[fusion-commits] r2613 - in sandbox/ol212: . lib lib/OpenLayers
svn_fusion at osgeo.org
Wed Sep 26 00:55:44 PDT 2012
Author: jng
Date: 2012-09-26 00:55:44 -0700 (Wed, 26 Sep 2012)
New Revision: 2613
sandbox/ol212/fusion.cfg
sandbox/ol212/lib/Map.js
sandbox/ol212/lib/OpenLayers/OpenLayers.js
Add TouchNavigation to our custom OpenLayers build profile so the Fusion experience is service-able for touch-based tablets.
Modified: sandbox/ol212/fusion.cfg
--- sandbox/ol212/fusion.cfg 2012-09-20 09:34:10 UTC (rev 2612)
+++ sandbox/ol212/fusion.cfg 2012-09-26 07:55:44 UTC (rev 2613)
@@ -36,6 +36,7 @@
OpenLayers/Control/Measure.js
OpenLayers/Control/ScaleLine.js
OpenLayers/Control/MousePosition.js
+OpenLayers/Control/TouchNavigation.js
OpenLayers/Filter.js
OpenLayers/Filter/FeatureId.js
OpenLayers/Filter/Spatial.js
Modified: sandbox/ol212/lib/Map.js
--- sandbox/ol212/lib/Map.js 2012-09-20 09:34:10 UTC (rev 2612)
+++ sandbox/ol212/lib/Map.js 2012-09-26 07:55:44 UTC (rev 2613)
@@ -230,7 +230,7 @@
OpenLayers.DOTS_PER_INCH = this._nDpi;
if (!this.oMapOL) {
var options = {
- controls: [],
+ controls: [ new OpenLayers.Control.TouchNavigation() ],
fallThrough: true,
scales: scalesArray,
fractionalZoom: this.fractionalZoom
Modified: sandbox/ol212/lib/OpenLayers/OpenLayers.js
--- sandbox/ol212/lib/OpenLayers/OpenLayers.js 2012-09-20 09:34:10 UTC (rev 2612)
+++ sandbox/ol212/lib/OpenLayers/OpenLayers.js 2012-09-26 07:55:44 UTC (rev 2613)
@@ -42512,6 +42512,240 @@
CLASS_NAME: "OpenLayers.Rule"
+ OpenLayers/Handler/Pinch.js
+/* Copyright (c) 2006-2012 by OpenLayers Contributors (see authors.txt for
+ * full list of contributors). Published under the 2-clause BSD license.
+ * See license.txt in the OpenLayers distribution or repository for the
+ * full text of the license. */
+ * @requires OpenLayers/Handler.js
+ * Class: OpenLayers.Handler.Pinch
+ * The pinch handler is used to deal with sequences of browser events related
+ * to pinch gestures. The handler is used by controls that want to know
+ * when a pinch sequence begins, when a pinch is happening, and when it has
+ * finished.
+ * Controls that use the pinch handler typically construct it with callbacks
+ * for 'start', 'move', and 'done'. Callbacks for these keys are
+ * called when the pinch begins, with each change, and when the pinch is
+ * done.
+ * Create a new pinch handler with the <OpenLayers.Handler.Pinch> constructor.
+ * Inherits from:
+ * - <OpenLayers.Handler>
+OpenLayers.Handler.Pinch = OpenLayers.Class(OpenLayers.Handler, {
+ * Property: started
+ * {Boolean} When a touchstart event is received, we want to record it,
+ * but not set 'pinching' until the touchmove get started after
+ * starting.
+ started: false,
+ * Property: stopDown
+ * {Boolean} Stop propagation of touchstart events from getting to
+ * listeners on the same element. Default is false.
+ stopDown: false,
+ * Property: pinching
+ * {Boolean}
+ pinching: false,
+ * Property: last
+ * {Object} Object that store informations related to pinch last touch.
+ last: null,
+ * Property: start
+ * {Object} Object that store informations related to pinch touchstart.
+ start: null,
+ * Constructor: OpenLayers.Handler.Pinch
+ * Returns OpenLayers.Handler.Pinch
+ * Parameters:
+ * control - {<OpenLayers.Control>} The control that is making use of
+ * this handler. If a handler is being used without a control, the
+ * handlers setMap method must be overridden to deal properly with
+ * the map.
