[fusion-commits] r2706 - in sandbox/createruntimemap: layers/MapGuide lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Sat May 18 03:16:16 PDT 2013
Author: jng
Date: 2013-05-18 03:16:16 -0700 (Sat, 18 May 2013)
New Revision: 2706
   sandbox/createruntimemap/layers/MapGuide/MapGuide.js
   sandbox/createruntimemap/lib/fusion.js
Ensure Fusion.Layer.MapGuide has access to the site version to do the native service support check under all possible initialization scenarios
Modified: sandbox/createruntimemap/layers/MapGuide/MapGuide.js
--- sandbox/createruntimemap/layers/MapGuide/MapGuide.js	2013-05-18 09:44:19 UTC (rev 2705)
+++ sandbox/createruntimemap/layers/MapGuide/MapGuide.js	2013-05-18 10:16:16 UTC (rev 2706)
@@ -124,6 +124,10 @@
         this.noCache = true;
         this.oLayersOLTile = [];
+        if (Fusion.siteVersion) {
+            this.siteVersion = Fusion.siteVersion;
+            this.checkNativeServiceSupport();
         var sid = Fusion.sessionId;
         if (sid) {
             this.session[0] = sid;
@@ -150,6 +154,24 @@
+    checkNativeServiceSupport: function() {
+        //NOTE: Using native services may cause a slight (but not too much) delay in any requests to PHP scripts
+        //that use layer property mappings as they will be lazy loaded due to us not calling LoadMap.php, which
+        //would've pre-cached such information. but we get much better map init performance
+        this.bUseNativeServices = false;
+        var vMajor = this.siteVersion[0];
+        var vMinor = this.siteVersion[1];
+        if (vMajor > 2) { // 3.0 or higher
+            this.bUseNativeServices = true;
+        } else {
+            if (vMajor == 2) { // 2.x
+                if (vMinor >= 6) { // >= 2.6
     createSessionCB: function(xhr) {
         if (xhr.status == 200) {
             var o = Fusion.parseJSON(xhr.responseText);
@@ -163,21 +185,7 @@
                                              parseInt(bits[2]),
                                              parseInt(bits[3])
-                //NOTE: Using native services may cause a slight (but not too much) delay in any requests to PHP scripts
-                //that use layer property mappings as they will be lazy loaded due to us not calling LoadMap.php, which
-                //would've pre-cached such information. but we get
-                this.bUseNativeServices = false;
-                var vMajor = this.siteVersion[0];
-                var vMinor = this.siteVersion[1];
-                if (vMajor > 2) { // 3.0 or higher
-                    this.bUseNativeServices = true;
-                } else {
-                    if (vMajor == 2) { // 2.x
-                        if (vMinor >= 6) { // >= 2.6
                 this.session[0] = o.sessionId;
                 var acceptLang = o.acceptLanguage.split(',');
                 //IE - en-ca,en-us;q=0.8,fr;q=0.5,fr-ca;q=0.3
Modified: sandbox/createruntimemap/lib/fusion.js
--- sandbox/createruntimemap/lib/fusion.js	2013-05-18 09:44:19 UTC (rev 2705)
+++ sandbox/createruntimemap/lib/fusion.js	2013-05-18 10:16:16 UTC (rev 2706)
@@ -1605,38 +1605,65 @@
         xhr.open("GET", url, false);
         xhr.send(null);
-        var o;
-        eval('o='+xhr.responseText);
+        var o = Fusion.parseJSON(xhr.responseText);
         Fusion.sessionId = o.sessionId;
+        var version = o.siteVersion;
+        var bits = version.split('.');
+        Fusion.siteVersion = new Array(parseInt(bits[0]),
+                                       parseInt(bits[1]),
+                                       parseInt(bits[2]),
+                                       parseInt(bits[3])
     var appDefUrl = Fusion.getQueryParam('ApplicationDefinition');
-    if(appDefUrl && (
+    if (appDefUrl && (
         appDefUrl.indexOf('Library') == 0 ||
-        appDefUrl.indexOf('Session') == 0)){
+        appDefUrl.indexOf('Session') == 0)) {
+        var fetchAppDef = function(appDefUrl, sessionId) {
+            var xhr = new getXmlHttpRequest();
+            var mapAgentUrl = getAgentUrl();
+            xhr.open("GET", mapAgentUrl + "?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=" + appDefUrl + "&FORMAT=text%2Fxml&SESSION="+ sessionId, false);
+            xhr.send(null);
+            var appDefXML = xhr.responseXML.documentElement;
+            if (appDefXML) {
+                var googleElement = appDefXML.getElementsByTagName("GoogleScript")[0];
+                var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
+                var veElement = appDefXML.getElementsByTagName("VirtualEarthScript")[0];
+                var osmElement = appDefXML.getElementsByTagName("OpenStreetMapScript")[0];
+                addElement(googleElement);
+                addElement(yahooElement);
+                addElement(veElement);
+                addElement(osmElement);
+        var getSiteVersion = function(sessionId) {
+            xhr.open("GET", mapAgentUrl + "?OPERATION=GETSITEVERSION&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&SESSION="+ sessionId, false);
+            xhr.send(null);
+            var verXML = xhr.responseXML.documentElement;
+            var el = verXML.getElementsByTagName("Version")[0];
+            var version = el.textContent || el.text;
+            return new Array(parseInt(bits[0]),
+                             parseInt(bits[3]));
         var passedSessionId = Fusion.getQueryParam('Session');
-        if(passedSessionId == null || passedSessionId == "" ){
+        if (passedSessionId == null || passedSessionId == "" ){
             createSessionId(Fusion.getQueryParam("Username"), Fusion.getQueryParam("Password"));
-        }else{
+        } else {
             Fusion.sessionId = passedSessionId;
+            Fusion.siteVersion = getSiteVersion(passedSessionId);
-        var xhr = new getXmlHttpRequest();
-        var mapAgentUrl = getAgentUrl();
-        xhr.open("GET", mapAgentUrl + "?OPERATION=GETRESOURCECONTENT&VERSION=1.0.0&LOCALE=en&CLIENTAGENT=MapGuide+Developer&RESOURCEID=" + appDefUrl + "&FORMAT=text%2Fxml&SESSION="+ Fusion.sessionId, false);
-        xhr.send(null);
-        var appDefXML = xhr.responseXML.documentElement;
-        if(appDefXML){
-            var googleElement = appDefXML.getElementsByTagName("GoogleScript")[0];
-            var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
-            var veElement = appDefXML.getElementsByTagName("VirtualEarthScript")[0];
-            var osmElement = appDefXML.getElementsByTagName("OpenStreetMapScript")[0];
-            addElement(googleElement);
-            addElement(yahooElement);
-            addElement(veElement);
-            addElement(osmElement);
+        fetchAppDef(appDefUrl, Fusion.sessionId);
More information about the fusion-commits mailing list
