[fusion-commits] r2730 - trunk/text
    svn_fusion at osgeo.org
    Mon Jun  3 22:17:38 PDT 2013
Author: jng
Date: 2013-06-03 22:17:37 -0700 (Mon, 03 Jun 2013)
New Revision: 2730
   trunk/text/en
#574: Typo
Modified: trunk/text/en
--- trunk/text/en	2013-06-04 05:15:38 UTC (rev 2729)
+++ trunk/text/en	2013-06-04 05:17:37 UTC (rev 2730)
@@ -316,7 +316,7 @@
 REDLINEEDITLINESTRINGHELP = Click the map to define each point of the line, Double Click on the final point to end.
 REDLINEEDITRECTANGLEHELP = Click on the map to specify the first corner and drag the mouse to define the rectangle.
 REDLINEEDITPOLYGONHELP  = Click the map to define each point of the polygon, Double Click on the final point to end.
-REDLINEEDITCIRCLEHELP   = Click on the map and drag the mouse out to the desired radius to defined your circle. Release the mouse button to finish.
+REDLINEEDITCIRCLEHELP   = Click on the map and drag the mouse out to the desired radius to define your circle. Release the mouse button to finish.
 REDLINEPROMPTLABEL      = Enter a label for the redline item
 REDLINEADD              = Add Redline
 REDLINEDIGITIZE         = Digitize Redline
More information about the fusion-commits