+ * callbacks - {Object} An object containing functions to be called when
+ * the pinch operation start, change, or is finished. The callbacks
+ * should expect to receive an object argument, which contains
+ * information about scale, distance, and position of touch points.
+ * options - {Object}
+ * Method: touchstart
+ * Handle touchstart events
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ * {Boolean} Let the event propagate.
+ touchstart: function(evt) {
+ var propagate = true;
+ this.pinching = false;
+ if (OpenLayers.Event.isMultiTouch(evt)) {
+ this.started = true;
+ this.last = this.start = {
+ distance: this.getDistance(evt.touches),
+ delta: 0,
+ scale: 1
+ this.callback("start", [evt, this.start]);
+ propagate = !this.stopDown;
+ } else {
+ this.started = false;
+ this.start = null;
+ this.last = null;
+ // prevent document dragging
+ OpenLayers.Event.stop(evt);
+ return propagate;
+ * Method: touchmove
+ * Handle touchmove events
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ touchmove: function(evt) {
+ if (this.started && OpenLayers.Event.isMultiTouch(evt)) {
+ this.pinching = true;
+ var current = this.getPinchData(evt);
+ this.callback("move", [evt, current]);
+ this.last = current;
+ return true;
+ * Method: touchend
+ * Handle touchend events
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ touchend: function(evt) {
+ if (this.started) {
+ this.callback("done", [evt, this.start, this.last]);
+ this.last = null;
+ return true;
+ * Method: activate
+ * Activate the handler.
+ * Returns:
+ * {Boolean} The handler was successfully activated.
+ activate: function() {
+ var activated = false;
+ if (OpenLayers.Handler.prototype.activate.apply(this, arguments)) {
+ activated = true;
+ return activated;
+ * Method: deactivate
+ * Deactivate the handler.
+ * Returns:
+ * {Boolean} The handler was successfully deactivated.
+ deactivate: function() {
+ var deactivated = false;
+ if (OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
+ this.last = null;
+ deactivated = true;
+ return deactivated;
+ * Method: getDistance
+ * Get the distance in pixels between two touches.
+ * Parameters:
+ * touches - {Array(Object)}
+ * Returns:
+ * {Number} The distance in pixels.
+ getDistance: function(touches) {
+ var t0 = touches[0];
+ var t1 = touches[1];
+ return Math.sqrt(
+ Math.pow(t0.clientX - t1.clientX, 2) +
+ Math.pow(t0.clientY - t1.clientY, 2)
+ * Method: getPinchData
+ * Get informations about the pinch event.
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ * {Object} Object that contains data about the current pinch.
+ getPinchData: function(evt) {
+ var distance = this.getDistance(evt.touches);
+ var scale = distance / this.start.distance;
+ return {
+ distance: distance,
+ delta: this.last.distance - distance,
+ scale: scale
+ CLASS_NAME: "OpenLayers.Handler.Pinch"
OpenLayers/Handler/Hover.js
@@ -44844,6 +45078,404 @@
CLASS_NAME: 'OpenLayers.Control.OverviewMap'
+ OpenLayers/Control/PinchZoom.js
+ * @requires OpenLayers/Handler/Pinch.js
+ * Class: OpenLayers.Control.PinchZoom
+ * Inherits:
+ * - <OpenLayers.Control>
+OpenLayers.Control.PinchZoom = OpenLayers.Class(OpenLayers.Control, {
+ * Property: type
+ * {OpenLayers.Control.TYPES}
+ type: OpenLayers.Control.TYPE_TOOL,
+ * Property: containerCenter
+ * {Object} Cached object representing the layer container center (in pixels).
+ containerCenter: null,
+ * Property: pinchOrigin
+ * {Object} Cached object representing the pinch start (in pixels).
+ pinchOrigin: null,
+ * Property: currentCenter
+ * {Object} Cached object representing the latest pinch center (in pixels).
+ currentCenter: null,
+ * APIProperty: autoActivate
+ * {Boolean} Activate the control when it is added to a map. Default is
+ * true.
+ autoActivate: true,
+ * Constructor: OpenLayers.Control.PinchZoom
+ * Create a control for zooming with pinch gestures. This works on devices
+ * with multi-touch support.
