[fusion-commits] r2734 - in trunk: . layers/MapGuide layers/MapGuide/php lib widgets widgets/QuickPlot
svn_fusion at osgeo.org
Thu Jun 6 07:10:59 PDT 2013
Author: jng
Date: 2013-06-06 07:10:58 -0700 (Thu, 06 Jun 2013)
New Revision: 2734
trunk/
trunk/layers/MapGuide/MapGuide.js
trunk/layers/MapGuide/php/CreateSession.php
trunk/layers/MapGuide/php/GetSelectionProperties.php
trunk/layers/MapGuide/php/LoadMap.php
trunk/lib/ApplicationDefinition.js
trunk/lib/MGBroker.js
trunk/lib/MapMessage.js
trunk/lib/fusion.js
trunk/widgets/BasemapSwitcher.js
trunk/widgets/QuickPlot/GeneratePicture.php
RFC 134: Merge sandbox into trunk. Some general notes:
* The supportsExtendedQuery() function in Fusion.Layers.MapGuide has been replaced with the bUseNativeServices flag, which serves the same purpose: To determine if we're working with MGOS 2.6 or higher
* We use GIF as the icon format in a CREATERUNTIMEMAP request as tests have shown this format is the smallest of all the image formats in base64 form.
Property changes on: trunk
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/fusion-mg24:2560
/sandbox/jxlib-3.0:1957-2248
+ /branches/fusion-mg24:2560
/sandbox/createruntimemap:2699-2708
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2013-06-06 09:49:47 UTC (rev 2733)
+++ trunk/layers/MapGuide/MapGuide.js 2013-06-06 14:10:58 UTC (rev 2734)
@@ -50,6 +50,7 @@
1155581.153, 2311162.307, 4622324.614, 9244649.227, 18489298.45,
36978596.91, 73957193.82, 147914387.6, 295828775.3, 591657550.5
+ bUseNativeServices: false,
selectionAsOverlay: true,
useAsyncOverlay: false,
defaultFormat: 'PNG',
@@ -123,6 +124,10 @@
this.noCache = true;
this.oLayersOLTile = [];
+ if (Fusion.siteVersion) {
+ this.siteVersion = Fusion.siteVersion;
+ this.checkNativeServiceSupport();
var sid = Fusion.sessionId;
if (sid) {
this.session[0] = sid;
@@ -149,13 +154,45 @@
+ checkNativeServiceSupport: function() {
+ //NOTE: Using native services may cause a slight (but not too much) delay in any requests to PHP scripts
+ //that use layer property mappings as they will be lazy loaded due to us not calling LoadMap.php, which
+ //would've pre-cached such information. but we get much better map init performance
+ this.bUseNativeServices = false;
+ var vMajor = this.siteVersion[0];
+ var vMinor = this.siteVersion[1];
+ if (vMajor > 2) { // 3.0 or higher
+ this.bUseNativeServices = true;
+ } else {
+ if (vMajor == 2) { // 2.x
+ if (vMinor >= 6) { // >= 2.6
createSessionCB: function(xhr) {
if (xhr.status == 200) {
var o = Fusion.parseJSON(xhr.responseText);
if (o.success === false) {
Fusion.reportError(o.message);
} else {
+ var version = o.siteVersion;
+ var bits = version.split('.');
+ this.siteVersion = new Array(parseInt(bits[0]),
+ parseInt(bits[1]),
+ parseInt(bits[2]),
+ parseInt(bits[3])
this.session[0] = o.sessionId;
+ if (!Fusion.siteVersion)
+ Fusion.siteVersion = this.siteVersion;
+ if (!Fusion.sessionId)
+ Fusion.sessionId = o.sessionId;
var acceptLang = o.acceptLanguage.split(',');
//IE - en-ca,en-us;q=0.8,fr;q=0.5,fr-ca;q=0.3
for (var i=0; i<acceptLang.length; ++i) {
@@ -200,9 +237,18 @@
return this.session[0];
+ calcMapName: function(resourceId, bAppendUniqueId) {
+ var slIdx = resourceId.lastIndexOf("/") + 1;
+ var dIdx = resourceId.lastIndexOf(".");
+ var name = resourceId.substring(slIdx, dIdx);
+ if (bAppendUniqueId)
+ name += (new Date()).getTime();
+ return name;
loadMap: function(resourceId, options) {
this.bMapLoaded = false;
if (!this.sessionReady()) {
this.sMapResourceId = resourceId;
return;
@@ -212,7 +258,6 @@
this.mapWidget._addWorker();
this._fScale = -1;
- //this._nDpi = 96;
options = options || {};
@@ -226,228 +271,394 @@
this.oSelection = null;
this.aSelectionCallbacks = [];
this._bSelectionIsLoading = false;
+ if (this.bUseNativeServices) {
+ var features = (1 | 2 | 4); //We want the whole lot
