[fusion-commits] r2647 - trunk/widgets/Redline
svn_fusion at osgeo.org
Sun Feb 24 22:25:05 PST 2013
Author: ChristineBao
Date: 2013-02-24 22:25:05 -0800 (Sun, 24 Feb 2013)
New Revision: 2647
trunk/widgets/Redline/markupmain.php
Fix "Linux: Redline doesn't work on linux server". The path for Linux is case-sensitive.
Modified: trunk/widgets/Redline/markupmain.php
--- trunk/widgets/Redline/markupmain.php 2013-02-25 06:19:51 UTC (rev 2646)
+++ trunk/widgets/Redline/markupmain.php 2013-02-25 06:25:05 UTC (rev 2647)
@@ -130,7 +130,7 @@
if (cmd == CMD_NEW) {
var widget = Fusion.getWidgetsByType("Redline")[0];
if (widget.autogenerateLayerNames) {
- Fusion.ajaxRequest("widgets/redline/newmarkup.php", {
+ Fusion.ajaxRequest("widgets/Redline/newmarkup.php", {
onSuccess: OpenLayers.Function.bind(OnMarkupCreated, this),
onFailure: OpenLayers.Function.bind(OnMarkupCreateFailure, this),
parameters: {
@@ -140,7 +140,7 @@
} else {
var name = prompt("<?= $redlineLayerNameLocal ?>");
parameters: {
More information about the fusion-commits
