[fusion-commits] r2586 - in branches/fusion-mg24: . docs_config
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Sep 7 07:13:52 PDT 2012
Author: jng
Date: 2012-09-07 07:13:51 -0700 (Fri, 07 Sep 2012)
New Revision: 2586
Added:
   branches/fusion-mg24/docs_config/
   branches/fusion-mg24/docs_config/Languages.txt
   branches/fusion-mg24/docs_config/Menu.txt
   branches/fusion-mg24/docs_config/Topics.txt
Removed:
#540: Add doc config from trunk
Property changes on: branches/fusion-mg24/docs_config
___________________________________________________________________
Added: svn:ignore
   + Data
Deleted: branches/fusion-mg24/docs_config/Languages.txt
--- trunk/docs_config/Languages.txt	2012-09-07 12:03:03 UTC (rev 2583)
+++ branches/fusion-mg24/docs_config/Languages.txt	2012-09-07 14:13:51 UTC (rev 2586)
@@ -1,113 +0,0 @@
-Format: 1.4
-# This is the Natural Docs languages file for this project.  If you change
-# anything here, it will apply to THIS PROJECT ONLY.  If you'd like to change
-# something for all your projects, edit the Languages.txt in Natural Docs'
-# Config directory instead.
-# You can prevent certain file extensions from being scanned like this:
-# Ignore Extensions: [extension] [extension] ...
-# SYNTAX:
-# Unlike other Natural Docs configuration files, in this file all comments
-# MUST be alone on a line.  Some languages deal with the # character, so you
-# cannot put comments on the same line as content.
-# Also, all lists are separated with spaces, not commas, again because some
-# languages may need to use them.
-# Language: [name]
-# Alter Language: [name]
-#    Defines a new language or alters an existing one.  Its name can use any
-#    characters.  If any of the properties below have an add/replace form, you
-#    must use that when using Alter Language.
-#    The language Shebang Script is special.  It's entry is only used for
-#    extensions, and files with those extensions have their shebang (#!) lines
-#    read to determine the real language of the file.  Extensionless files are
-#    always treated this way.
-#    The language Text File is also special.  It's treated as one big comment
-#    so you can put Natural Docs content in them without special symbols.  Also,
-#    if you don't specify a package separator, ignored prefixes, or enum value
-#    behavior, it will copy those settings from the language that is used most
-#    in the source tree.
-# Extensions: [extension] [extension] ...
-# [Add/Replace] Extensions: [extension] [extension] ...
-#    Defines the file extensions of the language's source files.  You can
-#    redefine extensions found in the main languages file.  You can use * to
-#    mean any undefined extension.
-# Shebang Strings: [string] [string] ...
-# [Add/Replace] Shebang Strings: [string] [string] ...
-#    Defines a list of strings that can appear in the shebang (#!) line to
-#    designate that it's part of the language.  You can redefine strings found
-#    in the main languages file.
-# Ignore Prefixes in Index: [prefix] [prefix] ...
-# [Add/Replace] Ignored Prefixes in Index: [prefix] [prefix] ...
-# Ignore [Topic Type] Prefixes in Index: [prefix] [prefix] ...
-# [Add/Replace] Ignored [Topic Type] Prefixes in Index: [prefix] [prefix] ...
-#    Specifies prefixes that should be ignored when sorting symbols in an
-#    index.  Can be specified in general or for a specific topic type.
-# For basic language support only:
-# Line Comments: [symbol] [symbol] ...
-#    Defines a space-separated list of symbols that are used for line comments,
-#    if any.
-# Block Comments: [opening sym] [closing sym] [opening sym] [closing sym] ...
-#    Defines a space-separated list of symbol pairs that are used for block
-#    comments, if any.
-# Package Separator: [symbol]
-#    Defines the default package separator symbol.  The default is a dot.
-# [Topic Type] Prototype Enders: [symbol] [symbol] ...
-#    When defined, Natural Docs will attempt to get a prototype from the code
-#    immediately following the topic type.  It stops when it reaches one of
-#    these symbols.  Use \n for line breaks.
-# Line Extender: [symbol]
-#    Defines the symbol that allows a prototype to span multiple lines if
-#    normally a line break would end it.
-# Enum Values: [global|under type|under parent]
-#    Defines how enum values are referenced.  The default is global.
-#    global       - Values are always global, referenced as 'value'.
-#    under type   - Values are under the enum type, referenced as
-#               'package.enum.value'.
-#    under parent - Values are under the enum's parent, referenced as
-#               'package.value'.
-# Perl Package: [perl package]
-#    Specifies the Perl package used to fine-tune the language behavior in ways
-#    too complex to do in this file.
-# For full language support only:
-# Full Language Support: [perl package]
-#    Specifies the Perl package that has the parsing routines necessary for full
-#    language support.
-# The following languages are defined in the main file, if you'd like to alter
-# them:
-#    Text File, Shebang Script, C/C++, C#, Java, JavaScript, Perl, Python,
-#    PHP, SQL, Visual Basic, Pascal, Assembly, Ada, Tcl, Ruby, Makefile,
-#    ActionScript, ColdFusion, R, Fortran
-# If you add a language that you think would be useful to other developers
-# and should be included in Natural Docs by default, please e-mail it to
-# languages [at] naturaldocs [dot] org.