+ var r = new Fusion.Lib.MGRequest.MGCreateRuntimeMap(resourceId, features, 25);
+ var mapName = this.calcMapName(resourceId, true);
+ r.setParams({
+ targetMapName: mapName,
+ iconFormat: "GIF"
+ if (this.session.length == 1)
+ r.setParams({ session: this.session[0] });
+ Fusion.oBroker.dispatchRequest(r, OpenLayers.Function.bind(this.onRuntimeMapCreated, this));
+ } else {
+ var sl = Fusion.getScriptLanguage();
+ var loadmapScript = 'layers/' + this.arch + '/' + sl + '/LoadMap.' + sl;
- var sl = Fusion.getScriptLanguage();
- var loadmapScript = 'layers/' + this.arch + '/' + sl + '/LoadMap.' + sl;
+ var sessionid = this.getSessionID();
- var sessionid = this.getSessionID();
- var params = {'mapid': resourceId, "session": sessionid};
- var options = {onSuccess: OpenLayers.Function.bind(this.mapLoaded,this),
- parameters:params};
- Fusion.ajaxRequest(loadmapScript, options);
+ var params = {'mapid': resourceId, "session": sessionid};
+ var options = {onSuccess: OpenLayers.Function.bind(this.mapLoaded,this),
+ parameters:params};
+ Fusion.ajaxRequest(loadmapScript, options);
- mapLoaded: function(r) {
- if (r.status == 200) {
- var o = Fusion.parseJSON(r.responseText);
- this._sResourceId = o.mapId;
- this._sMapname = o.mapName;
- this._sMapTitle = o.mapTitle;
+ * Re-shapes the CREATERUNTIMEMAP response to match the structure that our
+ * existing initialization code is expecting
+ convertResponse: function(o) {
+ var rt = o.RuntimeMap;
+ //LoadMap.php response
+ var lm = {
+ backgroundColor: ("#" + rt.BackgroundColor[0].substring(2)),
+ siteVersion: rt.SiteVersion[0],
+ mapId: rt.MapDefinition[0],
+ mapName: rt.Name[0],
+ mapTitle: rt.Name[0],
+ backgroundColor: rt.BackgroundColor[0],
+ metersPerUnit: parseFloat(rt.CoordinateSystem[0].MetersPerUnit[0]),
+ wkt: rt.CoordinateSystem[0].Wkt[0],
+ epsg: parseInt(rt.CoordinateSystem[0].EpsgCode[0]),
+ extent: [
+ parseFloat(rt.Extents[0].LowerLeftCoordinate[0].X[0]),
+ parseFloat(rt.Extents[0].LowerLeftCoordinate[0].Y[0]),
+ parseFloat(rt.Extents[0].UpperRightCoordinate[0].X[0]),
+ parseFloat(rt.Extents[0].UpperRightCoordinate[0].Y[0])
+ hasBaseMapLayers: false,
+ hasDynamicLayers: false,
+ FiniteDisplayScales: [],
+ groups: [],
+ layers: []
+ if (rt.FiniteDisplayScale) {
+ for (var i = 0; i < rt.FiniteDisplayScale.length; i++) {
+ lm.FiniteDisplayScales.push(parseFloat(rt.FiniteDisplayScale[i]));
+ for (var i = 0; i < rt.Group.length; i++) {
+ var grp = rt.Group[i];
+ var cg = {
+ groupName: grp.Name[0],
+ legendLabel: (grp.LegendLabel ? grp.LegendLabel[0] : ""),
+ uniqueId: grp.ObjectId[0],
+ displayInLegend: (grp.DisplayInLegend[0] == "true"),
+ expandInLegend: (grp.ExpandInLegend[0] == "true"),
+ parentUniqueId: grp.ParentId ? grp.ParentId[0] : "",
+ visible: (grp.Visible[0] == "true"),
+ actuallyVisible: (grp.ActuallyVisible[0] == "true"),
+ isBaseMapGroup: (grp.Type[0] == "2")
+ if (grp.Type[0] == "2")
+ lm.hasBaseMapLayers = true;
+ else
+ lm.hasDynamicLayers = true;
+ lm.groups.push(cg);
+ //LoadScaleRanges.php response
+ var lsr = {
+ layers: []
+ for (var i = 0; i < rt.Layer.length; i++) {
+ var lyr = rt.Layer[i];
+ var cl = {
+ uniqueId: lyr.ObjectId[0],
+ layerName: lyr.Name[0],
+ layerTypes: [],
+ resourceId: lyr.LayerDefinition[0],
+ parentGroup: lyr.ParentId ? lyr.ParentId[0] : "",
+ selectable: (lyr.Selectable[0] == "true"),
+ visible: (lyr.Visible[0] == "true"),
+ actuallyVisible: (lyr.ActuallyVisible[0] == "true"),
+ editable: false,
+ isBaseMapLayer: (lyr.Type[0] == "2"),
+ legendLabel: (lyr.LegendLabel ? lyr.LegendLabel[0] : ""),
+ displayInLegend: (lyr.DisplayInLegend[0] == "true"),
+ expandInLegend: (lyr.ExpandInLegend[0] == "true")
- // Fix defect that background color in overview map will affect background color in main map.
- // We'll first check if the loaded map is the one shown in main map.
