[fusion-commits] r2659 - in trunk: text widgets/Redline/classes
svn_fusion at osgeo.org
Fri Mar 8 05:45:51 PST 2013
Author: jng
Date: 2013-03-08 05:45:51 -0800 (Fri, 08 Mar 2013)
New Revision: 2659
trunk/text/en
trunk/widgets/Redline/classes/markupeditor.php
trunk/widgets/Redline/classes/markupmanager.php
#551: Add support for uploading SHP-based redlines. These must be uploaded as zip files containing all the required parts. Also do a schema validation check as part of uploading to ensure the Feature Source schematically looks like something created by this widget.
Modified: trunk/text/en
--- trunk/text/en 2013-03-08 12:33:00 UTC (rev 2658)
+++ trunk/text/en 2013-03-08 13:45:51 UTC (rev 2659)
@@ -330,6 +330,8 @@
REDLINEUPLOADREQUIRED = Redline Data File not specified
REDLINEUPLOADTEXT = Upload
REDLINEUPLOADCLOSE = Close
+REDLINEUPLOADSHPZIPERROR = Error uploading zip file. File is either:<ul><li>Not a zip file</li><li>A corrupted zip file</li><li>Does not contain a .shp file</li></ul>
+REDLINEUPLOADINVALIDSCHEMA = The uploaded redline data file has an invalid schema. This widget expects the following properties in the class definition:<ul><li>The class definition is named 'Markup'</li><li>It has an auto-generated numeric identity property (ID or FeatId)</li><li>It has a geometry property (Geometry)</li><li>It has a string property (Text)</li></ul><br>Redline data files created by this widget satisfy this schema requirements.
# HtmlViewerAbout
HTMLABOUTTITLE = About %s
Modified: trunk/widgets/Redline/classes/markupeditor.php
--- trunk/widgets/Redline/classes/markupeditor.php 2013-03-08 12:33:00 UTC (rev 2658)
+++ trunk/widgets/Redline/classes/markupeditor.php 2013-03-08 13:45:51 UTC (rev 2659)
@@ -278,7 +278,7 @@
$markupLayer = $map->GetLayers()->GetItem('_' . $this->GetMarkupName());
$selection = new MgSelection($map);
- $selection->AddFeatureIdInt32($markupLayer, 'MarkupSchema:Markup', (int) $this->args['MARKUPFEATURE']);
+ $selection->AddFeatureIdInt32($markupLayer, $markupLayer->GetFeatureClassName(), (int) $this->args['MARKUPFEATURE']);
return $selection->ToXML();
Modified: trunk/widgets/Redline/classes/markupmanager.php
--- trunk/widgets/Redline/classes/markupmanager.php 2013-03-08 12:33:00 UTC (rev 2658)
+++ trunk/widgets/Redline/classes/markupmanager.php 2013-03-08 13:45:51 UTC (rev 2659)
@@ -543,7 +543,7 @@
} else { //Single file, make things easier!
$dataName = $markupLayerResId->GetName().$extension;
- $byteReader = $resourceService->GetResourceData($markupFsId, $zipName);
+ $byteReader = $resourceService->GetResourceData($markupFsId, $dataName);
$len = $byteReader->GetLength();
$outputBuffer = '';
@@ -569,8 +569,8 @@
return "OSGeo.SQLite";
} else if ( substr( $extNorm, strlen( $extNorm ) - strlen( "db" ) ) == "db" ) {
- //} else if ( substr( $extNorm, strlen( $extNorm ) - strlen( "zip" ) ) == "zip" ) { //SHP file uploads will be zipped
- // return "OSGeo.SHP";
+ } else if ( substr( $extNorm, strlen( $extNorm ) - strlen( "zip" ) ) == "zip" ) { //SHP file uploads will be zipped
+ return "OSGeo.SHP";
} else {
return null;
@@ -603,8 +603,29 @@
//Set up feature source document
$dataName = $baseName . "." . $ext;
$fileParam = "File";
+ $shpFileParts = array();
if (strcmp($fdoProvider, "OSGeo.SHP") == 0) {
+ $dataName = null;
$fileParam = "DefaultFileLocation";
+ $zip = new ZipArchive();
+ if ($zip->open($_FILES["UPLOADFILE"]["tmp_name"]) === TRUE) {
+ for ($i = 0; $i < $zip->numFiles; $i++) {
+ $stat = $zip->statIndex($i);
+ $filePath = tempnam(sys_get_temp_dir(), "upload");
+ //Dump to temp file
+ file_put_contents($filePath, $zip->getFromIndex($i));
+ //Stash for later upload and cleanup
+ $entry = $stat["name"];
+ $shpFileParts[$entry] = $filePath;
+ if (substr( $entry, strlen( $entry ) - strlen( ".shp" ) ) == ".shp")
+ $dataName = $entry;
+ //Abort if we can't find a .shp file. This is not a valid zip file
+ if ($dataName == null)
+ throw new Exception(GetLocalizedString("REDLINEUPLOADSHPZIPERROR", $locale));
+ } else {
$extraXml = "";
if (strcmp($fdoProvider, "OSGeo.SDF") == 0) { //Need to set ReadOnly = false for SDF
@@ -613,7 +634,16 @@
$fsXml = sprintf(file_get_contents("templates/markupfeaturesource.xml"), $fdoProvider, $fileParam, $dataName, $extraXml);
$bs2 = new MgByteSource($fsXml, strlen($fsXml));
$resourceService->SetResource($markupFsId, $bs2->GetReader(), null);
- $resourceService->SetResourceData($markupFsId, $dataName, "File", $bs->GetReader());
+ if (count($shpFileParts) > 0) {
+ foreach ($shpFileParts as $name => $path) {
+ $bs3 = new MgByteSource($path);
+ $resourceService->SetResourceData($markupFsId, $name, "File", $bs3->GetReader());
+ //Cleanup
+ unlink($path);
+ } else { //Not a SHP file
+ $resourceService->SetResourceData($markupFsId, $dataName, "File", $bs->GetReader());
//Query the geometry types
$schemas = $featureService->DescribeSchema($markupFsId, "", null);
@@ -627,8 +657,23 @@
if ($clsProps->IndexOf($geomProp) >= 0) {
$geom = $clsProps->GetItem($geomProp);
$geomTypes = $geom->GetGeometryTypes();
+ //Since we're here. Validate the schema requirements. If this was created by this widget previously
+ //it will be valid
+ $idProps = $klass->GetIdentityProperties();
+ if ($idProps->GetCount() != 1) {
+ throw new Exception(GetLocalizedString("REDLINEUPLOADINVALIDSCHEMA", $locale));
+ } else {
+ //Must be auto-generated (implying numerical as well)
+ $keyProp = $idProps->GetItem(0);
+ if (!$keyProp->IsAutoGenerated()) {
+ if ($clsProps->IndexOf("Text") < 0) {
} else {
- throw new Exception(GetLocalizedString("REDLINEUPLOADNOGEOMETRY", $locale));
//Set up default style args
More information about the fusion-commits