Copied: branches/fusion-mg24/docs_config/Languages.txt (from rev 2583, trunk/docs_config/Languages.txt)
--- branches/fusion-mg24/docs_config/Languages.txt	                        (rev 0)
@@ -0,0 +1,113 @@
+Format: 1.4
+# This is the Natural Docs languages file for this project.  If you change
+# anything here, it will apply to THIS PROJECT ONLY.  If you'd like to change
+# something for all your projects, edit the Languages.txt in Natural Docs'
+# Config directory instead.
+# You can prevent certain file extensions from being scanned like this:
+# Ignore Extensions: [extension] [extension] ...
+# SYNTAX:
+# Unlike other Natural Docs configuration files, in this file all comments
+# MUST be alone on a line.  Some languages deal with the # character, so you
+# cannot put comments on the same line as content.
+# Also, all lists are separated with spaces, not commas, again because some
+# languages may need to use them.
+# Language: [name]
+# Alter Language: [name]
+#    Defines a new language or alters an existing one.  Its name can use any
+#    characters.  If any of the properties below have an add/replace form, you
+#    must use that when using Alter Language.
+#    The language Shebang Script is special.  It's entry is only used for
+#    extensions, and files with those extensions have their shebang (#!) lines
+#    read to determine the real language of the file.  Extensionless files are
+#    always treated this way.
+#    The language Text File is also special.  It's treated as one big comment
+#    so you can put Natural Docs content in them without special symbols.  Also,
+#    if you don't specify a package separator, ignored prefixes, or enum value
+#    behavior, it will copy those settings from the language that is used most
+#    in the source tree.
+# Extensions: [extension] [extension] ...
+# [Add/Replace] Extensions: [extension] [extension] ...
+#    Defines the file extensions of the language's source files.  You can
+#    redefine extensions found in the main languages file.  You can use * to
+#    mean any undefined extension.
+# Shebang Strings: [string] [string] ...
+# [Add/Replace] Shebang Strings: [string] [string] ...
+#    Defines a list of strings that can appear in the shebang (#!) line to
+#    designate that it's part of the language.  You can redefine strings found
+#    in the main languages file.
+# Ignore Prefixes in Index: [prefix] [prefix] ...
+# [Add/Replace] Ignored Prefixes in Index: [prefix] [prefix] ...
+# Ignore [Topic Type] Prefixes in Index: [prefix] [prefix] ...
+# [Add/Replace] Ignored [Topic Type] Prefixes in Index: [prefix] [prefix] ...
+#    Specifies prefixes that should be ignored when sorting symbols in an
+#    index.  Can be specified in general or for a specific topic type.
+# For basic language support only:
+# Line Comments: [symbol] [symbol] ...
+#    Defines a space-separated list of symbols that are used for line comments,
+#    if any.
+# Block Comments: [opening sym] [closing sym] [opening sym] [closing sym] ...
+#    Defines a space-separated list of symbol pairs that are used for block
+#    comments, if any.
+# Package Separator: [symbol]
+#    Defines the default package separator symbol.  The default is a dot.
+# [Topic Type] Prototype Enders: [symbol] [symbol] ...
+#    When defined, Natural Docs will attempt to get a prototype from the code
+#    immediately following the topic type.  It stops when it reaches one of
+#    these symbols.  Use \n for line breaks.
+# Line Extender: [symbol]
+#    Defines the symbol that allows a prototype to span multiple lines if
+#    normally a line break would end it.
+# Enum Values: [global|under type|under parent]
+#    Defines how enum values are referenced.  The default is global.
+#    global       - Values are always global, referenced as 'value'.
+#    under type   - Values are under the enum type, referenced as
+#               'package.enum.value'.
+#    under parent - Values are under the enum's parent, referenced as
+#               'package.value'.
+# Perl Package: [perl package]
+#    Specifies the Perl package used to fine-tune the language behavior in ways
+#    too complex to do in this file.
+# For full language support only:
+# Full Language Support: [perl package]
+#    Specifies the Perl package that has the parsing routines necessary for full
+#    language support.
+# The following languages are defined in the main file, if you'd like to alter
+# them:
+#    Text File, Shebang Script, C/C++, C#, Java, JavaScript, Perl, Python,
+#    PHP, SQL, Visual Basic, Pascal, Assembly, Ada, Tcl, Ruby, Makefile,
+#    ActionScript, ColdFusion, R, Fortran
+# If you add a language that you think would be useful to other developers
+# and should be included in Natural Docs by default, please e-mail it to
+# languages [at] naturaldocs [dot] org.
Deleted: branches/fusion-mg24/docs_config/Menu.txt
--- trunk/docs_config/Menu.txt	2012-09-07 12:03:03 UTC (rev 2583)
+++ branches/fusion-mg24/docs_config/Menu.txt	2012-09-07 14:13:51 UTC (rev 2586)
@@ -1,152 +0,0 @@
-Format: 1.4
-Title: Fusion
-SubTitle: API Reference
-# You can add a footer to your documentation like this:
-# Footer: [text]
-# If you want to add a copyright notice, this would be the place to do it.