- var currentMaps = this.mapWidget.mapGroup.maps;
- var isInMapWidget = false;
- for(var index = 0, len = currentMaps.length; index < len; index++) {
- var mapInMaps = currentMaps[index];
- if(mapInMaps.resourceId == this._sResourceId) {
- isInMapWidget = this;
- break;
+ lm.layers.push(cl);
+ var clsr = {
+ uniqueId: cl.uniqueId,
+ scaleRanges: []
+ var ltypes = {};
+ var minScale = 1.0e10;
+ var maxScale = 0;
+ if (lyr.ScaleRange) {
+ for (var j = 0; j < lyr.ScaleRange.length; j++) {
+ var sr = lyr.ScaleRange[j];
+ var csr = {
+ isCompressed: false,
+ maxScale: sr.MaxScale[0],
+ minScale: sr.MinScale[0],
+ styles: [],
+ minScale = Math.min(minScale, sr.MinScale[0]);
+ maxScale = Math.max(maxScale, sr.MaxScale[0]);
+ if (sr.FeatureStyle) {
+ for (var f = 0; f < sr.FeatureStyle.length; f++) {
+ var fts = sr.FeatureStyle[f];
+ for (var k = 0; k < fts.Rule.length; k++) {
+ var rule = fts.Rule[k];
+ var cr = {
+ categoryIndex: k,
+ filter: rule.Filter ? rule.Filter[0] : "",
+ geometryType: parseInt(fts.Type[0]),
+ legendLabel: rule.LegendLabel ? rule.LegendLabel[0] : ""
+ if (typeof(ltypes[cr.geometryType]) == 'undefined')
+ ltypes[cr.geometryType] = cr.geometryType;
+ //One single absence of an icon is enough to hint that it's compressed
+ if (!rule.Icon) {
+ csr.isCompressed = true;
+ } else {
+ cr.imageData = "data:" + rt.IconMimeType[0] + ";base64," + rule.Icon[0];
+ csr.styles.push(cr);
+ clsr.scaleRanges.push(csr);
- if(isInMapWidget) {
- this.mapWidget.setMetersPerUnit(o.metersPerUnit);
- this.mapWidget.setBackgroundColor(o.backgroundColor);
+ for (var lt in ltypes)
+ cl.layerTypes.push(lt);
+ cl.minScale = minScale;
+ cl.maxScale = maxScale;
+ lsr.layers.push(clsr);
+ return {
+ LoadMap: lm,
+ LoadScaleRanges: lsr
+ initLoadMapResponse: function(o) {
+ this._sResourceId = o.mapId;
+ this._sMapname = o.mapName;
+ this._sMapTitle = o.mapTitle;
+ // Fix defect that background color in overview map will affect background color in main map.
+ // We'll first check if the loaded map is the one shown in main map.
+ var currentMaps = this.mapWidget.mapGroup.maps;
+ var isInMapWidget = false;
+ for(var index = 0, len = currentMaps.length; index < len; index++) {
+ var mapInMaps = currentMaps[index];
+ if(mapInMaps.resourceId == this._sResourceId) {
+ isInMapWidget = this;
+ break;
+ if(isInMapWidget) {
+ this.mapWidget.setMetersPerUnit(o.metersPerUnit);
+ this.mapWidget.setBackgroundColor(o.backgroundColor);
- var version = o.siteVersion;
- var bits = version.split('.');
- this.siteVersion = new Array(parseInt(bits[0]),
- parseInt(bits[1]),
- parseInt(bits[2]),
- parseInt(bits[3])
+ this.mapTag.layerOptions.maxExtent = OpenLayers.Bounds.fromArray(o.extent);
+ this.layerRoot.clear();
+ this.layerRoot.legendLabel = this._sMapTitle;
+ this.layerRoot.displayInLegend = true;
+ this.layerRoot.expandInLegend = true;
- this.mapTag.layerOptions.maxExtent = OpenLayers.Bounds.fromArray(o.extent);
+ this.parseMapLayersAndGroups(o);
- this.layerRoot.clear();
- this.layerRoot.legendLabel = this._sMapTitle;
- this.layerRoot.displayInLegend = true;
- this.layerRoot.expandInLegend = true;
+ this.minScale = 1.0e10;
+ this.maxScale = 0;
+ for (var i=0; i<this.aLayers.length; i++) {
+ this.minScale = Math.min(this.minScale, this.aLayers[i].minScale);
+ this.maxScale = Math.max(this.maxScale, this.aLayers[i].maxScale);
+ //a scale value of 0 is undefined
+ if (this.minScale <= 0) {
+ this.minScale = 1.0;
- this.parseMapLayersAndGroups(o);
- this.minScale = 1.0e10;
- this.maxScale = 0;
- for (var i=0; i<this.aLayers.length; i++) {
- this.minScale = Math.min(this.minScale, this.aLayers[i].minScale);
- this.maxScale = Math.max(this.maxScale, this.aLayers[i].maxScale);
+ for (var i=0; i<this.aShowLayers.length; i++) {
+ var layer = this.layerRoot.findLayerByAttribute('layerName', this.aShowLayers[i]);
+ if (layer) {
+ this.aShowLayers[i] = layer.uniqueId;
+ } else {
+ this.aShowLayers[i] = '';
- //a scale value of 0 is undefined
- if (this.minScale <= 0) {
- this.minScale = 1.0;
+ for (var i=0; i<this.aHideLayers.length; i++) {
+ var layer = this.layerRoot.findLayerByAttribute('layerName', this.aHideLayers[i]);
+ if (layer) {
+ this.aHideLayers[i] = layer.uniqueId;
+ } else {
+ this.aHideLayers[i] = '';
- for (var i=0; i<this.aShowLayers.length; i++) {
- var layer = this.layerRoot.findLayerByAttribute('layerName', this.aShowLayers[i]);
- if (layer) {
- this.aShowLayers[i] = layer.uniqueId;
- } else {
- this.aShowLayers[i] = '';
+ for (var i=0; i<this.aShowGroups.length; i++) {
+ var group = this.layerRoot.findGroupByAttribute('groupName', this.aShowGroups[i]);
+ if (group) {
+ this.aShowGroups[i] = group.uniqueId;
+ } else {
+ this.aShowGroups[i] = '';
- for (var i=0; i<this.aHideLayers.length; i++) {
