[fusion-commits] r2655 - in trunk: text widgets/Redline/classes widgets/Redline/templates
svn_fusion at osgeo.org
Fri Mar 8 01:54:46 PST 2013
Author: jng
Date: 2013-03-08 01:54:46 -0800 (Fri, 08 Mar 2013)
New Revision: 2655
trunk/text/en
trunk/widgets/Redline/classes/markupmanager.php
trunk/widgets/Redline/templates/markupfeaturesource.xml
#551: Fix upload function and add support for SQLite redline data files
Modified: trunk/text/en
--- trunk/text/en 2013-03-08 09:32:42 UTC (rev 2654)
+++ trunk/text/en 2013-03-08 09:54:46 UTC (rev 2655)
@@ -318,7 +318,7 @@
# Redline Upload
REDLINEUPLOAD = Upload Redline
REDLINEDATAFILE = Redline Data File
-REDLINEUPLOADNOTE = Note: Data file must be a SDF file and you can only upload data files that have either been originally created by this widget or have an identical feature schema.
+REDLINEUPLOADNOTE = Note: Data file must be a SDF, SQLite or SHP file and you can only upload data files that have either been originally created by this widget or have an identical feature schema.<br><br>For SHP files, you must upload a zip file containing the SHP file and its associated files (.dbf, .idx, .shx, etc)
REDLINEUPLOADREQUIRED = Redline Data File not specified
REDLINEUPLOADTEXT = Upload
REDLINEUPLOADCLOSE = Close
Modified: trunk/widgets/Redline/classes/markupmanager.php
--- trunk/widgets/Redline/classes/markupmanager.php 2013-03-08 09:32:42 UTC (rev 2654)
+++ trunk/widgets/Redline/classes/markupmanager.php 2013-03-08 09:54:46 UTC (rev 2655)
@@ -526,7 +526,7 @@
function UploadMarkup()
$locale = "en";
- if (array_key_exists($this->args, "LOCALE"))
+ if (array_key_exists("LOCALE", $this->args))
$locale = $this->args["LOCALE"];
$uploadFileParts = pathinfo($_FILES["UPLOADFILE"]["name"]);
$fdoProvider = $this->GetProviderFromExtension($uploadFileParts["extension"]);
@@ -547,8 +547,17 @@
$markupLayerResId = new MgResourceIdentifier($this->GetResourceIdPrefix() . $baseName . ".LayerDefinition");
$markupFsId = new MgResourceIdentifier($this->GetResourceIdPrefix() . $baseName . '.FeatureSource');
+ //Set up feature source document
$dataName = $baseName . "." . $ext;
- $fsXml = sprintf(file_get_contents("templates/markupfeaturesource.xml"), $dataName);
+ $fileParam = "File";
+ if (strcmp($fdoProvider, "OSGeo.SHP") == 0) {
+ $fileParam = "DefaultFileLocation";
+ $extraXml = "";
+ if (strcmp($fdoProvider, "OSGeo.SDF") == 0) { //Need to set ReadOnly = false for SDF
+ $extraXml = "<Parameter><Name>ReadOnly</Name><Value>FALSE</Value></Parameter>";
+ $fsXml = sprintf(file_get_contents("templates/markupfeaturesource.xml"), $fdoProvider, $fileParam, $dataName, $extraXml);
$bs2 = new MgByteSource($fsXml, strlen($fsXml));
$resourceService->SetResource($markupFsId, $bs2->GetReader(), null);
$resourceService->SetResourceData($markupFsId, $dataName, "File", $bs->GetReader());
@@ -560,6 +569,7 @@
$klass = $classes->GetItem(0);
$geomProp = $klass->GetDefaultGeometryPropertyName();
$clsProps = $klass->GetProperties();
+ $className = $schema->GetName().":".$klass->GetName();
$geomTypes = -1;
if ($clsProps->IndexOf($geomProp) >= 0) {
$geom = $clsProps->GetItem($geomProp);
@@ -601,7 +611,7 @@
$this->args["LABELBACKCOLOR"] = DefaultStyle::LABEL_BACK_COLOR;
$this->args["LABELBACKSTYLE"] = DefaultStyle::LABEL_BACK_STYLE;
- $markupLayerDefinition = $this->CreateMarkupLayerDefinitionContent($markupFsId->ToString());
+ $markupLayerDefinition = $this->CreateMarkupLayerDefinitionContent($markupFsId->ToString(), $className);
$layerBs = new MgByteSource($markupLayerDefinition, strlen($markupLayerDefinition));
//Save to new resource or overwrite existing
Modified: trunk/widgets/Redline/templates/markupfeaturesource.xml
--- trunk/widgets/Redline/templates/markupfeaturesource.xml 2013-03-08 09:32:42 UTC (rev 2654)
+++ trunk/widgets/Redline/templates/markupfeaturesource.xml 2013-03-08 09:54:46 UTC (rev 2655)
@@ -1,12 +1,9 @@
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
- <Provider>OSGeo.SDF</Provider>
+ <Provider>%s</Provider>
<Parameter>
- <Name>File</Name>
+ <Name>%s</Name>
<Value>%%MG_DATA_FILE_PATH%%%s</Value>
</Parameter>
- <Parameter>
- <Name>ReadOnly</Name>
- <Value>FALSE</Value>
- </Parameter>
+ %s
</FeatureSource>
\ No newline at end of file
More information about the fusion-commits
