[fusion-commits] r2723 - trunk/layers/MapGuide
svn_fusion at osgeo.org
Wed May 29 00:20:23 PDT 2013
Author: jng
Date: 2013-05-29 00:20:22 -0700 (Wed, 29 May 2013)
New Revision: 2723
trunk/layers/MapGuide/MapGuideViewerApi.js
#569: Fix up MapGuideViewerApi.js. The existing digitization APIs now wrap the new digitization APIs of the Map widget (#570). This eliminates a whole bunch of problematic code involving digitization state (since the Map widget handles all that now) and faux-global vars because of the various ways this script could be referenced, all while presenting the same identical public API for client-side code that uses this script.
Modified: trunk/layers/MapGuide/MapGuideViewerApi.js
--- trunk/layers/MapGuide/MapGuideViewerApi.js 2013-05-29 07:15:07 UTC (rev 2722)
+++ trunk/layers/MapGuide/MapGuideViewerApi.js 2013-05-29 07:20:22 UTC (rev 2723)
@@ -27,11 +27,6 @@
* This is a simple API layer to mimick the MapGuide ajaxviewer API
var mgApiMapWidgetId = 'Map';
-var mgApiActiveWidget = null;
-var mgApiActiveControl = null;
-var mgApiDrawControls;
-var mgApiDigitizingLayer = null;
-var mgApiInitialized = false;
var MainFusionWindow = GetFusionWindow();
var OpenLayers = MainFusionWindow.OpenLayers;
var Fusion = MainFusionWindow.Fusion;
@@ -40,7 +35,7 @@
function Refresh() {
//var Fusion = window.top.Fusion;
- var mapWidget = Fusion.getWidgetById(mgApiMapWidgetId);
+ var mapWidget = GetFusionMapWidget();
if (mapWidget && mapWidget.isMapLoaded()) {
mapWidget.redraw();
@@ -48,7 +43,7 @@
function SetSelectionXML(selectionXml) {
mapWidget.setSelection(selectionXml, true);
@@ -56,7 +51,7 @@
function ZoomToView(x, y, scale, refresh) {
var extent = mapWidget.getExtentFromPoint(x, y, scale);
mapWidget.setExtents(extent);
@@ -64,31 +59,37 @@
function DigitizePoint(handler) {
- mgApiStartDigitizing('point', handler)
+ GetFusionMapWidget().digitizePoint({}, function(olGeom) {
+ mgApiCallHandler(olGeom, 'point', handler);
function DigitizeLine(handler) {
- mgApiStartDigitizing('line', handler)
+ GetFusionMapWidget().digitizeLine({}, function(olGeom) {
+ mgApiCallHandler(olGeom, 'line', handler);
function DigitizeLineString(handler) {
- mgApiStartDigitizing('linestr', handler)
+ GetFusionMapWidget().digitizeLineString({}, function(olGeom) {
+ mgApiCallHandler(olGeom, 'linestr', handler);
function DigitizeRectangle(handler) {
- mgApiStartDigitizing('rectangle', handler)
+ GetFusionMapWidget().digitizeRectangle({}, function(olGeom) {
+ mgApiCallHandler(olGeom, 'rect', handler);
function DigitizePolygon(handler) {
- mgApiStartDigitizing('polygon', handler)
+ GetFusionMapWidget().digitizePolygon({}, function(olGeom) {
+ mgApiCallHandler(olGeom, 'polygon', handler);
function ClearDigitization(bCancelHandler) {
- if (mgApiDigitizingLayer) {
- mgApiDigitizingLayer.removeFeatures(mgApiDigitizingLayer.features);
- if (bCancelHandler)
- mgApiDeactivate();
+ GetFusionMapWidget().cancelDigitization();
//Theses are the Geometry classes used in the MapGuide Viewer API
@@ -141,168 +142,39 @@
this.LineStringInfo();
-//The following methods are private and not intended for use by applications
-function mgApiStartDigitizing(type, handler) {
- mgApiInit();
- if (handler) {
- //var Fusion = window.top.Fusion;
- mgApiActiveWidget = mapWidget.oActiveWidget;
- if (mgApiActiveWidget) {
- mapWidget.deactivateWidget(mgApiActiveWidget);
- mapWidget.triggerEvent(Fusion.Event.MAP_DIGITIZER_ACTIVATED);
- var control = mgApiDrawControls[type];
- control.userHandler = handler;
- mgApiActiveControl = control;
- control.activate();
+//---------------------- Private API ------------------------ //
-function mgApiCallHandler(evt) {
- var geom = evt.feature.geometry;
