[fusion-commits] r2662 - trunk/widgets/widgetinfo
svn_fusion at osgeo.org
Tue Mar 12 19:58:01 PDT 2013
Author: liuar
Date: 2013-03-12 19:58:01 -0700 (Tue, 12 Mar 2013)
New Revision: 2662
trunk/widgets/widgetinfo/cursorposition.xml
Submit on behalf of Andy Zhang. Integrate #2640 to trunk.
Set default value of DisplayProjection of widget CursorPosition to null.
The default value of DisplayProjection widget CursorPosition is EPSG:4326. If we don't change it manually, the cursor position is always displayed in EPSG:4326 format, which is not correct. Now we don't set the default value. The cursor position widget will get projection from map. Then the x, y value of cursor position is consistent with map CS.
Modified: trunk/widgets/widgetinfo/cursorposition.xml
--- trunk/widgets/widgetinfo/cursorposition.xml 2013-03-08 14:31:54 UTC (rev 2661)
+++ trunk/widgets/widgetinfo/cursorposition.xml 2013-03-13 02:58:01 UTC (rev 2662)
@@ -29,7 +29,7 @@
<Type>string</Type>
<Label>DisplayProjection</Label>
<Description>The projection to display mouse coordinates in. This can be an EPSG code (EPSG:XXXX) or a WKT string. This parameter takes precedence over the Units parameter if specified</Description>
- <DefaultValue>EPSG:4326</DefaultValue>
+ <DefaultValue></DefaultValue>
<IsMandatory>0</IsMandatory>
</Parameter>
<Parameter>
More information about the fusion-commits