+ * Parameters:
+ * options - {Object} An optional object whose properties will be set on
+ * the control
+ initialize: function(options) {
+ OpenLayers.Control.prototype.initialize.apply(this, arguments);
+ this.handler = new OpenLayers.Handler.Pinch(this, {
+ start: this.pinchStart,
+ move: this.pinchMove,
+ done: this.pinchDone
+ }, this.handlerOptions);
+ * APIMethod: activate
+ * Activate this control. Must be called after the control is added to a
+ * map.
+ * Returns:
+ * {Boolean} The control was successfully activated.
+ var activated = OpenLayers.Control.prototype.activate.apply(this,arguments);
+ if (activated) {
+ this.map.events.on({
+ moveend: this.updateContainerCenter,
+ scope: this
+ this.updateContainerCenter();
+ return activated;
+ * APIMethod: deactivate
+ * Deactivate this control.
+ * Returns:
+ * {Boolean} The control was successfully deactivated.
+ var deactivated = OpenLayers.Control.prototype.deactivate.apply(this,arguments);
+ if (this.map && this.map.events) {
+ this.map.events.un({
+ scope: this
+ * Method: updateContainerCenter
+ * Must be called each time the layer container moves.
+ updateContainerCenter: function() {
+ var container = this.map.layerContainerDiv;
+ // the layer container div is a square of 100px/100px
+ this.containerCenter = {
+ x: parseInt(container.style.left, 10) + 50,
+ y: parseInt(container.style.top, 10) + 50
+ * Method: pinchStart
+ * Parameters:
+ * evt - {Event}
+ * pinchData - {Object} pinch data object related to the current touchmove
+ * of the pinch gesture. This give us the current scale of the pinch.
+ pinchStart: function(evt, pinchData) {
+ this.pinchOrigin = evt.xy;
+ this.currentCenter = evt.xy;
+ * Method: pinchMove
+ * Parameters:
+ * evt - {Event}
+ pinchMove: function(evt, pinchData) {
+ var scale = pinchData.scale;
+ var containerCenter = this.containerCenter;
+ var pinchOrigin = this.pinchOrigin;
+ var current = evt.xy;
+ var dx = Math.round((current.x - pinchOrigin.x) + (scale - 1) * (containerCenter.x - pinchOrigin.x));
+ var dy = Math.round((current.y - pinchOrigin.y) + (scale - 1) * (containerCenter.y - pinchOrigin.y));
+ this.applyTransform(
+ "translate(" + dx + "px, " + dy + "px) scale(" + scale + ")"
+ this.currentCenter = current;
+ * Method: applyTransform
+ * Applies the given transform to layers.
+ applyTransform: function(transform) {
+ var style = this.map.layerContainerDiv.style;
+ style['-webkit-transform'] = transform;
+ style['-moz-transform'] = transform;
+ * Method: pinchDone
+ * Parameters:
+ * evt - {Event}
+ * start - {Object} pinch data object related to the touchstart event that
+ * started the pinch gesture.
+ * last - {Object} pinch data object related to the last touchmove event
+ * of the pinch gesture. This give us the final scale of the pinch.
+ pinchDone: function(evt, start, last) {
+ this.applyTransform("");
+ var zoom = this.map.getZoomForResolution(this.map.getResolution() / last.scale, true);
+ if (zoom !== this.map.getZoom() || !this.currentCenter.equals(this.pinchOrigin)) {
+ var resolution = this.map.getResolutionForZoom(zoom);
+ var location = this.map.getLonLatFromPixel(this.pinchOrigin);
+ var zoomPixel = this.currentCenter;
+ var size = this.map.getSize();
+ location.lon += resolution * ((size.w / 2) - zoomPixel.x);
+ location.lat -= resolution * ((size.h / 2) - zoomPixel.y);
+ // Force a reflow before calling setCenter. This is to work
+ // around an issue occuring in iOS.
+ // See https://github.com/openlayers/openlayers/pull/351.
+ // Without a reflow setting the layer container div's top left
+ // style properties to "0px" - as done in Map.moveTo when zoom
+ // is changed - won't actually correctly reposition the layer
+ // container div.
+ // Also, we need to use a statement that the Google Closure
+ // compiler won't optimize away.
