[fusion-commits] r2718 - trunk/layers/MapGuide
svn_fusion at osgeo.org
Mon May 27 21:24:15 PDT 2013
Author: jng
Date: 2013-05-27 21:24:15 -0700 (Mon, 27 May 2013)
New Revision: 2718
trunk/layers/MapGuide/MapGuide.js
#434: Proj4js is a EPSG-driven system (or at least it works much better with EPSG codes). So when initializing our projection in Fusion.Layers.MapGuide, if we have an EPSG code and a WKT string available, the EPSG code takes precedence.
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2013-05-28 04:20:48 UTC (rev 2717)
+++ trunk/layers/MapGuide/MapGuide.js 2013-05-28 04:24:15 UTC (rev 2718)
@@ -332,10 +332,17 @@
//set projection units and code if supplied
var wktProj;
if (o.wkt && o.wkt.length > 0){
- wktProj = new OpenLayers.Projection(o.wkt);
+ //Proj4js prefers EPSG codes over raw WKT. So if an EPSG code exists, use that over the WKT
+ if (o.epsg != 0) {
+ wktProj = new OpenLayers.Projection("EPSG:" + o.epsg);
+ this.mapTag.layerOptions.projection = "EPSG:" + o.epsg;
+ } else {
+ wktProj = new OpenLayers.Projection(o.wkt);
if (!wktProj || (wktProj && wktProj.proj && !wktProj.proj.readyToUse)) {
if (o.epsg != 0) {
} else {
//default to the local non-projected system if not otherwise specified
More information about the fusion-commits