- var apiGeom = null;
- if (this.handler.CLASS_NAME == 'OpenLayers.Handler.RegularPolygon') {
- var v = geom.getVertices();
- apiGeom = new Rectangle(new Point(v[0].x, v[0].y), new Point(v[2].x, v[2].y));
- } else {
- switch (geom.CLASS_NAME) {
- case 'OpenLayers.Geometry.Point':
- apiGeom = new Point(geom.x, geom.y);
- break;
- case 'OpenLayers.Geometry.LineString':
- apiGeom = new LineString();
- for (var i=0; i<v.length; ++i) {
- apiGeom.AddPoint(new Point(v[i].x, v[i].y));
- break;
- case 'OpenLayers.Geometry.Polygon':
- break;
- this.userHandler(apiGeom);
- //deactivate the control in a separate thread so that the chain of event
- //handlers has a chance to finish before the deactivation occurs
- window.setTimeout(mgApiDeactivate, 100);
- return false;
-function mgApiDeactivate() {
- if (mgApiActiveControl) {
- mgApiActiveControl.deactivate();
- mgApiActiveControl = null;
+//This function converts the digitized OL geometry into the AJAX viewer geometry model
+function mgApiCallHandler(geom, geomType, handler) {
+ var apiGeom = null;
+ if (geomType == 'rect') {
+ var v = geom.getVertices();
+ apiGeom = new Rectangle(new Point(v[0].x, v[0].y), new Point(v[2].x, v[2].y));
+ } else {
+ switch (geom.CLASS_NAME) {
+ case 'OpenLayers.Geometry.Point':
+ apiGeom = new Point(geom.x, geom.y);
+ break;
+ case 'OpenLayers.Geometry.LineString':
+ apiGeom = new LineString();
+ for (var i=0; i<v.length; ++i) {
+ apiGeom.AddPoint(new Point(v[i].x, v[i].y));
+ break;
+ case 'OpenLayers.Geometry.Polygon':
+ break;
- mapWidget.activateWidget(mgApiActiveWidget);
- mgApiActiveWidget = null;
- mapWidget.triggerEvent(Fusion.Event.MAP_DIGITIZER_DEACTIVATED);
+ handler(apiGeom);
+ return false;
-// set the Stylemap for the MGAPI
-var mgApiStyle = new OpenLayers.Style({
- pointRadius: 4,
- graphicName: "square",
- fillColor: "white",
- fillOpacity: 0.4,
- strokeWidth: 2,
- strokeOpacity: 1,
- strokeColor: "#666666"
-var mgApiStyleMap = new OpenLayers.StyleMap(mgApiStyle);
-Fusion.registerForEvent(Fusion.Event.FUSION_INITIALIZED, mgApiInit);
-//set up of digitizing tools once everything is initialized
-function mgApiInit() {
- if (mgApiInitialized) {
- return;
- mgApiInitialized = true;
- var map = Fusion.getWidgetById(mgApiMapWidgetId).oMapOL;
- mgApiDigitizingLayer = new OpenLayers.Layer.Vector("Digitizing Layer", {styleMap: mgApiStyleMap});
- map.addLayers([mgApiDigitizingLayer]);
- mgApiDrawControls = {
- point: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayer,
- OpenLayers.Handler.Point, {
- handlerOptions: {
- layerOptions: {
- styleMap: mgApiStyleMap
- line: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayer,
- OpenLayers.Handler.Path, {
- handlerOptions: {
- maxVertices: 2,
- freehandToggle: null,
- freehand: false,
- persist: true,
- style: "default", // this forces default render intent
- layerOptions: {
- linestr: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayer,
- handlerOptions: {
- freehand: false,
- persist: true,
- layerOptions: {
- rectangle: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayer,
- OpenLayers.Handler.RegularPolygon, {
- handlerOptions: {
- persist: true,
- sides: 4,
- irregular: true,
- layerOptions: {
- polygon: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayer,
- OpenLayers.Handler.Polygon, {
- handlerOptions: {
- freehand: false,
- persist: true,
- layerOptions: {
- for(var key in mgApiDrawControls) {
- if (mgApiDrawControls[key].events) {
- mgApiDrawControls[key].events.register('featureadded', null, mgApiCallHandler);
- map.addControl(mgApiDrawControls[key]);
/* locate the Fusion window */
function GetFusionWindow() {
var curWindow = window;
More information about the fusion-commits