-# You can add a timestamp to your documentation like one of these:
-# Timestamp: Generated on month day, year
-# Timestamp: Updated mm/dd/yyyy
-# Timestamp: Last updated mon day
-#   m     - One or two digit month.  January is "1"
-#   mm    - Always two digit month.  January is "01"
-#   mon   - Short month word.  January is "Jan"
-#   month - Long month word.  January is "January"
-#   d     - One or two digit day.  1 is "1"
-#   dd    - Always two digit day.  1 is "01"
-#   day   - Day with letter extension.  1 is "1st"
-#   yy    - Two digit year.  2006 is "06"
-#   yyyy  - Four digit year.  2006 is "2006"
-#   year  - Four digit year.  2006 is "2006"
-# Cut and paste the lines below to change the order in which your files
-# appear on the menu.  Don't worry about adding or removing files, Natural
-# Docs will take care of that.
-# You can further organize the menu by grouping the entries.  Add a
-# "Group: [name] {" line to start a group, and add a "}" to end it.
-# You can add text and web links to the menu by adding "Text: [text]" and
-# "Link: [name] ([URL])" lines, respectively.
-# The formatting and comments are auto-generated, so don't worry about
-# neatness when editing the file.  Natural Docs will clean it up the next
-# time it is run.  When working with groups, just deal with the braces and
-# forget about the indentation and comments.
-# You can use this file on other computers even if they use different
-# directories.  As long as the command line points to the same source files,
-# Natural Docs will be able to correct the locations automatically.
-Group: Core  {
-   File: Fusion  (no auto-title, %WORKING_COPY%\build\lib\fusion.js)
-   File: Fusion.Error  (no auto-title, %WORKING_COPY%\build\lib\Error.js)
-   File: Fusion.Lib.ApplicationDefinition  (no auto-title, %WORKING_COPY%\build\lib\ApplicationDefinition.js)
-   File: Fusion.Lib.EventMgr  (no auto-title, %WORKING_COPY%\build\lib\EventMgr.js)
-   File: Fusion.Lib.MGBroker  (no auto-title, %WORKING_COPY%\build\lib\MGBroker.js)
-   File: Fusion.MapMessage  (no auto-title, %WORKING_COPY%\build\lib\MapMessage.js)
-   File: Fusion.Tool.Rectangle  (no auto-title, %WORKING_COPY%\build\lib\RectTool.js)
-   File: Fusion.Tool.Search  (no auto-title, %WORKING_COPY%\build\lib\Search.js)
-   File: Fusion.Widget  (no auto-title, %WORKING_COPY%\build\lib\Widget.js)
-   File: Fusion.Widget.Map  (no auto-title, %WORKING_COPY%\build\lib\Map.js)
-   }  # Group: Core
-Group: Widgets  {
-   File: Fusion.Widget.About  (no auto-title, %WORKING_COPY%\build\widgets\About.js)
-   File: Fusion.Widget.ActivityIndicator  (no auto-title, %WORKING_COPY%\build\widgets\ActivityIndicator.js)
-   File: Fusion.Widget.AddWMSLayer  (no auto-title, %WORKING_COPY%\build\widgets\AddWMSLayer.js)
-   File: Fusion.Widget.BasemapSwitcher  (no auto-title, %WORKING_COPY%\build\widgets\BasemapSwitcher.js)
-   File: Fusion.Widget.Buffer  (no auto-title, %WORKING_COPY%\build\widgets\Buffer.js)
-   File: Fusion.Widget.BufferPanel  (no auto-title, %WORKING_COPY%\build\widgets\BufferPanel.js)
-   File: Fusion.Widget.CenterSelection  (no auto-title, %WORKING_COPY%\build\widgets\CenterSelection.js)
-   File: Fusion.Widget.ClearSelection  (no auto-title, %WORKING_COPY%\build\widgets\ClearSelection.js)
-   File: Fusion.Widget.ColorPicker  (no auto-title, %WORKING_COPY%\build\widgets\ColorPicker.js)
-   File: Fusion.Widget.CursorPosition  (no auto-title, %WORKING_COPY%\build\widgets\CursorPosition.js)
-   File: Fusion.Widget.EditableScale  (no auto-title, %WORKING_COPY%\build\widgets\EditableScale.js)
-   File: Fusion.Widget.ExtentHistory  (no auto-title, %WORKING_COPY%\build\widgets\ExtentHistory.js)
