[fusion-commits] r2721 - trunk/lib
svn_fusion at osgeo.org
Tue May 28 23:54:18 PDT 2013
Author: jng
Date: 2013-05-28 23:54:18 -0700 (Tue, 28 May 2013)
New Revision: 2721
trunk/lib/Map.js
#570: Add digitization APIs to the Map widget. The new APIs are:
* digitizePoint/digitizeLine/digitizeLineString/digitizeRectangle/digitizePolygon - Performs the digitization and passes the digitized OpenLayers.Geometry to the supplied callback function. These APIs include a options parameter where a prompt can be specified. If specified, the MapMessage component is used to display the prompt for the duration of digitization.
* cancelDigitization - To cancel the digitization process. A keypress handler has been added so that ESC keypress hooks into this function.
* isDigitizing - Indicates if digitization is in process
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js 2013-05-29 03:53:11 UTC (rev 2720)
+++ trunk/lib/Map.js 2013-05-29 06:54:18 UTC (rev 2721)
@@ -127,6 +127,13 @@
Fusion.Widget.Map = OpenLayers.Class(Fusion.Lib.EventMgr, {
+ ID_DIGITIZING_LAYER: "FusionMapDigitizingLayer",
+ DRAW_CONTROL_POINT: "FusionMapDrawPoint",
+ DRAW_CONTROL_LINE: "FusionMapDrawLine",
+ DRAW_CONTROL_LINESTR: "FusionMapDrawLineString",
+ DRAW_CONTROL_RECT: "FusionMapDrawRect",
+ DRAW_CONTROL_POLY: "FusionMapDrawPoly",
/** The DOM object that holds the map */
_oDomObj: null,
@@ -181,12 +188,22 @@
maxScale: null, //set this to a large number in AppDef to zoom out beyond maxExtent, e.g. 1 billion
+ * Property: isDigitizing
+ * Gets whether a digitizer is currently active
+ isDigitizing: false,
* Property: message
* The {<Fusion.MapMessage>} notification bar
message: null,
+ /** The OL style map for digitizing **/
+ digitizingStyleMap: null,
* construct a new view Fusion.Widget.Map class.
@@ -306,6 +323,19 @@
this.aSelectionCallbacks = [];
this.bFetchingSelection = false;
+ //Create style map
+ this.digitizingStyleMap = new OpenLayers.StyleMap(new OpenLayers.Style({
+ pointRadius: 4,
+ graphicName: "square",
+ fillColor: "white",
+ fillOpacity: 0.4,
+ strokeWidth: 2,
+ strokeOpacity: 1,
+ strokeColor: "#666666",
+ this.keyHandler = OpenLayers.Function.bind(this.onKeyPress, this);
//create the 'Map' layer widgets defined in the MapGroup
this.loadMapGroup(mapGroup);
@@ -320,8 +350,8 @@
* Return: none
mapLoaded: function() {
- this.setViewOptions(this.getUnits());
- this.loadScaleRanges(OpenLayers.Function.bind(this.scaleRangesLoaded, this));
+ this.setViewOptions(this.getUnits());
+ this.loadScaleRanges(OpenLayers.Function.bind(this.scaleRangesLoaded, this));
@@ -578,6 +608,9 @@
var initialExtent = this.setInitialExtents();
this.setExtents(initialExtent);
+ //Start observing keypresses
+ OpenLayers.Event.observe(document,"keypress",this.keyHandler);
this.triggerEvent(Fusion.Event.MAP_LOADED, mapTag);
@@ -1646,28 +1679,287 @@
return OpenLayers.Util.getParameterString(queryParams);
- supressContextMenu: function( bSupress ) {
- this.bSupressContextMenu = bSupress;
+ supressContextMenu: function( bSupress ) {
+ this.bSupressContextMenu = bSupress;
- setContextMenu: function(menu) {
- //console.log('setcontextmenu');
- this.oContextMenu = menu;
+ setContextMenu: function(menu) {
+ //console.log('setcontextmenu');
+ this.oContextMenu = menu;
- onContextMenu: function(e) {
- //console.log('oncontextmenu');
