[fusion-commits] r2763 - trunk/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Aug 6 19:12:41 PDT 2013
Author: liuar
Date: 2013-08-06 19:12:41 -0700 (Tue, 06 Aug 2013)
New Revision: 2763
   trunk/lib/Map.js
Submit on behalf of Andy Zhang.
Update zoom method to zoom up or down log2(nFactor) level with fixed scales
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2013-08-06 07:37:05 UTC (rev 2762)
+++ trunk/lib/Map.js	2013-08-07 02:12:41 UTC (rev 2763)
@@ -1243,7 +1243,7 @@
      *                  - if set to 0 or 1, the map is just recentered
      *                  - if the map has fractional zoom enabled, the map resolution
      *                  will be modified by this factor
-     *                  - with fixed scales, zoom up or down one level, depending on the sign
+     *                  - with fixed scales, zoom up or down log2(nFactor) level
      * Returns: none
@@ -1275,11 +1275,7 @@
             } else {
                 var currentZoomLevel = this.oMapOL.getZoom();
                 this.oMapOL.setCenter(new OpenLayers.LonLat(fX, fY));
-                if (nFactor > 1) {
-                    this.oMapOL.zoomTo(currentZoomLevel+1);
-                } else if (nFactor < 1) {
-                    this.oMapOL.zoomTo(currentZoomLevel-1);
+                this.oMapOL.zoomTo(currentZoomLevel + Math.floor(Math.log(nFactor) / Math.log(2)));
More information about the fusion-commits mailing list