-   File: Fusion.Widget.FeatureInfo  (no auto-title, %WORKING_COPY%\build\widgets\FeatureInfo.js)
-   File: Fusion.Widget.GetFeatureInfo  (no auto-title, %WORKING_COPY%\build\widgets\GetFeatureInfo.js)
-   File: Fusion.Widget.GoogleStreetViewer  (no auto-title, %WORKING_COPY%\build\widgets\GoogleStreetViewer.js)
-   File: Fusion.Widget.Help  (no auto-title, %WORKING_COPY%\build\widgets\Help.js)
-   File: Fusion.Widget.InitialMapView  (no auto-title, %WORKING_COPY%\build\widgets\InitialMapView.js)
-   File: Fusion.Widget.InvokeScript  (no auto-title, %WORKING_COPY%\build\widgets\InvokeScript.js)
-   File: Fusion.Widget.InvokeURL  (no auto-title, %WORKING_COPY%\build\widgets\InvokeURL.js)
-   File: Fusion.Widget.LayerManager  (no auto-title, %WORKING_COPY%\build\widgets\LayerManager.js)
-   File: Fusion.Widget.Legend  (no auto-title, %WORKING_COPY%\build\widgets\Legend.js)
-   File: Fusion.Widget.LinkToView  (no auto-title, %WORKING_COPY%\build\widgets\LinkToView.js)
-   File: Fusion.Widget.MapMenu  (no auto-title, %WORKING_COPY%\build\widgets\MapMenu.js)
-   File: Fusion.Widget.MapMetadata  (no auto-title, %WORKING_COPY%\build\widgets\MapMetadata.js)
-   File: Fusion.Widget.Maptip  (no auto-title, %WORKING_COPY%\build\widgets\Maptip.js)
-   File: Fusion.Widget.Measure  (no auto-title, %WORKING_COPY%\build\widgets\Measure.js)
-   File: Fusion.Widget.Navigator  (no auto-title, %WORKING_COPY%\build\widgets\Navigator.js)
-   File: Fusion.Widget.OverviewMap  (no auto-title, %WORKING_COPY%\build\widgets\OverviewMap.js)
-   File: Fusion.Widget.Pan  (no auto-title, %WORKING_COPY%\build\widgets\Pan.js)
-   File: Fusion.Widget.PanOnClick  (no auto-title, %WORKING_COPY%\build\widgets\PanOnClick.js)
-   File: Fusion.Widget.PanQuery  (no auto-title, %WORKING_COPY%\build\widgets\PanQuery.js)
-   File: Fusion.Widget.Print  (no auto-title, %WORKING_COPY%\build\widgets\Print.js)
-   File: Fusion.Widget.Query  (no auto-title, %WORKING_COPY%\build\widgets\Query.js)
-   File: Fusion.Widget.QuickPlot  (no auto-title, %WORKING_COPY%\build\widgets\QuickPlot.js)
-   File: Fusion.Widget.Redline  (no auto-title, %WORKING_COPY%\build\widgets\Redline.js)
-   File: Fusion.Widget.RefreshMap  (no auto-title, %WORKING_COPY%\build\widgets\RefreshMap.js)
-   File: Fusion.Widget.SaveMap  (no auto-title, %WORKING_COPY%\build\widgets\SaveMap.js)
-   File: Fusion.Widget.SaveMapImage  (no auto-title, %WORKING_COPY%\build\widgets\SaveMapImage.js)
-   File: Fusion.Widget.SaveSession  (no auto-title, %WORKING_COPY%\build\widgets\SaveSession.js)
-   File: Fusion.Widget.Scalebar  (no auto-title, %WORKING_COPY%\build\widgets\Scalebar.js)
-   File: Fusion.Widget.ScalebarDual  (no auto-title, %WORKING_COPY%\build\widgets\ScalebarDual.js)
-   File: Fusion.Widget.Search  (no auto-title, %WORKING_COPY%\build\widgets\Search.js)
-   File: Fusion.Widget.Select  (no auto-title, %WORKING_COPY%\build\widgets\Select.js)
-   File: Fusion.Widget.SelectionInfo  (no auto-title, %WORKING_COPY%\build\widgets\SelectionInfo.js)
-   File: Fusion.Widget.SelectionPanel  (no auto-title, %WORKING_COPY%\build\widgets\SelectionPanel.js)
-   File: Fusion.Widget.SelectPolygon  (no auto-title, %WORKING_COPY%\build\widgets\SelectPolygon.js)
-   File: Fusion.Widget.SelectRadius  (no auto-title, %WORKING_COPY%\build\widgets\SelectAttribute.js)
-   File: Fusion.Widget.SelectRadius  (no auto-title, %WORKING_COPY%\build\widgets\SelectRadius.js)
-   File: Fusion.Widget.SelectRadiusValue  (no auto-title, %WORKING_COPY%\build\widgets\SelectRadiusValue.js)
-   File: Fusion.Widget.SelectWithin  (no auto-title, %WORKING_COPY%\build\widgets\SelectWithin.js)