- if (this.oContextMenu && !this.bSupressContextMenu && this.isLoaded()) {
- this.oContextMenu.show(new Event(e));
- this.contextMenuPosition = this.getEventPosition(e);
- OpenLayers.Event.stop(e);
+ onContextMenu: function(e) {
+ //console.log('oncontextmenu');
+ if (this.oContextMenu && !this.bSupressContextMenu && this.isLoaded()) {
+ this.oContextMenu.show(new Event(e));
+ this.contextMenuPosition = this.getEventPosition(e);
+ OpenLayers.Event.stop(e);
- executeFromContextMenu: function(widget) {
- //console.log('executefromcontextmenu');
- widget.activate(this.contextMenuPosition.x, this.contextMenuPosition.y);
+ executeFromContextMenu: function(widget) {
+ //console.log('executefromcontextmenu');
+ widget.activate(this.contextMenuPosition.x, this.contextMenuPosition.y);
+ _getDigitizingLayer: function() {
+ var layer = this.oMapOL.getLayer(this.ID_DIGITIZING_LAYER);
+ if (layer == null) {
+ layer = new OpenLayers.Layer.Vector("Digitizing Layer", { styleMap: this.digitizingStyleMap });
+ this.oMapOL.addLayers([layer]);
+ return layer;
+ * Method: cancelDigitization
+ * De-activates any active digitizers
+ cancelDigitization: function() {
+ //Don't trigger until the end
+ this._deactivateDigitizer(this.DRAW_CONTROL_POINT, false, true);
+ this._deactivateDigitizer(this.DRAW_CONTROL_LINE, false, true);
+ this._deactivateDigitizer(this.DRAW_CONTROL_LINESTR, false, true);
+ this._deactivateDigitizer(this.DRAW_CONTROL_RECT, false, true);
+ this._deactivateDigitizer(this.DRAW_CONTROL_POLY, false, true);
+ this._triggerDigitizerDeactivated();
+ _onGeometryDigitized: function(evt, controlId, origCallback) {
+ this._deactivateDigitizer(controlId, true, true);
+ origCallback(evt.feature.geometry);
+ _setDigitizationPrompt: function(prompt) {
+ this.message.info(prompt + ' <a id="abortDigitizationLink" href="javascript:void(0)">' + OpenLayers.i18n("stop") + '</a>');
+ var link = this.message.container.ownerDocument.getElementById("abortDigitizationLink");
+ //Wire the anchor click
+ link.onclick = OpenLayers.Function.bind(function() {
+ this.cancelDigitization();
+ }, this);
+ _deactivateDigitizer: function(controlId, bTrigger, bUnsub) {
+ var ctrl = this.oMapOL.getControl(controlId);
+ if (ctrl) {
+ ctrl.deactivate();
+ ctrl.layer.removeAllFeatures();
+ if (bUnsub)
+ ctrl.events.remove("featureadded");
+ if (bTrigger)
+ _activateDigitizer: function(ctrl, controlId, origCallback) {
+ //Register for one-shot callback notification
+ if (ctrl.events) {
+ var oneShotHandler = OpenLayers.Function.bind(function(cid, evt) {
+ ctrl.events.unregister("featureadded", null, oneShotHandler);
+ console.log("De-registered one-shot callback for: " + cid)
+ this._onGeometryDigitized(evt, cid, origCallback);
+ }, this, controlId);
+ ctrl.events.register("featureadded", null, oneShotHandler);
+ console.log("Register one-shot callback for: " + controlId);
+ ctrl.activate();
+ this._triggerDigitizerActivated();
+ _triggerDigitizerActivated: function() {
+ this.isDigitizing = true;
+ this.triggerEvent(Fusion.Event.MAP_DIGITIZER_ACTIVATED);
+ console.log("digitizer activated")
+ _triggerDigitizerDeactivated: function() {
+ this.isDigitizing = false;
+ try {
+ this.message.clear();
+ } catch (e) {}
+ this.triggerEvent(Fusion.Event.MAP_DIGITIZER_DEACTIVATED);
+ console.log("digitizer de-activated")
