[fusion-commits] r2666 - in sandbox/ol212: . lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Mar 19 05:24:11 PDT 2013
Author: jng
Date: 2013-03-19 05:24:11 -0700 (Tue, 19 Mar 2013)
New Revision: 2666
Removed:
   sandbox/ol212/lib/IE9patch.js
   sandbox/ol212/build.xml
   sandbox/ol212/lib/fusion.js
IE9patch.js was put in due to some IE9-specific issue with MooTools (according to commit notes). Since we've internally upgraded JxLib's MooTools and the internally patched JxLib shows no side-effects, this patch file is no longer required.
Modified: sandbox/ol212/build.xml
--- sandbox/ol212/build.xml	2013-03-19 12:15:03 UTC (rev 2665)
+++ sandbox/ol212/build.xml	2013-03-19 12:24:11 UTC (rev 2666)
@@ -209,7 +209,6 @@
                           fusion.js
                           jxLib/jxlib.uncompressed.js
                           OpenLayers/OpenLayers.js
-                          IE9patch.js
                           Proj4js/proj4js-compressed.js
                           Error.js
                           EventMgr.js
Deleted: sandbox/ol212/lib/IE9patch.js
--- sandbox/ol212/lib/IE9patch.js	2013-03-19 12:15:03 UTC (rev 2665)
+++ sandbox/ol212/lib/IE9patch.js	2013-03-19 12:24:11 UTC (rev 2666)
@@ -1,28 +0,0 @@
-document.newElement = function(tag, props) {
-    var createdElement;
-    var temp = tag.split(' ').shift();//error in IE if tag has extra attributes listed
-                                      //just strip off the tag name, properties should
-                                      //set through the props argument
-    if (Browser.Engine.trident && props){
-        ['name', 'type', 'checked'].each(function(attribute){
-            if (!props[attribute]) return;
-            tag += ' ' + attribute + '="' + props[attribute] + '"';
-            if (attribute != 'checked') delete props[attribute];
-        var replaceTag = '<' + tag +'>';
-        try {
-            createdElement = this.createElement(replaceTag);
-        catch (e) {
-            createdElement = this.createElement(temp);
-    else {
-        createdElement = this.createElement(tag);
-    return document.id(this.createElement(temp)).set(props);
Modified: sandbox/ol212/lib/fusion.js
--- sandbox/ol212/lib/fusion.js	2013-03-19 12:15:03 UTC (rev 2665)
+++ sandbox/ol212/lib/fusion.js	2013-03-19 12:24:11 UTC (rev 2666)
@@ -1492,7 +1492,6 @@
     if (!Fusion._singleFile) {
         var coreScripts = [ 'lib/jxLib/jxlib.uncompressed.js', //JxLib has first dibs on any globals
                             'lib/OpenLayers/OpenLayers.js',
-                            'lib/IE9patch.js',
                             'lib/Proj4js/proj4js-compressed.js',
                             'lib/EventMgr.js',
                             'lib/Error.js',
More information about the fusion-commits mailing list