-   File: Fusion.Widget.TaskPane  (no auto-title, %WORKING_COPY%\build\widgets\TaskPane.js)
-   File: Fusion.Widget.Theme  (no auto-title, %WORKING_COPY%\build\widgets\Theme.js)
-   File: Fusion.Widget.ViewOptions  (no auto-title, %WORKING_COPY%\build\widgets\ViewOptions.js)
-   File: Fusion.Widget.ViewSize  (no auto-title, %WORKING_COPY%\build\widgets\ViewSize.js)
-   File: Fusion.Widget.Zoom  (no auto-title, %WORKING_COPY%\build\widgets\Zoom.js)
-   File: Fusion.Widget.ZoomOnClick  (no auto-title, %WORKING_COPY%\build\widgets\ZoomOnClick.js)
-   File: Fusion.Widget.ZoomToSelection  (no auto-title, %WORKING_COPY%\build\widgets\ZoomToSelection.js)
-   File: OpenLayers.Control.MapCapturer  (no auto-title, %WORKING_COPY%\build\widgets\QuickPlot\MapCapturer.js)
-   }  # Group: Widgets
-Group: External  {
-   File: OpenLayers.Map.isValidLonLat  (no auto-title, %WORKING_COPY%\build\lib\OLpatch.js)
-   File: JxLib  (no auto-title, %WORKING_COPY%\build\lib\jxLib\jxlib.uncompressed.js)
-   File: OpenLayers.Control.DragFeature  (no auto-title, %WORKING_COPY%\build\lib\DragFeature.js)
-   File: OpenLayers  (no auto-title, %WORKING_COPY%\build\lib\OpenLayers\OpenLayers.js)
-   File: Proj4js  (no auto-title, %WORKING_COPY%\build\lib\Proj4js\proj4js-combined.js)
-   }  # Group: External
-Group: Index  {
-   Index: Everything
-   Class Index: Classes
-   Constant Index: Constants
-   Event Index: Events
-   File Index: Files
-   Function Index: Functions
-   Property Index: Properties
-   }  # Group: Index
-##### Do not change or remove these lines. #####
-Data: 1(D3330wbgHu`HpEXm8oG6bFrWGubPpIWN8fGb_GYb777bcN68u\ztHN\AbYN8ofbo8Y)
-Data: 1(h3330wbgHu`HpEXm8oG6bFrWGubPpIWN8fGb_GYb777bcN68u\ztHN\AbYN8ofb78f`Gt6)
Copied: branches/fusion-mg24/docs_config/Menu.txt (from rev 2583, trunk/docs_config/Menu.txt)
--- branches/fusion-mg24/docs_config/Menu.txt	                        (rev 0)
@@ -0,0 +1,152 @@
+Format: 1.4
+Title: Fusion
+SubTitle: API Reference
+# You can add a footer to your documentation like this:
+# Footer: [text]
+# If you want to add a copyright notice, this would be the place to do it.
+# You can add a timestamp to your documentation like one of these:
+# Timestamp: Generated on month day, year
+# Timestamp: Updated mm/dd/yyyy
+# Timestamp: Last updated mon day
+#   m     - One or two digit month.  January is "1"
+#   mm    - Always two digit month.  January is "01"
+#   mon   - Short month word.  January is "Jan"
+#   month - Long month word.  January is "January"
+#   d     - One or two digit day.  1 is "1"
+#   dd    - Always two digit day.  1 is "01"
+#   day   - Day with letter extension.  1 is "1st"
+#   yy    - Two digit year.  2006 is "06"
+#   yyyy  - Four digit year.  2006 is "2006"
+#   year  - Four digit year.  2006 is "2006"
+# Cut and paste the lines below to change the order in which your files
+# appear on the menu.  Don't worry about adding or removing files, Natural
+# Docs will take care of that.
+# You can further organize the menu by grouping the entries.  Add a
+# "Group: [name] {" line to start a group, and add a "}" to end it.
+# You can add text and web links to the menu by adding "Text: [text]" and
+# "Link: [name] ([URL])" lines, respectively.
+# The formatting and comments are auto-generated, so don't worry about
+# neatness when editing the file.  Natural Docs will clean it up the next
+# time it is run.  When working with groups, just deal with the braces and
+# forget about the indentation and comments.
+# You can use this file on other computers even if they use different
+# directories.  As long as the command line points to the same source files,
+# Natural Docs will be able to correct the locations automatically.
