[fusion-commits] r2597 - in sandbox/ol212: layers/Generic lib
svn_fusion at osgeo.org
Mon Sep 17 01:55:10 PDT 2012
Author: jng
Date: 2012-09-17 01:55:09 -0700 (Mon, 17 Sep 2012)
New Revision: 2597
sandbox/ol212/layers/Generic/Generic.js
sandbox/ol212/lib/Map.js
Add support for client-side stretching of tiled layers (made possible with client-zoom support in OpenLayers 2.12). This will only happen if all the tiled layers in question inherit from OpenLayers.Layer.Grid. If there is a single, non-Grid layer present (eg. Google) this trick will not work.
Modified: sandbox/ol212/layers/Generic/Generic.js
--- sandbox/ol212/layers/Generic/Generic.js 2012-09-17 07:51:38 UTC (rev 2596)
+++ sandbox/ol212/layers/Generic/Generic.js 2012-09-17 08:55:09 UTC (rev 2597)
@@ -199,10 +199,10 @@
else {
this.oLayerOL = new OpenLayers.Layer[this.layerType](this.getMapName(), this.mapTag.layerOptions );
+ //fractionalZoom not permitted with tiled base layers regardless
+ this.mapWidget.fractionalZoom = false;
+ this.mapWidget.oMapOL.setOptions({fractionalZoom: false});
- //fractionalZoom not permitted with tiled base layers regardless
- this.mapWidget.fractionalZoom = false;
- this.mapWidget.oMapOL.setOptions({fractionalZoom: false});
Modified: sandbox/ol212/lib/Map.js
--- sandbox/ol212/lib/Map.js 2012-09-17 07:51:38 UTC (rev 2596)
+++ sandbox/ol212/lib/Map.js 2012-09-17 08:55:09 UTC (rev 2597)
@@ -409,6 +409,42 @@
if (this.aMaps.length == 1) {
this.oMapOL.setBaseLayer(this.aMaps[0].oLayerOL);
+ if (this.fractionalZoom) {
+ var newResolutions = null;
+ var mgResolutions = null;
+ for (var i = 0; i < this.aMaps.length; i++) {
+ if (this.aMaps[i].arch == 'MapGuide') {
+ mgResolutions = this.aMaps[i].oLayerOL.resolutions;
+ if (this.aMaps[i].arch == 'Generic') {
+ var oLayer = this.aMaps[i].oLayerOL;
+ oLayer.serverResolutions = oLayer.resolutions;
+ if (newResolutions == null) {
+ newResolutions = [];
+ for (var j = 0; j < oLayer.serverResolutions.length; j++) {
+ newResolutions.push(oLayer.serverResolutions[j]);
+ for (var j = 0; j < mgResolutions.length; j++) {
+ if (mgResolutions[j] < oLayer.minResolution) {
+ newResolutions.push(mgResolutions[j]);
+ oLayer.resolutions = newResolutions;
+ var newScales = [];
+ for (var i = 0; i < newResolutions.length; i++) {
+ newScales.push(OpenLayers.Util.getScaleFromResolution(newResolutions[i], oLayer.units));
+ oLayer.scales = newScales;
+ oLayer.minResolution = newResolutions[newResolutions.length - 1];
+ oLayer.maxScale = newScales[newScales.length - 1];
+ oLayer.numZoomLevels = newScales.length;
var initialExtent = this.setInitialExtents();
this.setExtents(initialExtent);
More information about the fusion-commits