- var layer = this.layerRoot.findLayerByAttribute('layerName', this.aHideLayers[i]);
- if (layer) {
- this.aHideLayers[i] = layer.uniqueId;
- } else {
- this.aHideLayers[i] = '';
- for (var i=0; i<this.aShowGroups.length; i++) {
- var group = this.layerRoot.findGroupByAttribute('groupName', this.aShowGroups[i]);
- if (group) {
- this.aShowGroups[i] = group.uniqueId;
- } else {
- this.aShowGroups[i] = '';
+ for (var i=0; i<this.aHideGroups.length; i++) {
+ var group = this.layerRoot.findGroupByAttribute('groupName', this.aHideGroups[i]);
+ if (group) {
+ this.aHideGroups[i] = group.uniqueId;
+ } else {
+ this.aHideGroups[i] = '';
- for (var i=0; i<this.aHideGroups.length; i++) {
- var group = this.layerRoot.findGroupByAttribute('groupName', this.aHideGroups[i]);
- if (group) {
- this.aHideGroups[i] = group.uniqueId;
- } else {
- this.aHideGroups[i] = '';
+ if (o.hasBaseMapLayers && this.bIsMapWidgetLayer) { //Use tile if there is base layer and in main map
+ this.bSingleTile = false;
- if (o.hasBaseMapLayers && this.bIsMapWidgetLayer) { //Use tile if there is base layer and in main map
- this.bSingleTile = false;
- //set projection units and code if supplied
- var wktProj;
- if (o.wkt && o.wkt.length > 0){
- //Proj4js prefers EPSG codes over raw WKT. So if an EPSG code exists, use that over the WKT
- if (o.epsg != 0) {
+ //set projection units and code if supplied
+ var wktProj;
+ if (o.wkt && o.wkt.length > 0){
+ //Proj4js prefers EPSG codes over raw WKT. So if an EPSG code exists, use that over the WKT
+ if (o.epsg != 0) {
wktProj = new OpenLayers.Projection("EPSG:" + o.epsg);
this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
- } else {
+ } else {
wktProj = new OpenLayers.Projection(o.wkt);
- if (!wktProj || (wktProj && wktProj.proj && !wktProj.proj.readyToUse)) {
+ if (!wktProj || (wktProj && wktProj.proj && !wktProj.proj.readyToUse)) {
- } else {
+ } else {
//default to the local non-projected system if not otherwise specified
o.wkt = "LOCAL_CS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
- //TODO: consider passing the metersPerUnit value into the framework
- //to allow for scaling that doesn't match any of the pre-canned units
- this.mapTag.layerOptions.units = Fusion.getClosestUnits(o.metersPerUnit);
+ //TODO: consider passing the metersPerUnit value into the framework
+ //to allow for scaling that doesn't match any of the pre-canned units
+ this.mapTag.layerOptions.units = Fusion.getClosestUnits(o.metersPerUnit);
- //add in scales array if supplied
- if (o.FiniteDisplayScales && o.FiniteDisplayScales.length>0) {
- this.scales = o.FiniteDisplayScales;
- this.mapWidget.fractionalZoom = false;
- this.mapWidget.oMapOL.fractionalZoom = false;
+ //add in scales array if supplied
+ if (o.FiniteDisplayScales && o.FiniteDisplayScales.length>0) {
+ this.scales = o.FiniteDisplayScales;
+ this.mapWidget.fractionalZoom = false;
+ this.mapWidget.oMapOL.fractionalZoom = false;
- if (!this.bSingleTile) {
- if (o.groups.length >0) {
- var tiledLayerIndex = 0;
- this.noCache = false;
- this.mapWidget.registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, OpenLayers.Function.bind(this.mapExtentsChanged, this));
- for (var i=0; i<o.groups.length; i++) {
- if(o.groups[i].isBaseMapGroup) {
- this.oLayersOLTile[tiledLayerIndex] = this.createOLLayer(this._sMapname + "_Tiled[" + tiledLayerIndex + "]", false, 2, false, o.groups[i].groupName);
- tiledLayerIndex++;
+ if (!this.bSingleTile) {
+ if (o.groups.length >0) {
+ var tiledLayerIndex = 0;
+ this.noCache = false;
+ this.mapWidget.registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, OpenLayers.Function.bind(this.mapExtentsChanged, this));
+ for (var i=0; i<o.groups.length; i++) {
+ if(o.groups[i].isBaseMapGroup) {
+ this.oLayersOLTile[tiledLayerIndex] = this.createOLLayer(this._sMapname + "_Tiled[" + tiledLayerIndex + "]", false, 2, false, o.groups[i].groupName);
+ tiledLayerIndex++;
- else {
- this.bSingleTile = true;
+ } else {
+ this.bSingleTile = true;
- //remove this layer if it was already created
- if (this.oLayerOL) {
- this.oLayerOL.events.unregister("loadstart", this, this.loadStart);
- this.oLayerOL.events.unregister("loadend", this, this.loadEnd);
- this.oLayerOL.events.unregister("loadcancel", this, this.loadEnd);
- this.oLayerOL.destroy();
+ //remove this layer if it was already created
+ if (this.oLayerOL) {
+ this.oLayerOL.events.unregister("loadstart", this, this.loadStart);
+ this.oLayerOL.events.unregister("loadend", this, this.loadEnd);
+ this.oLayerOL.events.unregister("loadcancel", this, this.loadEnd);
+ this.oLayerOL.destroy();
- if (this.oLayersOLTile.length != 0) {
- this.oLayerOL = this.oLayersOLTile[this.oLayersOLTile.length-1]; // The last baselayer at the bottom.