+Group: Core  {
+   File: Fusion  (no auto-title, %WORKING_COPY%\build\lib\fusion.js)
+   File: Fusion.Error  (no auto-title, %WORKING_COPY%\build\lib\Error.js)
+   File: Fusion.Lib.ApplicationDefinition  (no auto-title, %WORKING_COPY%\build\lib\ApplicationDefinition.js)
+   File: Fusion.Lib.EventMgr  (no auto-title, %WORKING_COPY%\build\lib\EventMgr.js)
+   File: Fusion.Lib.MGBroker  (no auto-title, %WORKING_COPY%\build\lib\MGBroker.js)
+   File: Fusion.MapMessage  (no auto-title, %WORKING_COPY%\build\lib\MapMessage.js)
+   File: Fusion.Tool.Rectangle  (no auto-title, %WORKING_COPY%\build\lib\RectTool.js)
+   File: Fusion.Tool.Search  (no auto-title, %WORKING_COPY%\build\lib\Search.js)
+   File: Fusion.Widget  (no auto-title, %WORKING_COPY%\build\lib\Widget.js)
+   File: Fusion.Widget.Map  (no auto-title, %WORKING_COPY%\build\lib\Map.js)
+   }  # Group: Core
+Group: Widgets  {
+   File: Fusion.Widget.About  (no auto-title, %WORKING_COPY%\build\widgets\About.js)
+   File: Fusion.Widget.ActivityIndicator  (no auto-title, %WORKING_COPY%\build\widgets\ActivityIndicator.js)
+   File: Fusion.Widget.AddWMSLayer  (no auto-title, %WORKING_COPY%\build\widgets\AddWMSLayer.js)
+   File: Fusion.Widget.BasemapSwitcher  (no auto-title, %WORKING_COPY%\build\widgets\BasemapSwitcher.js)
+   File: Fusion.Widget.Buffer  (no auto-title, %WORKING_COPY%\build\widgets\Buffer.js)
+   File: Fusion.Widget.BufferPanel  (no auto-title, %WORKING_COPY%\build\widgets\BufferPanel.js)
+   File: Fusion.Widget.CenterSelection  (no auto-title, %WORKING_COPY%\build\widgets\CenterSelection.js)
+   File: Fusion.Widget.ClearSelection  (no auto-title, %WORKING_COPY%\build\widgets\ClearSelection.js)
+   File: Fusion.Widget.ColorPicker  (no auto-title, %WORKING_COPY%\build\widgets\ColorPicker.js)
+   File: Fusion.Widget.CursorPosition  (no auto-title, %WORKING_COPY%\build\widgets\CursorPosition.js)
+   File: Fusion.Widget.EditableScale  (no auto-title, %WORKING_COPY%\build\widgets\EditableScale.js)
+   File: Fusion.Widget.ExtentHistory  (no auto-title, %WORKING_COPY%\build\widgets\ExtentHistory.js)
+   File: Fusion.Widget.FeatureInfo  (no auto-title, %WORKING_COPY%\build\widgets\FeatureInfo.js)
+   File: Fusion.Widget.GetFeatureInfo  (no auto-title, %WORKING_COPY%\build\widgets\GetFeatureInfo.js)
+   File: Fusion.Widget.GoogleStreetViewer  (no auto-title, %WORKING_COPY%\build\widgets\GoogleStreetViewer.js)
+   File: Fusion.Widget.Help  (no auto-title, %WORKING_COPY%\build\widgets\Help.js)
+   File: Fusion.Widget.InitialMapView  (no auto-title, %WORKING_COPY%\build\widgets\InitialMapView.js)
+   File: Fusion.Widget.InvokeScript  (no auto-title, %WORKING_COPY%\build\widgets\InvokeScript.js)
+   File: Fusion.Widget.InvokeURL  (no auto-title, %WORKING_COPY%\build\widgets\InvokeURL.js)
+   File: Fusion.Widget.LayerManager  (no auto-title, %WORKING_COPY%\build\widgets\LayerManager.js)
+   File: Fusion.Widget.Legend  (no auto-title, %WORKING_COPY%\build\widgets\Legend.js)
+   File: Fusion.Widget.LinkToView  (no auto-title, %WORKING_COPY%\build\widgets\LinkToView.js)
+   File: Fusion.Widget.MapMenu  (no auto-title, %WORKING_COPY%\build\widgets\MapMenu.js)
+   File: Fusion.Widget.MapMetadata  (no auto-title, %WORKING_COPY%\build\widgets\MapMetadata.js)
+   File: Fusion.Widget.Maptip  (no auto-title, %WORKING_COPY%\build\widgets\Maptip.js)
+   File: Fusion.Widget.Measure  (no auto-title, %WORKING_COPY%\build\widgets\Measure.js)
+   File: Fusion.Widget.Navigator  (no auto-title, %WORKING_COPY%\build\widgets\Navigator.js)
+   File: Fusion.Widget.OverviewMap  (no auto-title, %WORKING_COPY%\build\widgets\OverviewMap.js)
+   File: Fusion.Widget.Pan  (no auto-title, %WORKING_COPY%\build\widgets\Pan.js)
+   File: Fusion.Widget.PanOnClick  (no auto-title, %WORKING_COPY%\build\widgets\PanOnClick.js)
+   File: Fusion.Widget.PanQuery  (no auto-title, %WORKING_COPY%\build\widgets\PanQuery.js)
+   File: Fusion.Widget.Print  (no auto-title, %WORKING_COPY%\build\widgets\Print.js)
+   File: Fusion.Widget.Query  (no auto-title, %WORKING_COPY%\build\widgets\Query.js)
