.open(url, this.targetWindow, this.windowFeatures);
-    deactivate: function() {
-        if(!this.activated) return;
+    deactivate: function () {
+        if (!this.activated) return;
         this.activated = false;
         if(this.symbolLayer != null) {
             this.symbolLayer.deregisterListener(this);
+        this.hideMessage(this.csTransformErrorMessage);
+        this.hideMessage(this.serviceUnavailableMessage);
+        this.hideMessage(this.googleBaseMapErrorMessage);
+        if(this.GoogleSVPage != null) {
+            this.GoogleSVPage.deregisterViewChangeListener(this);
+            this.GoogleSVPage.hidePage();
-    onSymbolChanged: function(position) {
-        if(!this.GoogleSVPage || !this.symbolLayer || !position){
+    onSymbolChanged: function (position) {
+        if (!this.GoogleSVPage || !this.symbolLayer || !position) {
             return;
         var lonlat = new OpenLayers.LonLat(position.x, position.y);
         var targetLonLat = new OpenLayers.LonLat(position.targetX, position.targetY);
         var mapProj = this.getMap().projection;
         //Goolge Street View always use the CS EPSG:4326,
         //The Symbol layer always use the same CS as the map
         //must consider if the transform is not correct
-        try
+        try {
             lonlat.transform(mapProj, this.targetCs);
             targetLonLat.transform(mapProj, this.targetCs);
-            this.hideMessage(this.csTransformErrorMessage);
             // Transform Z
             var unitsPerMeter = this.getUnitsPerMeter(this.targetCs);
             var unitsPerMeterInMap = this.getUnitsPerMeter(mapProj);
-            this.GoogleSVPage.setView(lonlat.lon, lonlat.lat, position.z*unitsPerMeter/unitsPerMeterInMap,
-            targetLonLat.lon, targetLonLat.lat, position.targetZ*unitsPerMeter/unitsPerMeterInMap);
-        }catch(e)
+            this.GoogleSVPage.setView(lonlat.lon, lonlat.lat, position.z * unitsPerMeter / unitsPerMeterInMap,
+            targetLonLat.lon, targetLonLat.lat, position.targetZ * unitsPerMeter / unitsPerMeterInMap);
+        } catch (e) {
             this.showMessage(this.csTransformErrorMessage);
-    getUnitsPerMeter: function(cs) {
-        if(cs.proj == null) return 1;
+    getUnitsPerMeter: function (cs) {
+        if (cs.proj == null) return 1;
         // This is because Proj4js has a defect about unit.
         // If CS doesn't include a unit and it has an angular unit, the angular unit will be set to CS unit.
         var unitIndex = cs.proj.unitIndex;
-        if(unitIndex == null) {
+        if (unitIndex == null) {
             var unit = cs.proj.units;
-            if(!unit) return 1;    // No units
+            if (!unit) return 1;    // No units
             unitIndex = Fusion.unitFromName(unit);
             cs.proj.unitIndex = unitIndex;
         return Fusion.fromMeter(unitIndex, 1);
-    onStreetViewChange: function(position) {
-        if(!this.activated || !this.GoogleSVPage || !position){
+    onStreetViewChange: function (position) {
+        if (!this.activated || !this.GoogleSVPage || !position) {
             return;
         var x = position.x;
         var y = position.y;
         var z = position.z;
         var targetX = position.targetX;
         var targetY = position.targetY;
         var targetZ = position.targetZ;
         var source = new OpenLayers.LonLat(x, y);
         var target = new OpenLayers.LonLat(targetX, targetY);
-        try
+        try {
             source.transform(this.targetCs, mapProj);
             target.transform(this.targetCs, mapProj);
             x = source.lon;
             y = source.lat;
             targetX = target.lon;
@@ -239,50 +277,49 @@
             // Transform Z
-            z = z*unitsPerMeterInMap/unitsPerMeter;
-            targetZ = targetZ*unitsPerMeterInMap/unitsPerMeter;
+            z = z * unitsPerMeterInMap / unitsPerMeter;
+            targetZ = targetZ * unitsPerMeterInMap / unitsPerMeter;
-            if(!this.getMap().getCurrentExtents().contains(x, y)) {
+            if (!this.getMap().getCurrentExtents().contains(x, y)) {
                 this.getMap().zoom(x, y, 1);
             this.symbolLayer.updateSymbolPosition(x, y, z, targetX, targetY, targetZ, this);
-        }catch(e)
+        } catch (e) {
-    setGoogleSVPage: function(GoogleSVWindow) {
-        if(this.GoogleSVPage != null) {
+    setGoogleSVPage: function (GoogleSVWindow) {
+        if (this.GoogleSVPage != null) {
         this.GoogleSVPage = GoogleSVWindow;
-        if(GoogleSVWindow != null) {
+        if (GoogleSVWindow != null) {
             this.GoogleSVPage.registerViewChangeListener(this);
-            if(this.GoogleSVPage.camera) {
+            if (this.GoogleSVPage.camera) {
                 this.onStreetViewChange(this.GoogleSVPage.camera);
-            else if(!this.symbolLayer && !this.symbolLayer.position){
+            else if (!this.symbolLayer && !this.symbolLayer.position) {
                 this.onSymbolChanged(this.symbolLayer.position);
             else {
                 var currentCenter = this.getMap().getCurrentCenter();
-				var viewCenter = this.getMap().geoToPix(currentCenter.x, currentCenter.y);
-				var aboveCenter = this.getMap().pixToGeo(viewCenter.x, viewCenter.y-10);
+                var viewCenter = this.getMap().geoToPix(currentCenter.x, currentCenter.y);
+                var aboveCenter = this.getMap().pixToGeo(viewCenter.x, viewCenter.y - 10);
                 //this only happens in the pageload phase of the GoogleSVPage
                 //and should initialize both the Street View location and the Symbol Layer location
                 this.symbolLayer.updateSymbolPosition(currentCenter.x, currentCenter.y, 0, aboveCenter.x, aboveCenter.y, 0, null);
-        else if(this.activated) {
+        else if (this.activated) {
             var instances = Fusion.Widget.uiInstances[this.type];
-            for (var i=0; i<instances.length; i++) {
+            for (var i = 0; i < instances.length; i++) {
                 var instance = instances[i];
                 if (instance.shouldActivateWith(this)) {
                     instance.deactivate();
@@ -291,20 +328,18 @@
             this.deactivate();
-    showMessage: function(message)
+    showMessage: function (message) {
         this.getMap().message.warn(message);
-    hideMessage: function(message)
-        if(this.getMap().message){
+    hideMessage: function (message) {
+        if (this.getMap().message) {
             this.getMap().message.hideDesignatedMessage(message);
-Proj4js.reportError = function(msg) {
-                throw msg;
-                //console.log(msg);
+Proj4js.reportError = function (msg) {
+    throw msg;
+    //console.log(msg);
More information about the fusion-commits mailing list
