[fusion-commits] r2680 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Mar 27 02:03:21 PDT 2013
Author: jng
Date: 2013-03-27 02:03:20 -0700 (Wed, 27 Mar 2013)
New Revision: 2680
   trunk/widgets/CenterSelection.js
#559: Fix stack overflow in CenterSelection widget and fix usage of broken APIs.
Modified: trunk/widgets/CenterSelection.js
--- trunk/widgets/CenterSelection.js	2013-03-26 10:58:48 UTC (rev 2679)
+++ trunk/widgets/CenterSelection.js	2013-03-27 09:03:20 UTC (rev 2680)
@@ -38,9 +38,8 @@
     uiClass: Jx.Button,
     initializeWidget: function(widgetTag) {
         //console.log('CenterSelection.initialize');
-        Fusion.Widget.prototype.initialize.apply(this, [widgetTag, false]);
-        Fusion.Widget.prototype.initialize.apply(this, []);
+        //Fusion.Widget.prototype.initialize.apply(this, [widgetTag, false]);
+        //Fusion.Widget.prototype.initialize.apply(this, []);
         this.enable = Fusion.Widget.CenterSelection.prototype.enable;
         this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_ON, OpenLayers.Function.bind(this.enable, this));
@@ -67,23 +66,34 @@
         var curWidth = extents[2] - extents[0];
         var curHeight = extents[3] - extents[1];
-        var ll = selection[map.getMapName()].getLowerLeftCoord();
-        var ur = selection[map.getMapName()].getUpperRightCoord();
+        var mapName = null;
+        var mlayers = map.getAllMaps();
+        for (var i = 0; i < mlayers.length; i++) {
+            if (mlayers[i].arch == "MapGuide") {
+                mapName = mlayers[i].getMapName();
+                break;
-        var newWidth = ur.x - ll.x;
-        var newHeight = ur.y - ll.y;
-        if (newWidth < curWidth && newHeight < curHeight) {
-            var cx = (ur.x + ll.x) / 2;
-            var cy = (ur.y + ll.y) / 2;
-            map.zoom(cx,cy,1);
-        } else {
-            var buffer = 0.1;
-            var minx = ll.x-newWidth*buffer;
-            var miny = ll.y-newHeight*buffer;
-            var maxx = ur.x+newWidth*buffer;
-            var maxy = ur.y+newHeight*buffer;
-            map.setExtents(new OpenLayers.Bounds(minx,miny,maxx,maxy));
+        if (mapName != null) {
+            var ll = selection[mapName].getLowerLeftCoord();
+            var ur = selection[mapName].getUpperRightCoord();
+            var newWidth = ur.x - ll.x;
+            var newHeight = ur.y - ll.y;
+            if (newWidth < curWidth && newHeight < curHeight) {
+                var cx = (ur.x + ll.x) / 2;
+                var cy = (ur.y + ll.y) / 2;
+                map.zoom(cx,cy,1);
+            } else {
+                var buffer = 0.1;
+                var minx = ll.x-newWidth*buffer;
+                var miny = ll.y-newHeight*buffer;
+                var maxx = ur.x+newWidth*buffer;
+                var maxy = ur.y+newHeight*buffer;
+                map.setExtents(new OpenLayers.Bounds(minx,miny,maxx,maxy));
More information about the fusion-commits mailing list