+ onKeyPress: function(e) {
+ if (this.isDigitizing) {
+ var charCode = (e.charCode) ? e.charCode : ((e.keyCode) ? e.keyCode : e.which);
+ if (charCode == OpenLayers.Event.KEY_ESC) {
+ * Method: digitizePoint
+ * Digitizes a point and passes the value to a function for processing. Digitization can be cancelled via the cancelDigitization()
+ * method or via pressing the ESC key
+ * Parameters:
+ * callback - {Function} The callback function that will receive the digitized geometry
+ * Return:
+ * {OpenLayers.Geometry.Point}
+ digitizePoint: function(options, callback) {
+ var ctrl = this.oMapOL.getControl(this.DRAW_CONTROL_POINT);
+ if (ctrl == null) {
+ ctrl = new OpenLayers.Control.DrawFeature(
+ this._getDigitizingLayer(),
+ OpenLayers.Handler.Point, {
+ id: this.DRAW_CONTROL_POINT,
+ handlerOptions: {
+ layerOptions: {
+ styleMap: this.digitizingStyleMap
+ this.oMapOL.addControl(ctrl);
+ if (options.prompt) {
+ this._setDigitizationPrompt(options.prompt);
+ this._activateDigitizer(ctrl, this.DRAW_CONTROL_POINT, callback);
+ * Method: digitizeLine
+ * Digitizes a line and passes the value to a function for processing. Digitization can be cancelled via the cancelDigitization()
+ * Parameters:
+ * options - {Object} digitization options
+ * Return:
+ * {OpenLayers.Geometry.LineString}
+ digitizeLine: function(options, callback) {
+ var ctrl = this.oMapOL.getControl(this.DRAW_CONTROL_LINE);
+ OpenLayers.Handler.Path, {
+ id: this.DRAW_CONTROL_LINE,
+ handlerOptions: {
+ maxVertices: 2,
+ freehandToggle: null,
+ freehand: false,
+ persist: true,
+ style: "default", // this forces default render intent
+ layerOptions: {
+ this._activateDigitizer(ctrl, this.DRAW_CONTROL_LINE, callback);
+ * Method: digitizeLineString
+ * Digitizes a line string and passes the value to a function for processing. Digitization can be cancelled via the cancelDigitization()
+ * Parameters:
+ * Return:
+ digitizeLineString: function(options, callback) {
+ var ctrl = this.oMapOL.getControl(this.DRAW_CONTROL_LINESTR);
+ id: this.DRAW_CONTROL_LINESTR,
+ handlerOptions: {
+ freehand: false,
+ persist: true,
+ layerOptions: {
+ this._activateDigitizer(ctrl, this.DRAW_CONTROL_LINESTR, callback);
+ * Method: digitizeRectangle
+ * Digitizes a rectangle and passes the value to a function for processing. Digitization can be cancelled via the cancelDigitization()
+ * Parameters:
+ * Return:
+ * {OpenLayers.Geometry.Polygon}
+ digitizeRectangle: function(options, callback) {
+ var ctrl = this.oMapOL.getControl(this.DRAW_CONTROL_RECT);
+ OpenLayers.Handler.RegularPolygon, {
+ id: this.DRAW_CONTROL_RECT,
+ handlerOptions: {
+ persist: true,
+ sides: 4,
+ irregular: true,
+ layerOptions: {
+ this._activateDigitizer(ctrl, this.DRAW_CONTROL_RECT, callback);
+ * Method: digitizePolygon
+ * Digitizes a polygon and passes the value to a function for processing. Digitization can be cancelled via the cancelDigitization()
+ * Parameters:
+ * Return:
+ digitizePolygon: function(options, callback) {
+ var ctrl = this.oMapOL.getControl(this.DRAW_CONTROL_POLY);
+ OpenLayers.Handler.Polygon, {
+ id: this.DRAW_CONTROL_POLY,
+ handlerOptions: {
+ freehand: false,
+ persist: true,
+ layerOptions: {
+ this._activateDigitizer(ctrl, this.DRAW_CONTROL_POLY, callback);
More information about the fusion-commits
