[fusion-commits] r2765 - in trunk/widgets: . widgetinfo
svn_fusion at osgeo.org
Thu Aug 8 23:49:50 PDT 2013
Author: jng
Date: 2013-08-08 23:49:50 -0700 (Thu, 08 Aug 2013)
New Revision: 2765
trunk/widgets/Maptip.js
trunk/widgets/widgetinfo/coordinatetracker.xml
trunk/widgets/widgetinfo/featureinfo.xml
trunk/widgets/widgetinfo/mapmenu.xml
trunk/widgets/widgetinfo/maptip.xml
#571: Update maptip and some widgetinfo xml files to use the imagestrip icon instead of the individual icon
Modified: trunk/widgets/Maptip.js
--- trunk/widgets/Maptip.js 2013-08-07 02:16:40 UTC (rev 2764)
+++ trunk/widgets/Maptip.js 2013-08-09 06:49:50 UTC (rev 2765)
@@ -142,7 +142,8 @@
this.mapTipBtn = new Jx.Button({
- image: Fusion.getApplicationURL() + 'images/maptip.png',
+ image: Fusion.getApplicationURL() + 'images/icons.png',
+ imageClass: "maptip",
label: this.label,
toggle: true,
onDown: (function() {
Modified: trunk/widgets/widgetinfo/coordinatetracker.xml
--- trunk/widgets/widgetinfo/coordinatetracker.xml 2013-08-07 02:16:40 UTC (rev 2764)
+++ trunk/widgets/widgetinfo/coordinatetracker.xml 2013-08-09 06:49:50 UTC (rev 2765)
@@ -6,7 +6,7 @@
<Label>Coordinate Tracker</Label>
<Tooltip>Click to view mouse coordinates in various projections</Tooltip>
<StatusText></StatusText>
- <ImageUrl>images/coordinate-tracker.png</ImageUrl>
+ <ImageUrl>images/icons.png</ImageUrl>
<ImageClass>coordinate-tracker</ImageClass>
<StandardUi>true</StandardUi>
<ContainableBy>Any</ContainableBy>
Modified: trunk/widgets/widgetinfo/featureinfo.xml
--- trunk/widgets/widgetinfo/featureinfo.xml 2013-08-07 02:16:40 UTC (rev 2764)
+++ trunk/widgets/widgetinfo/featureinfo.xml 2013-08-09 06:49:50 UTC (rev 2765)
@@ -6,7 +6,7 @@
<Label>Feature Info</Label>
<Tooltip>Click to display selected feature info</Tooltip>
- <ImageClass>featureinfo</ImageClass>
+ <ImageClass>feature-info</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/mapmenu.xml
--- trunk/widgets/widgetinfo/mapmenu.xml 2013-08-07 02:16:40 UTC (rev 2764)
+++ trunk/widgets/widgetinfo/mapmenu.xml 2013-08-09 06:49:50 UTC (rev 2765)
@@ -6,8 +6,8 @@
<Label>Maps</Label>
<Tooltip>Choose a map theme</Tooltip>
- <ImageUrl></ImageUrl>
- <ImageClass></ImageClass>
+ <ImageClass>legend-map</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/maptip.xml
--- trunk/widgets/widgetinfo/maptip.xml 2013-08-07 02:16:40 UTC (rev 2764)
+++ trunk/widgets/widgetinfo/maptip.xml 2013-08-09 06:49:50 UTC (rev 2765)
@@ -6,8 +6,8 @@
<Label>Maptip</Label>
<Tooltip>Click to Enable/Disable get information about features from Server</Tooltip>
- <ImageUrl>images/maptip.png</ImageUrl>
- <ImageClass>Maptip</ImageClass>
+ <ImageClass>maptip</ImageClass>
<Parameter>
More information about the fusion-commits
