[fusion-commits] r2755 - in trunk: layers/MapGuide widgets
svn_fusion at osgeo.org
Wed Jul 31 18:23:36 PDT 2013
Author: liuar
Date: 2013-07-31 18:23:36 -0700 (Wed, 31 Jul 2013)
New Revision: 2755
trunk/layers/MapGuide/MapGuide.js
trunk/widgets/Legend.js
Fix MGOS ticket #2329: Legend is not correctly displayed.
This submission fixed the legend issue of flexible web layout.
1. The field layer.layerTypes doesn't indicate the layer is a DWF or Raster layer any more. We cannot set legend icon according to the value.
2. For layers which doesn't have scale ranges (e.g. drawing layer), we need add a dummy scale range for it. Otherwise, the legend tree will not display correctly.
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2013-07-30 01:19:01 UTC (rev 2754)
+++ trunk/layers/MapGuide/MapGuide.js 2013-08-01 01:23:36 UTC (rev 2755)
@@ -423,8 +423,17 @@
clsr.scaleRanges.push(csr);
+ } else {
+ //For a drawing layer which doesn't have scale ranges, we need add a dummy scale range for it.
+ //Otherwise, the legend tree will not display correctly.
+ minScale = 0;
+ maxScale = 1.0e10;
+ clsr.scaleRanges.push(new Fusion.Layers.ScaleRange({
+ minScale: 0,
+ maxScale: 1.0e10},
+ Fusion.Constant.LAYER_DWF_TYPE, {label:lyr.layerName}));
for (var lt in ltypes)
cl.layerTypes.push(lt);
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js 2013-07-30 01:19:01 UTC (rev 2754)
+++ trunk/widgets/Legend.js 2013-08-01 01:23:36 UTC (rev 2755)
@@ -825,18 +825,7 @@
opt.image = layer.oMap.getLegendImageURL(scale, layer, style);
- // MapGuide DWF and Raster layer
- // MapGuide Raster and DWF layer
- if(layer.layerTypes[0] == 4){
- opt.image = this.imgLayerRasterIcon;
- opt.enabled = true;
- } else if(layer.layerTypes[0] == 5){
- opt.image = this.imgLayerDWFIcon;
var item;
if (!layer.isBaseMapLayer&&checkbox) {
// opt.contextMenu = this.getContextMenu();
More information about the fusion-commits
