[fusion-commits] r2673 - trunk/widgets/Query
svn_fusion at osgeo.org
Fri Mar 22 10:38:59 PDT 2013
Author: jng
Date: 2013-03-22 10:38:59 -0700 (Fri, 22 Mar 2013)
New Revision: 2673
trunk/widgets/Query/querymain.php
#550: Query: Use MapMessage prompts for spatial filter geometry digitization. Also cancel any active digitizations on unload()
Modified: trunk/widgets/Query/querymain.php
--- trunk/widgets/Query/querymain.php 2013-03-22 17:28:15 UTC (rev 2672)
+++ trunk/widgets/Query/querymain.php 2013-03-22 17:38:59 UTC (rev 2673)
@@ -61,6 +61,9 @@
$zoomLocal = GetLocalizedString('QUERYZOOM', $locale );
$selectLocal = GetLocalizedString('QUERYSELECT', $locale );
$errorLocal = GetLocalizedString('QUERYERROR', $locale );
+ $rectangleHelpLocal = GetLocalizedString('REDLINEEDITRECTANGLEHELP', $locale );
+ $polygonHelpLocal = GetLocalizedString('REDLINEEDITPOLYGONHELP', $locale );
try
@@ -177,11 +180,15 @@
function OnDigitizeRectangle()
ClearDigitization();
+ var map = Fusion.getMapByName(mapName).mapWidget;
+ map.message.info("<?= $rectangleHelpLocal ?>");
DigitizeRectangle(OnRectangleDigitized);
function OnRectangleDigitized(rectangle)
+ map.message.clear();
var geomText = "5,"
+ rectangle.Point1.X + "," + rectangle.Point1.Y + ","
+ rectangle.Point2.X + "," + rectangle.Point1.Y + ","
@@ -195,11 +202,15 @@
function OnDigitizePolygon()
+ map.message.info("<?= $polygonHelpLocal ?>");
DigitizePolygon(OnPolyonDigitized);
function OnPolyonDigitized(polygon)
var geomText = polygon.Count;
for (var i = 0; i < polygon.Count; i++)
@@ -404,6 +415,7 @@
function OnUnload()
+ ClearDigitization();
ToggleSpatialFilter(false);
More information about the fusion-commits