+   File: Fusion.Widget.QuickPlot  (no auto-title, %WORKING_COPY%\build\widgets\QuickPlot.js)
+   File: Fusion.Widget.Redline  (no auto-title, %WORKING_COPY%\build\widgets\Redline.js)
+   File: Fusion.Widget.RefreshMap  (no auto-title, %WORKING_COPY%\build\widgets\RefreshMap.js)
+   File: Fusion.Widget.SaveMap  (no auto-title, %WORKING_COPY%\build\widgets\SaveMap.js)
+   File: Fusion.Widget.SaveMapImage  (no auto-title, %WORKING_COPY%\build\widgets\SaveMapImage.js)
+   File: Fusion.Widget.SaveSession  (no auto-title, %WORKING_COPY%\build\widgets\SaveSession.js)
+   File: Fusion.Widget.Scalebar  (no auto-title, %WORKING_COPY%\build\widgets\Scalebar.js)
+   File: Fusion.Widget.ScalebarDual  (no auto-title, %WORKING_COPY%\build\widgets\ScalebarDual.js)
+   File: Fusion.Widget.Search  (no auto-title, %WORKING_COPY%\build\widgets\Search.js)
+   File: Fusion.Widget.Select  (no auto-title, %WORKING_COPY%\build\widgets\Select.js)
+   File: Fusion.Widget.SelectionInfo  (no auto-title, %WORKING_COPY%\build\widgets\SelectionInfo.js)
+   File: Fusion.Widget.SelectionPanel  (no auto-title, %WORKING_COPY%\build\widgets\SelectionPanel.js)
+   File: Fusion.Widget.SelectPolygon  (no auto-title, %WORKING_COPY%\build\widgets\SelectPolygon.js)
+   File: Fusion.Widget.SelectRadius  (no auto-title, %WORKING_COPY%\build\widgets\SelectAttribute.js)
+   File: Fusion.Widget.SelectRadius  (no auto-title, %WORKING_COPY%\build\widgets\SelectRadius.js)
+   File: Fusion.Widget.SelectRadiusValue  (no auto-title, %WORKING_COPY%\build\widgets\SelectRadiusValue.js)
+   File: Fusion.Widget.SelectWithin  (no auto-title, %WORKING_COPY%\build\widgets\SelectWithin.js)
+   File: Fusion.Widget.TaskPane  (no auto-title, %WORKING_COPY%\build\widgets\TaskPane.js)
+   File: Fusion.Widget.Theme  (no auto-title, %WORKING_COPY%\build\widgets\Theme.js)
+   File: Fusion.Widget.ViewOptions  (no auto-title, %WORKING_COPY%\build\widgets\ViewOptions.js)
+   File: Fusion.Widget.ViewSize  (no auto-title, %WORKING_COPY%\build\widgets\ViewSize.js)
+   File: Fusion.Widget.Zoom  (no auto-title, %WORKING_COPY%\build\widgets\Zoom.js)
+   File: Fusion.Widget.ZoomOnClick  (no auto-title, %WORKING_COPY%\build\widgets\ZoomOnClick.js)
+   File: Fusion.Widget.ZoomToSelection  (no auto-title, %WORKING_COPY%\build\widgets\ZoomToSelection.js)
+   File: OpenLayers.Control.MapCapturer  (no auto-title, %WORKING_COPY%\build\widgets\QuickPlot\MapCapturer.js)
+   }  # Group: Widgets
+Group: External  {
+   File: OpenLayers.Map.isValidLonLat  (no auto-title, %WORKING_COPY%\build\lib\OLpatch.js)
+   File: JxLib  (no auto-title, %WORKING_COPY%\build\lib\jxLib\jxlib.uncompressed.js)
+   File: OpenLayers.Control.DragFeature  (no auto-title, %WORKING_COPY%\build\lib\DragFeature.js)
+   File: OpenLayers  (no auto-title, %WORKING_COPY%\build\lib\OpenLayers\OpenLayers.js)
+   File: Proj4js  (no auto-title, %WORKING_COPY%\build\lib\Proj4js\proj4js-combined.js)
+   }  # Group: External
+Group: Index  {
+   Index: Everything
+   Class Index: Classes
+   Constant Index: Constants
+   Event Index: Events
+   File Index: Files
+   Function Index: Functions
+   Property Index: Properties
+   }  # Group: Index
+##### Do not change or remove these lines. #####
+Data: 1(D3330wbgHu`HpEXm8oG6bFrWGubPpIWN8fGb_GYb777bcN68u\ztHN\AbYN8ofbo8Y)
+Data: 1(h3330wbgHu`HpEXm8oG6bFrWGubPpIWN8fGb_GYb777bcN68u\ztHN\AbYN8ofb78f`Gt6)
Deleted: branches/fusion-mg24/docs_config/Topics.txt
--- trunk/docs_config/Topics.txt	2012-09-07 12:03:03 UTC (rev 2583)
+++ branches/fusion-mg24/docs_config/Topics.txt	2012-09-07 14:13:51 UTC (rev 2586)
@@ -1,81 +0,0 @@
-Format: 1.4
-# This is the Natural Docs topics file for this project.  If you change anything
-# here, it will apply to THIS PROJECT ONLY.  If you'd like to change something
-# for all your projects, edit the Topics.txt in Natural Docs' Config directory
-# instead.
-# If you'd like to prevent keywords from being recognized by Natural Docs, you
-# can do it like this:
-# Ignore Keywords: [keyword], [keyword], ...