+ this.map.div.clientWidth = this.map.div.clientWidth;
+ this.map.setCenter(location, zoom);
+ CLASS_NAME: "OpenLayers.Control.PinchZoom"
+ OpenLayers/Control/TouchNavigation.js
+ * @requires OpenLayers/Control/DragPan.js
+ * @requires OpenLayers/Control/PinchZoom.js
+ * @requires OpenLayers/Handler/Click.js
+ * Class: OpenLayers.Control.TouchNavigation
+ * The navigation control handles map browsing with touch events (dragging,
+ * double-tapping, tap with two fingers, and pinch zoom). Create a new
+ * control with the <OpenLayers.Control.TouchNavigation> constructor.
+ * If you’re only targeting touch enabled devices with your mapping application,
+ * you can create a map with only a TouchNavigation control. The
+ * <OpenLayers.Control.Navigation> control is mobile ready by default, but
+ * you can generate a smaller build of the library by only including this
+ * touch navigation control if you aren't concerned about mouse interaction.
+ * Inherits:
+OpenLayers.Control.TouchNavigation = OpenLayers.Class(OpenLayers.Control, {
+ * Property: dragPan
+ * {<OpenLayers.Control.DragPan>}
+ dragPan: null,
+ * APIProperty: dragPanOptions
+ * {Object} Options passed to the DragPan control.
+ dragPanOptions: null,
+ * Property: pinchZoom
+ * {<OpenLayers.Control.PinchZoom>}
+ pinchZoom: null,
+ * APIProperty: pinchZoomOptions
+ * {Object} Options passed to the PinchZoom control.
+ pinchZoomOptions: null,
+ * APIProperty: clickHandlerOptions
+ * {Object} Options passed to the Click handler.
+ clickHandlerOptions: null,
+ * APIProperty: documentDrag
+ * {Boolean} Allow panning of the map by dragging outside map viewport.
+ * Default is false.
+ documentDrag: false,
+ * true.
+ * Constructor: OpenLayers.Control.TouchNavigation
+ * Create a new navigation control
+ * Parameters:
+ * the control
+ this.handlers = {};
+ * Method: destroy
+ * The destroy method is used to perform any clean up before the control
+ * is dereferenced. Typically this is where event listeners are removed
+ * to prevent memory leaks.
+ destroy: function() {
+ this.deactivate();
+ if(this.dragPan) {
+ this.dragPan.destroy();
+ this.dragPan = null;
+ if (this.pinchZoom) {
+ this.pinchZoom.destroy();
+ delete this.pinchZoom;
+ OpenLayers.Control.prototype.destroy.apply(this,arguments);
+ if(OpenLayers.Control.prototype.activate.apply(this,arguments)) {
+ this.dragPan.activate();
+ this.handlers.click.activate();
+ this.pinchZoom.activate();
+ return true;
+ return false;
+ if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)) {
+ this.dragPan.deactivate();
+ this.handlers.click.deactivate();
+ this.pinchZoom.deactivate();
+ return true;
+ return false;
+ * Method: draw
+ draw: function() {
+ var clickCallbacks = {
+ click: this.defaultClick,
+ dblclick: this.defaultDblClick
+ var clickOptions = OpenLayers.Util.extend({
+ "double": true,
+ stopDouble: true,
+ pixelTolerance: 2
+ }, this.clickHandlerOptions);
+ this.handlers.click = new OpenLayers.Handler.Click(
+ this, clickCallbacks, clickOptions
+ this.dragPan = new OpenLayers.Control.DragPan(
+ OpenLayers.Util.extend({
+ map: this.map,
+ documentDrag: this.documentDrag
+ }, this.dragPanOptions)
+ this.dragPan.draw();
+ this.pinchZoom = new OpenLayers.Control.PinchZoom(
+ OpenLayers.Util.extend({map: this.map}, this.pinchZoomOptions)
+ * Method: defaultClick
+ * Parameters:
+ * evt - {Event}
+ defaultClick: function (evt) {
+ if(evt.lastTouches && evt.lastTouches.length == 2) {
+ this.map.zoomOut();
+ * Method: defaultDblClick
+ * Parameters:
+ * evt - {Event}
+ defaultDblClick: function (evt) {
+ var newCenter = this.map.getLonLatFromViewPortPx(evt.xy);
+ this.map.setCenter(newCenter, this.map.zoom + 1);
+ CLASS_NAME: "OpenLayers.Control.TouchNavigation"
OpenLayers/Format/WFSCapabilities/v1_0_0.js
More information about the fusion-commits
