[fusion-commits] r2583 - in trunk: layers/MapGuide widgets/Redline
    svn_fusion at osgeo.org
    Fri Sep  7 05:03:05 PDT 2012
Author: jng
Date: 2012-09-07 05:03:03 -0700 (Fri, 07 Sep 2012)
New Revision: 2583
   trunk/layers/MapGuide/MapGuideViewerApi.js
   trunk/widgets/Redline/editmarkup.php
#538: Fix undefined variable in MapGuideViewerApi.js and dismiss the notification bar on CloseEditor() for the Redline widget
Modified: trunk/layers/MapGuide/MapGuideViewerApi.js
--- trunk/layers/MapGuide/MapGuideViewerApi.js	2012-09-07 11:52:57 UTC (rev 2582)
+++ trunk/layers/MapGuide/MapGuideViewerApi.js	2012-09-07 12:03:03 UTC (rev 2583)
@@ -27,7 +27,7 @@
 * This is a simple API layer to mimick the MapGuide ajaxviewer API
 var mgApiMapWidgetId = 'Map';
-var mgApimgApiActiveWidget = null;
+var mgApiActiveWidget = null;
 var mgApiActiveControl = null;
 var mgApiDrawControls;
 var mgApiDigitizingLayer = null;
Modified: trunk/widgets/Redline/editmarkup.php
--- trunk/widgets/Redline/editmarkup.php	2012-09-07 11:52:57 UTC (rev 2582)
+++ trunk/widgets/Redline/editmarkup.php	2012-09-07 12:03:03 UTC (rev 2583)
@@ -277,6 +277,9 @@
 		function CloseEditor()
 			ClearDigitization(true);
+			var map = Fusion.getMapByName(mapName).mapWidget;
+			map.message.clear();
 			var editForm = document.getElementById("editForm");
 			editForm.action = "markupmain.php";
More information about the fusion-commits