-# Or you can use the list syntax like how they are defined:
-# Ignore Keywords:
-#    [keyword]
-#    [keyword], [plural keyword]
-# SYNTAX:
-# Topic Type: [name]
-# Alter Topic Type: [name]
-#    Creates a new topic type or alters one from the main file.  Each type gets
-#    its own index and behavior settings.  Its name can have letters, numbers,
-#    spaces, and these charaters: - / . '
-# Plural: [name]
-#    Sets the plural name of the topic type, if different.
-# Keywords:
-#    [keyword]
-#    Defines or adds to the list of keywords for the topic type.  They may only
-#    contain letters, numbers, and spaces and are not case sensitive.  Plural
-#    keywords are used for list topics.  You can redefine keywords found in the
-#    main topics file.
-# Index: [yes|no]
-#    Whether the topics get their own index.  Defaults to yes.  Everything is
-#    included in the general index regardless of this setting.
-# Scope: [normal|start|end|always global]
-#    How the topics affects scope.  Defaults to normal.
-#    normal        - Topics stay within the current scope.
-#    start         - Topics start a new scope for all the topics beneath it,
-#                    like class topics.
-#    end           - Topics reset the scope back to global for all the topics
-#                    beneath it.
-#    always global - Topics are defined as global, but do not change the scope
-#                    for any other topics.
-# Class Hierarchy: [yes|no]
-#    Whether the topics are part of the class hierarchy.  Defaults to no.
-# Page Title If First: [yes|no]
-#    Whether the topic's title becomes the page title if it's the first one in
-#    a file.  Defaults to no.
-# Break Lists: [yes|no]
-#    Whether list topics should be broken into individual topics in the output.
-#    Defaults to no.
-# Can Group With: [type], [type], ...
-#    Defines a list of topic types that this one can possibly be grouped with.
-#    Defaults to none.
-# The following topics are defined in the main file, if you'd like to alter
-# their behavior or add keywords:
-#    Generic, Class, Interface, Section, File, Group, Function, Variable,
-#    Property, Type, Constant, Enumeration, Event, Delegate, Macro,
-#    Database, Database Table, Database View, Database Index, Database
-#    Cursor, Database Trigger, Cookie, Build Target
-# If you add something that you think would be useful to other developers
-# topics [at] naturaldocs [dot] org.
Copied: branches/fusion-mg24/docs_config/Topics.txt (from rev 2583, trunk/docs_config/Topics.txt)
--- branches/fusion-mg24/docs_config/Topics.txt	                        (rev 0)
@@ -0,0 +1,81 @@
+Format: 1.4
+# This is the Natural Docs topics file for this project.  If you change anything
+# here, it will apply to THIS PROJECT ONLY.  If you'd like to change something
+# for all your projects, edit the Topics.txt in Natural Docs' Config directory
+# instead.
+# If you'd like to prevent keywords from being recognized by Natural Docs, you
+# can do it like this:
+# Ignore Keywords: [keyword], [keyword], ...
+# Or you can use the list syntax like how they are defined:
+# Ignore Keywords:
+#    [keyword]
+#    [keyword], [plural keyword]
+# SYNTAX:
+# Topic Type: [name]
+# Alter Topic Type: [name]
+#    Creates a new topic type or alters one from the main file.  Each type gets
+#    its own index and behavior settings.  Its name can have letters, numbers,
+#    spaces, and these charaters: - / . '
+# Plural: [name]
+#    Sets the plural name of the topic type, if different.
+# Keywords:
+#    [keyword]
+#    Defines or adds to the list of keywords for the topic type.  They may only
+#    contain letters, numbers, and spaces and are not case sensitive.  Plural
+#    keywords are used for list topics.  You can redefine keywords found in the
+#    main topics file.
+# Index: [yes|no]
+#    Whether the topics get their own index.  Defaults to yes.  Everything is
+#    included in the general index regardless of this setting.
+# Scope: [normal|start|end|always global]
+#    How the topics affects scope.  Defaults to normal.
+#    normal        - Topics stay within the current scope.
+#    start         - Topics start a new scope for all the topics beneath it,
+#                    like class topics.
+#    end           - Topics reset the scope back to global for all the topics
+#                    beneath it.
+#    always global - Topics are defined as global, but do not change the scope
+#                    for any other topics.
+# Class Hierarchy: [yes|no]
+#    Whether the topics are part of the class hierarchy.  Defaults to no.
+# Page Title If First: [yes|no]
+#    Whether the topic's title becomes the page title if it's the first one in
+#    a file.  Defaults to no.
+# Break Lists: [yes|no]
+#    Whether list topics should be broken into individual topics in the output.
+#    Defaults to no.
+# Can Group With: [type], [type], ...
+#    Defines a list of topic types that this one can possibly be grouped with.
+#    Defaults to none.
+# The following topics are defined in the main file, if you'd like to alter
+# their behavior or add keywords:
+#    Generic, Class, Interface, Section, File, Group, Function, Variable,
+#    Property, Type, Constant, Enumeration, Event, Delegate, Macro,
+#    Database, Database Table, Database View, Database Index, Database
+#    Cursor, Database Trigger, Cookie, Build Target
+# If you add something that you think would be useful to other developers
+# topics [at] naturaldocs [dot] org.
More information about the fusion-commits mailing list