- } else {
- this.oLayerOL = this.createOLLayer(this._sMapname, this.bSingleTile, 2, false, "");
+ if (this.oLayersOLTile.length != 0) {
+ this.oLayerOL = this.oLayersOLTile[this.oLayersOLTile.length-1]; // The last baselayer at the bottom.
+ } else {
+ this.oLayerOL = this.createOLLayer(this._sMapname, this.bSingleTile, 2, false, "");
+ if (wktProj && wktProj.proj && wktProj.proj.readyToUse) {
+ this.oLayerOL.projection = wktProj;
+ this.oLayerOL.projection.proj.units = this.mapTag.layerOptions.units;
+ this.oLayerOL.events.register("loadstart", this, this.loadStart);
+ this.oLayerOL.events.register("loadend", this, this.loadEnd);
+ this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
+ //remove the dynamic overlay layer if it was already created
+ if (this.oLayerOL2) {
+ this.oLayerOL2.destroy();
+ //this is to distinguish between a regular map and an overview map
+ this.bMapLoaded = true;
+ if (this.bIsMapWidgetLayer) {
+ this.mapWidget.addMap(this);
- if (wktProj && wktProj.proj && wktProj.proj.readyToUse) {
- this.oLayerOL.projection = wktProj;
- this.oLayerOL.projection.proj.units = this.mapTag.layerOptions.units;
+ if(this.oLayersOLTile.length > 1) {
+ for(var i=this.oLayersOLTile.length-2; i>=0; i--) {
+ // Workaround to make multiple baselayers display.
+ // Openlayers only supports single baselayer.
+ this.oLayersOLTile[i].isBaseLayer = false;
+ this.mapWidget.oMapOL.addLayer(this.oLayersOLTile[i]);
- this.oLayerOL.events.register("loadstart", this, this.loadStart);
- this.oLayerOL.events.register("loadend", this, this.loadEnd);
- this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
- //remove the dynamic overlay layer if it was already created
- if (this.oLayerOL2) {
- this.oLayerOL2.destroy();
+ //if we have a tiled map that also contains dynamic layers, we need to create
+ //an additional overlay layer to render them on top of the tiles
+ if(!this.bSingleTile && o.hasDynamicLayers) {
+ this.oLayerOL2 = this.createOLLayer(this._sMapname + "_DynamicOverlay",true,2,true, "");
+ this.mapWidget.oMapOL.addLayer(this.oLayerOL2);
+ this.oLayerOL2.setVisibility(true);
- //this is to distinguish between a regular map and an overview map
- this.bMapLoaded = true;
- if (this.bIsMapWidgetLayer) {
- this.mapWidget.addMap(this);
- if(this.oLayersOLTile.length > 1) {
- for(var i=this.oLayersOLTile.length-2; i>=0; i--) {
- // Workaround to make multiple baselayers display.
- // Openlayers only supports single baselayer.
- this.oLayersOLTile[i].isBaseLayer = false;
- this.mapWidget.oMapOL.addLayer(this.oLayersOLTile[i]);
- //if we have a tiled map that also contains dynamic layers, we need to create
- //an additional overlay layer to render them on top of the tiles
- if(!this.bSingleTile && o.hasDynamicLayers) {
- this.oLayerOL2 = this.createOLLayer(this._sMapname + "_DynamicOverlay",true,2,true, "");
- this.mapWidget.oMapOL.addLayer(this.oLayerOL2);
- this.oLayerOL2.setVisibility(true);
- //Fix Defect: the Base Layer Group should be invisiable when the "initially visiable in map" is set to false
- var i = 0;
- var j = 0;
- for(i = 0;i < this.layerRoot.groups.length; i++){
- if(this.layerRoot.groups[i].isBaseMapGroup && !this.layerRoot.groups[i].initiallyVisible){
- for(j = 0; j<this.oLayersOLTile.length; j++) {
- if(this.oLayersOLTile[j].params.basemaplayergroupname === this.layerRoot.groups[i].name) {
- this.oLayersOLTile[j].setVisibility(false);
+ //Fix Defect: the Base Layer Group should be invisiable when the "initially visiable in map" is set to false
+ var i = 0;
+ var j = 0;
+ for(i = 0;i < this.layerRoot.groups.length; i++){
+ if(this.layerRoot.groups[i].isBaseMapGroup && !this.layerRoot.groups[i].initiallyVisible){
+ for(j = 0; j<this.oLayersOLTile.length; j++) {
+ if(this.oLayersOLTile[j].params.basemaplayergroupname === this.layerRoot.groups[i].name) {
+ this.oLayersOLTile[j].setVisibility(false);
+ * Callback function from a LoadMap.php request
+ mapLoaded: function(r) {
+ if (r.status == 200) {
+ var o = Fusion.parseJSON(r.responseText);
+ this.initLoadMapResponse(o);
this.mapWidget._removeWorker();
this.triggerEvent(Fusion.Event.LAYER_LOADED);
+ * Callback function from a CREATERUNTIMEMAP request
+ onRuntimeMapCreated: function(r) {
+ var co = this.convertResponse(o);
+ this.initLoadMapResponse(co.LoadMap);
+ //Need to wait for the right event to trigger loadScaleRanges, so stash our
+ //prepared result for when it comes
+ this._initScaleRanges = co.LoadScaleRanges;
+ this.mapWidget._removeWorker();
+ this.triggerEvent(Fusion.Event.LAYER_LOADED);
//TBD: this function not yet converted for OL
reloadMap: function() {
@@ -490,43 +701,52 @@
loadScaleRanges: function() {
- var loadmapScript = 'layers/' + this.arch + '/' + sl + '/LoadScaleRanges.' + sl;
+ if (this.bUseNativeServices && this._initScaleRanges) {
+ this.initLoadScaleRangeResponse(this._initScaleRanges);
+ delete this._initScaleRanges;
+ } else {
+ var loadmapScript = 'layers/' + this.arch + '/' + sl + '/LoadScaleRanges.' + sl;
- //IE7 or lower: No pre-caching for you!
