[fusion-commits] r2606 - sandbox/ol212/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Sep 19 22:03:11 PDT 2012
Author: jng
Date: 2012-09-19 22:03:11 -0700 (Wed, 19 Sep 2012)
New Revision: 2606
   sandbox/ol212/lib/Map.js
Add more notes about the client-zoom capabilities and refine the capability check. Only apply client-zoom if the MapGuide Map Definition has no tiled layers (we may remove this requirement in the future as we continue to explore the client-zoom possibilities in Fusion)
Modified: sandbox/ol212/lib/Map.js
--- sandbox/ol212/lib/Map.js	2012-09-19 09:46:11 UTC (rev 2605)
+++ sandbox/ol212/lib/Map.js	2012-09-20 05:03:11 UTC (rev 2606)
@@ -168,7 +168,7 @@
     /** flag to indicate if fractional zoom is supported, ie. allow any scale
     *   value rather than a fixed set of scales
-    fractionalZoom: false,
+    fractionalZoom: true,
     /** The DOM object that holds the map */
     maxScale: null, //set this to a large number in AppDef to zoom out beyond maxExtent, e.g. 1 billion
@@ -410,25 +410,26 @@
         this.oMapOL.setBaseLayer(this.aMaps[0].oLayerOL);
-      //Take advantage of new client-zoom capabilities introduced in OpenLayers 2.12
+      // Take advantage of new client-zoom capabilities introduced in OpenLayers 2.12
-      //What we do here is for every grid-based commerical layer, we tack on extra resolutions
-      //of the MapGuide OL Layer that is below the minimum supported resolution of the commercial
-      //layers. The existing resolutions array is shifted to the layer's serverResolutions array.
+      // What we do here is for every grid-based commerical layer, we tack on extra resolutions
+      // of the MapGuide OL Layer that is below the minimum supported resolution of the commercial
+      // layers. The existing resolutions array is shifted to the layer's serverResolutions array.
-      //When we go below the minimum supported resolution of these commercial layers,
-      //client-zoom kicks in and stretches the commerical layers appropriately.
+      // When we go below the minimum supported resolution of these commercial layers,
+      // client-zoom kicks in and stretches the commerical layers appropriately.
-      //A small side-effect is that if fractionalZoom = true, and the layer setup is such that
-      //this won't be set to false during initialization (eg. fractionalZoom = true +
-      //A MapGuide dynamic map + OSM layers), then the OSM layers will almost always be slightly
-      //stretched, as any zoom scale is allowed and OL will be stretching the OSM layers to match.
+      // A small side-effect is that if fractionalZoom = true, and the layer setup is such that
+      // this won't be set to false during initialization (eg. fractionalZoom = true +
+      // A MapGuide dynamic map + OSM layers), then the OSM layers will almost always be slightly
+      // stretched, as any zoom scale is allowed and OL will be stretching the OSM layers to match.
-      //This technique does not work with Google layers (as they aren't grid-based). The mere presence
-      //of Google layers (or any non-Grid layers) will disable client-zoom, and your map will be snapping
-      //to whatever discrete scale list that is imposed by the commercial layer
+      // This technique does not work with Google layers (as they aren't grid-based). The mere presence
+      // of Google layers (or any non-Grid layers) will disable client-zoom if a non-Grid layer is the active
+      // one, and your map will be snapping to whatever discrete scale list that is imposed by the commercial layer
-      //With these changes the behaviour is like so (OSM is interchangeable with any other grid-based layer):
+      // With these changes the behaviour is like so (OSM is interchangeable with any other grid-based layer, MapGuide
+      // is assumed to be fully dynamic and have no tiled layers):
       // - MapGuide + OSM (fractionalZoom = true): Fully dynamic map and OSM tiles are stretched accordingly. OSM
       //                                           tiles will most likely never be un-stretched due to the fully dynamic
@@ -439,40 +440,58 @@
       //                                         list are disregarded). OSM tiles are stretched accordingly when
       //                                         going below the minimum supported OSM scale
-      //TODO: Yet to observe this behaviour with tiled MG maps or maps with tiled/untiled mixtures
+      // MapGuide Map Definitions with tiled layers cannot take advantage of client-zoom (at least to my knowledge and for
+      // this initial implementation).
+      // So the same rules apply for MG tiled map integration: It must use the same scale list as Google + Bing + OSM.
+      // TODO: In the case of a mixed MG Map Definition and no CMS layers, investigate the possibility of using client-zoom
+      // so that MG tiled layers can be stretched.
       var newResolutions = null;
       var mgResolutions = null;
+      var bCanUseClientZoom = true;
       for (var i = 0; i < this.aMaps.length; i++) {
           if (this.aMaps[i].arch == 'MapGuide') {
               mgResolutions = this.aMaps[i].oLayerOL.resolutions;
-      for (var i = 0; i < this.aMaps.length; i++) {
-          if (this.aMaps[i].arch == 'Generic') {
-              var oLayer = this.aMaps[i].oLayerOL;
-              oLayer.serverResolutions = oLayer.resolutions;
-              if (newResolutions == null) {
-                  newResolutions = [];
-                  for (var j = 0; j < oLayer.serverResolutions.length; j++) {
-                      newResolutions.push(oLayer.serverResolutions[j]);
-                  for (var j = 0; j < mgResolutions.length; j++) {
-                      if (mgResolutions[j] < oLayer.minResolution) {
-                          newResolutions.push(mgResolutions[j]);
+              if (this.aMaps[i].bSingleTile) {
+                bCanUseClientZoom = true;
+              } else {
+                //TODO: How smart can we be to make this be true?
+                bCanUseClientZoom = false;
-              oLayer.resolutions = newResolutions;
-              var newScales = [];
-              for (var i = 0; i < newResolutions.length; i++) {
-                  newScales.push(OpenLayers.Util.getScaleFromResolution(newResolutions[i], oLayer.units));
-              oLayer.scales = newScales;
-              oLayer.minResolution = newResolutions[newResolutions.length - 1];
-              oLayer.maxScale = newScales[newScales.length - 1];
-              oLayer.numZoomLevels = newScales.length;
+              break;
+      //console.log("Can use client-zoom: " + bCanUseClientZoom);
+      if (bCanUseClientZoom) {
+        for (var i = 0; i < this.aMaps.length; i++) {
+            if (this.aMaps[i].arch == 'Generic') {
+                var oLayer = this.aMaps[i].oLayerOL;
+                oLayer.serverResolutions = oLayer.resolutions;
+                if (newResolutions == null) {
+                    newResolutions = [];
+                    for (var j = 0; j < oLayer.serverResolutions.length; j++) {
+                        newResolutions.push(oLayer.serverResolutions[j]);
+                    for (var j = 0; j < mgResolutions.length; j++) {
+                        if (mgResolutions[j] < oLayer.minResolution) {
+                            newResolutions.push(mgResolutions[j]);
+                oLayer.resolutions = newResolutions;
+                var newScales = [];
+                for (var i = 0; i < newResolutions.length; i++) {
+                    newScales.push(OpenLayers.Util.getScaleFromResolution(newResolutions[i], oLayer.units));
+                oLayer.scales = newScales;
+                oLayer.minResolution = newResolutions[newResolutions.length - 1];
+                oLayer.maxScale = newScales[newScales.length - 1];
+                oLayer.numZoomLevels = newScales.length;
       var initialExtent = this.setInitialExtents();
       this.setExtents(initialExtent);
More information about the fusion-commits mailing list
