[fusion-commits] r2771 - in trunk: text widgets
svn_fusion at osgeo.org
Tue Aug 27 05:22:40 PDT 2013
Author: jng
Date: 2013-08-27 05:22:39 -0700 (Tue, 27 Aug 2013)
New Revision: 2771
trunk/text/en.json
trunk/widgets/Geolocation.js
#579: Geolocation widget improvements:
- Use the MapMessage for relaying geolocation errors
- Cache the OpenLayers.Projection for the geolocation position
- MapMessage warn when the resolved location falls outside the extents or initial view of the map
Modified: trunk/text/en.json
--- trunk/text/en.json 2013-08-27 11:40:25 UTC (rev 2770)
+++ trunk/text/en.json 2013-08-27 12:22:39 UTC (rev 2771)
@@ -82,6 +82,8 @@
'openStreetMapTransportMap':'Open Street Map (TransportMap)',
'openStreetMapCycleMap':'Open Street Map (CycleMap)',
'end': '',
+'currentPositionOutsideInitialView': 'Your position is outside of the initial view of the map',
+'currentPositionOutsideMaxExtent': 'Your position is outside of the maximum extent of the map',
'measureInProgress':'Measurement is currently in progress',
'selectPolygonPrompt':'Click to add a vertex to the selection polygon. Double click to complete the polygon and select all features with it',
'selectRadiusPrompt':'Click and drag to the desired radius to select'
Modified: trunk/widgets/Geolocation.js
--- trunk/widgets/Geolocation.js 2013-08-27 11:40:25 UTC (rev 2770)
+++ trunk/widgets/Geolocation.js 2013-08-27 12:22:39 UTC (rev 2771)
@@ -39,6 +39,7 @@
bEnableHighAccuracy: false,
nTimeout: 5000,
nMaximumAge: 0,
+ geoProj: null,
initializeWidget: function(widgetTag) {
var json = widgetTag.extension;
@@ -62,11 +63,11 @@
//Maybe use MapMessage for non-intrusive error display?
switch(error.code) {
case 1: //Permission denied
- alert(error.message);
+ this.getMap().message.error(error.message);
case 2: //Position unavailable
case 3: //Timeout
default:
console.error("Error with geolocation: (" + error.code + ") " + error.message);
@@ -76,12 +77,25 @@
var mapWidget = this.getMap();
var olMap = mapWidget.oMapOL;
- var geoProj = new OpenLayers.Projection("EPSG:4326");
+ if (this.geoProj == null)
+ this.geoProj = new OpenLayers.Projection("EPSG:4326");
var mapProj = olMap.projection;
var lonlat = new OpenLayers.LonLat(pos.coords.longitude, pos.coords.latitude);
- lonlat.transform(geoProj, mapProj);
+ lonlat.transform(this.geoProj, mapProj);
+ var msg = null;
+ if (!mapWidget.initialExtents.contains(lonlat)) {
+ msg = OpenLayers.i18n("currentPositionOutsideInitialView");
+ } else if (!olMap.maxExtent.contains(lonlat)) {
+ msg = OpenLayers.i18n("currentPositionOutsideMaxExtent");
+ if (msg != null) {
+ var msgbar = this.getMap().message;
+ msgbar.warn(msg);
+ setTimeout(function() { msgbar.hideDesignatedMessage(msg); }, 5000);
if (this.nZoom == null) {
olMap.moveTo(lonlat);
} else {
More information about the fusion-commits