- var preCacheIcons = !(Browser.Engine.trident4 || Browser.Engine.trident5);
- //console.log("Layer icon pre-caching enabled: " + preCacheIcons);
+ //IE7 or lower: No pre-caching for you!
+ var preCacheIcons = !(Browser.Engine.trident4 || Browser.Engine.trident5);
+ //console.log("Layer icon pre-caching enabled: " + preCacheIcons);
- var params = {'mapname': this._sMapname, "session": sessionid, "preCacheIcons": preCacheIcons};
- var options = {onSuccess: OpenLayers.Function.bind(this.scaleRangesLoaded,this),
+ var params = {'mapname': this._sMapname, "session": sessionid, "preCacheIcons": preCacheIcons};
+ var options = {onSuccess: OpenLayers.Function.bind(this.scaleRangesLoaded,this),
+ initLoadScaleRangeResponse: function(o) {
+ if (o.layers && o.layers.length > 0) {
+ var iconOpt = {
+ url: o.icons_url || null,
+ width: o.icons_width || 16,
+ height: o.icons_height || 16
+ for (var i=0; i<o.layers.length; i++) {
+ var oLayer = this.getLayerById(o.layers[i].uniqueId);
+ if (oLayer) {
+ oLayer.scaleRanges = [];
+ for (var j=0; j<o.layers[i].scaleRanges.length; j++) {
+ var scaleRange = new Fusion.Layers.ScaleRange(o.layers[i].scaleRanges[j],
+ oLayer.layerType, iconOpt);
+ oLayer.scaleRanges.push(scaleRange);
+ this.mapWidget.triggerEvent(Fusion.Event.MAP_SCALE_RANGE_LOADED);
scaleRangesLoaded: function(r)
- if (o.layers && o.layers.length > 0) {
- var iconOpt = {
- url: o.icons_url || null,
- width: o.icons_width || 16,
- height: o.icons_height || 16
- for (var i=0; i<o.layers.length; i++) {
- var oLayer = this.getLayerById(o.layers[i].uniqueId);
- if (oLayer) {
- oLayer.scaleRanges = [];
- for (var j=0; j<o.layers[i].scaleRanges.length; j++) {
- var scaleRange = new Fusion.Layers.ScaleRange(o.layers[i].scaleRanges[j],
- oLayer.layerType, iconOpt);
- oLayer.scaleRanges.push(scaleRange);
- this.mapWidget.triggerEvent(Fusion.Event.MAP_SCALE_RANGE_LOADED);
+ this.initLoadScaleRangeResponse(o);
@@ -1121,25 +1341,6 @@
- * Checks if we can perform a v2.6.0 QUERYMAPFEATURES request. A v2.6.0 QUERYMAPFEATURES request gives us
- * - All attributes of selected features if requested (bypassing several follow-up requests to PHP scripts to get this data)
- * - Slimmer maptip requests.
- * A much better option, if it is available to us.
- supportsExtendedQuery: function() {
- var bSupportsExtended = false;
- if (this.siteVersion[0] >= 2) { //2.x or higher
- if (this.siteVersion[0] == 2) { //Major is 2
- if (this.siteVersion[1] >= 6) { //2.6 or higher 2.x
- bSupportsExtended = true;
- } else { //3.x, 4.x, etc
- return bSupportsExtended;
Do a query on the map
@@ -1164,7 +1365,7 @@
options.filter = '';
- if (this.supportsExtendedQuery()) {
var reqData = 1; //attributes
//TODO: Can't use inline selection image yet as we'll have to modify OpenLayers to accept an inline selection
//over doing a GETDYNAMICMAPOVERLAYIMAGE request. When we can, or the value of 2 into the mask for inline
@@ -1398,7 +1599,7 @@
var layerAttributeFilter = 5;
//TODO: possibly make the layer names configurable?
