[fusion-commits] r2688 - trunk/layers/MapGuide
svn_fusion at osgeo.org
Sun Apr 14 18:09:09 PDT 2013
Author: liuar
Date: 2013-04-14 18:09:09 -0700 (Sun, 14 Apr 2013)
New Revision: 2688
trunk/layers/MapGuide/MapGuide.js
Submit on behalf of Andy Zhang. Enhancement of MapGuide Ticket#434.
http://trac.osgeo.org/fusion/ticket/434
There is a case that the wkt string is invalid or outdated. The property wktProj.proj.readyToUse is false in this case. We need to check the value of readyToUse after wktProj object is constructed.
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2013-04-05 11:54:47 UTC (rev 2687)
+++ trunk/layers/MapGuide/MapGuide.js 2013-04-15 01:09:09 UTC (rev 2688)
@@ -333,12 +333,15 @@
var wktProj;
if (o.wkt && o.wkt.length > 0){
wktProj = new OpenLayers.Projection(o.wkt);
- } else if (o.epsg != 0) {
- this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
- } else {
- //default to the local non-projected system if not otherwise specified
- o.wkt = "LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
- wktProj = new OpenLayers.Projection(o.wkt);
+ if (!wktProj || (wktProj && wktProj.proj && !wktProj.proj.readyToUse)) {
+ if (o.epsg != 0) {
+ this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
+ } else {
+ //default to the local non-projected system if not otherwise specified
+ o.wkt = "LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
+ wktProj = new OpenLayers.Projection(o.wkt);
//TODO: consider passing the metersPerUnit value into the framework
//to allow for scaling that doesn't match any of the pre-canned units
@@ -383,7 +386,7 @@
this.oLayerOL = this.createOLLayer(this._sMapname, this.bSingleTile, 2, false, "");
- if (wktProj) {
+ if (wktProj && wktProj.proj && wktProj.proj.readyToUse) {
this.oLayerOL.projection = wktProj;
this.oLayerOL.projection.proj.units = this.mapTag.layerOptions.units;
More information about the fusion-commits
