[fusion-commits] r2697 - trunk/widgets
svn_fusion at osgeo.org
Fri May 10 00:09:06 PDT 2013
Author: liuar
Date: 2013-05-10 00:09:06 -0700 (Fri, 10 May 2013)
New Revision: 2697
trunk/widgets/SelectPolygon.js
Submit on behalf of Andy Zhang.
Select Polygon: Check vertex count of the polygon before executing query.
Modified: trunk/widgets/SelectPolygon.js
--- trunk/widgets/SelectPolygon.js 2013-05-10 06:19:02 UTC (rev 2696)
+++ trunk/widgets/SelectPolygon.js 2013-05-10 07:09:06 UTC (rev 2697)
@@ -117,8 +117,11 @@
execute: function(geom) {
var options = {};
+ var points = geom.getVertices();
+ if (points.length < 3) {
+ return;
options.geometry = geom.toString();
options.selectionType = this.selectionType;
options.computed = this.bComputeMetadata;
More information about the fusion-commits