var layerNames = mapTipWidget.aLayers.toString();
var reqData = (4 | 8); //Tooltips and hyperlinks
var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures2(this.getSessionID(),
this._sMapname,
Modified: trunk/layers/MapGuide/php/CreateSession.php
--- trunk/layers/MapGuide/php/CreateSession.php 2013-06-06 09:49:47 UTC (rev 2733)
+++ trunk/layers/MapGuide/php/CreateSession.php 2013-06-06 14:10:58 UTC (rev 2734)
@@ -48,6 +48,7 @@
$result = null;
$result->sessionId = $sessionId;
$result->userName = $username;
+ $result->siteVersion = GetSiteVersion();
$result->acceptLanguage = $_SERVER['HTTP_ACCEPT_LANGUAGE'];
echo var2json($result);
Modified: trunk/layers/MapGuide/php/GetSelectionProperties.php
--- trunk/layers/MapGuide/php/GetSelectionProperties.php 2013-06-06 09:49:47 UTC (rev 2733)
+++ trunk/layers/MapGuide/php/GetSelectionProperties.php 2013-06-06 14:10:58 UTC (rev 2734)
@@ -76,21 +76,25 @@
/* the class that is used for this layer will be used to select features */
$class = $oLayer->GetFeatureClassName();
- /* select the features */
- $queryOptions = new MgFeatureQueryOptions();
- $geomName = $oLayer->GetFeatureGeometryName();
- //TODO : seems that property mapping breaks the selection ????
- //could it be that $selection->AddFeatures($layerObj, $featureReader, 0) is
- //the one causing a problem when the properies are limited ?
- if (isset($_SESSION['property_mappings']) && isset($_SESSION['property_mappings'][$oLayer->GetObjectId()])) {
- $mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
- if (count($mappings) > 0) {
- foreach($mappings as $name => $value) {
- if ($geomName != $name) {
- $queryOptions->AddFeatureProperty($name);
- //echo "$name $value <br>\n";
+ /* select the features */
+ $queryOptions = new MgFeatureQueryOptions();
+ $geomName = $oLayer->GetFeatureGeometryName();
+ //TODO : seems that property mapping breaks the selection ????
+ //could it be that $selection->AddFeatures($layerObj, $featureReader, 0) is
+ //the one causing a problem when the properies are limited ?
+ if (isset($_SESSION['property_mappings']) && isset($_SESSION['property_mappings'][$oLayer->GetObjectId()])) {
+ $mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
+ } else {
+ //This is normally pre-stashed by LoadMap.php, but if the client is using the new
+ //CREATERUNTIMEMAP shortcut, this information does not exist yet, so fetch and stash
+ $mappings = GetLayerPropertyMappings($resourceService, $oLayer);
+ $_SESSION['property_mappings'][$oLayer->GetObjectId()] = $mappings;
+ if (count($mappings) > 0) {
+ foreach($mappings as $name => $value) {
+ if ($geomName != $name) {
+ $queryOptions->AddFeatureProperty($name);
+ //echo "$name $value <br>\n";
Modified: trunk/layers/MapGuide/php/LoadMap.php
--- trunk/layers/MapGuide/php/LoadMap.php 2013-06-06 09:49:47 UTC (rev 2733)
+++ trunk/layers/MapGuide/php/LoadMap.php 2013-06-06 14:10:58 UTC (rev 2734)
@@ -114,7 +114,6 @@
$mapObj->metersPerUnit = $metersPerUnit;
$mapObj->wkt = $srs;
$mapObj->epsg = $epsgCode;
- $mapObj->siteVersion = GetSiteVersion();
$mapObj->mapTitle=addslashes($mapTitle);
Property changes on: trunk/lib/ApplicationDefinition.js
- /branches/fusion-mg24/lib/ApplicationDefinition.js:2560
/sandbox/adsk/2.4j/lib/ApplicationDefinition.js:2486-2514
/sandbox/jxlib-3.0/lib/ApplicationDefinition.js:1957-2248
/trunk/lib/ApplicationDefinition.js:2469-2485
+ /branches/fusion-mg24/lib/ApplicationDefinition.js:2560
/sandbox/createruntimemap/lib/ApplicationDefinition.js:2699-2708
Modified: trunk/lib/MGBroker.js
--- trunk/lib/MGBroker.js 2013-06-06 09:49:47 UTC (rev 2733)
+++ trunk/lib/MGBroker.js 2013-06-06 14:10:58 UTC (rev 2734)
@@ -316,6 +316,34 @@
+ * Class: Fusion.Lib.MGRequest.MGCreateRuntimeMap
+ * encapsulate a request to the server to create a new runtime map (and session if required)
+ * on the server
+ * Inherits from:
+ * - <Fusion.Lib.MGRequest>
+Fusion.Lib.MGRequest.MGCreateRuntimeMap = OpenLayers.Class(Fusion.Lib.MGRequest, {
+ * Constructor: Fusion.Lib.MGRequest.MGCreateRuntimeMap
+ * initialize a new instance of Fusion.Lib.MGRequest.MGCreateRuntimeMap
+ initialize: function(mapDefinition, features, iconsPerScaleRange) {
+ this.initializeRequest();
+ this.setParams({
+ operation: "CREATERUNTIMEMAP",
+ mapdefinition: mapDefinition,
+ requestedfeatures: features,
+ iconsperscalerange: iconsPerScaleRange,
+ format: "application/json",
+ version: "2.6.0"
* Class: Fusion.Lib.MGRequest.MGCopyResource
* encapsulate a request to the server to copy a resource.
Property changes on: trunk/lib/MapMessage.js
- /branches/fusion-mg24/lib/MapMessage.js:2560
/sandbox/adsk/2.4j/lib/MapMessage.js:2486-2514
/sandbox/jxlib-3.0/lib/MapMessage.js:1957-2248
/trunk/lib/MapMessage.js:2469-2485
+ /branches/fusion-mg24/lib/MapMessage.js:2560
/sandbox/createruntimemap/lib/MapMessage.js:2699-2708
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js 2013-06-06 09:49:47 UTC (rev 2733)
+++ trunk/lib/fusion.js 2013-06-06 14:10:58 UTC (rev 2734)
@@ -1606,38 +1606,65 @@
xhr.open("GET", url, false);
xhr.send(null);
- var o;
- eval('o='+xhr.responseText);
+ var o = Fusion.parseJSON(xhr.responseText);
+ Fusion.siteVersion = new Array(parseInt(bits[0]),
+ parseInt(bits[3])
var appDefUrl = Fusion.getQueryParam('ApplicationDefinition');
- if(appDefUrl && (
+ if (appDefUrl && (
appDefUrl.indexOf('Library') == 0 ||
- appDefUrl.indexOf('Session') == 0)){
+ appDefUrl.indexOf('Session') == 0)) {
+ var fetchAppDef = function(appDefUrl, sessionId) {
+ var xhr = new getXmlHttpRequest();
+ var mapAgentUrl = getAgentUrl();
+ xhr.open("GET", mapAgentUrl + "?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=" + appDefUrl + "&FORMAT=text%2Fxml&SESSION="+ sessionId, false);
+ xhr.send(null);
+ var appDefXML = xhr.responseXML.documentElement;
+ if (appDefXML) {
+ var googleElement = appDefXML.getElementsByTagName("GoogleScript")[0];
+ var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
+ var veElement = appDefXML.getElementsByTagName("VirtualEarthScript")[0];
+ var osmElement = appDefXML.getElementsByTagName("OpenStreetMapScript")[0];
+ addElement(googleElement);
+ addElement(yahooElement);
+ addElement(veElement);
+ addElement(osmElement);
+ var getSiteVersion = function(sessionId) {
+ xhr.open("GET", mapAgentUrl + "?OPERATION=GETSITEVERSION&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&SESSION="+ sessionId, false);
+ xhr.send(null);
+ var verXML = xhr.responseXML.documentElement;
+ var el = verXML.getElementsByTagName("Version")[0];
+ var version = el.textContent || el.text;
+ return new Array(parseInt(bits[0]),
+ parseInt(bits[3]));
var passedSessionId = Fusion.getQueryParam('Session');
- if(passedSessionId == null || passedSessionId == "" ){
+ if (passedSessionId == null || passedSessionId == "" ){
createSessionId(Fusion.getQueryParam("Username"), Fusion.getQueryParam("Password"));
- }else{
+ } else {
Fusion.sessionId = passedSessionId;
+ Fusion.siteVersion = getSiteVersion(passedSessionId);
- var xhr = new getXmlHttpRequest();
- var mapAgentUrl = getAgentUrl();
- xhr.open("GET", mapAgentUrl + "?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=" + appDefUrl + "&FORMAT=text%2Fxml&SESSION="+ Fusion.sessionId, false);
- xhr.send(null);
- var appDefXML = xhr.responseXML.documentElement;
- if(appDefXML){
- var googleElement = appDefXML.getElementsByTagName("GoogleScript")[0];
- var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
- var veElement = appDefXML.getElementsByTagName("VirtualEarthScript")[0];
- var osmElement = appDefXML.getElementsByTagName("OpenStreetMapScript")[0];
- addElement(googleElement);
- addElement(yahooElement);
- addElement(veElement);
- addElement(osmElement);
+ fetchAppDef(appDefUrl, Fusion.sessionId);
Property changes on: trunk/widgets/BasemapSwitcher.js
- /branches/fusion-mg24/widgets/BasemapSwitcher.js:2560
/sandbox/adsk/2.4j/widgets/BasemapSwitcher.js:2486-2526
/sandbox/jxlib-3.0/widgets/BasemapSwitcher.js:1957-2248
/trunk/widgets/BasemapSwitcher.js:2469-2485
+ /branches/fusion-mg24/widgets/BasemapSwitcher.js:2560
/sandbox/createruntimemap/widgets/BasemapSwitcher.js:2699-2708
Property changes on: trunk/widgets/QuickPlot/GeneratePicture.php
- /branches/fusion-mg24/widgets/QuickPlot/GeneratePicture.php:2560
/sandbox/adsk/2.4jbeta2/widgets/QuickPlot/GeneratePicture.php:2488-2498
/sandbox/jxlib-3.0/widgets/QuickPlot/GeneratePicture.php:1957-2248
/trunk/widgets/QuickPlot/GeneratePicture.php:2469-2487
+ /branches/fusion-mg24/widgets/QuickPlot/GeneratePicture.php:2560
/sandbox/createruntimemap/widgets/QuickPlot/GeneratePicture.php:2699-2708
More information about the fusion-commits
