[fusion-commits] r2725 - in trunk: layers/MapGuide lib
svn_fusion at osgeo.org
Thu May 30 00:37:05 PDT 2013
Author: jng
Date: 2013-05-30 00:37:05 -0700 (Thu, 30 May 2013)
New Revision: 2725
trunk/layers/MapGuide/MapGuide.js
trunk/lib/MGBroker.js
MapGuide RFC 126: Merge QUERYMAPFEATURES v2.6 sandbox
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2013-05-29 08:25:25 UTC (rev 2724)
+++ trunk/layers/MapGuide/MapGuide.js 2013-05-30 07:37:05 UTC (rev 2725)
@@ -971,26 +971,28 @@
* given, all the elemsnts will be returned.
getSelection: function(userFunc, layers, startcount) {
- /*for now always go back to server to fetch selection */
- if (userFunc)
- //this.aSelectionCallbacks.push(userFunc);
- //this.mapWidget._addWorker();
- // this._bSelectionIsLoading = true;
- var s = 'layers/' + this.arch + '/' + Fusion.getScriptLanguage() + "/Selection." + Fusion.getScriptLanguage() ;
- var options = {
- parameters: {'session': this.getSessionID(),
- 'mapname': this._sMapname,
- 'layers': layers,
- 'startcount': startcount},
- onSuccess: OpenLayers.Function.bind(this.getSelectionCB, this, userFunc)
- Fusion.ajaxRequest(s, options);
+ /*for now always go back to server to fetch selection */
+ if (userFunc)
+ if (this.previousAttributes) {
+ userFunc(new Fusion.SelectionObject(this.previousAttributes));
+ } else {
+ //this.aSelectionCallbacks.push(userFunc);
+ //this.mapWidget._addWorker();
+ // this._bSelectionIsLoading = true;
+ var s = 'layers/' + this.arch + '/' + Fusion.getScriptLanguage() + "/Selection." + Fusion.getScriptLanguage() ;
+ var options = {
+ parameters: {
+ 'session': this.getSessionID(),
+ 'mapname': this._sMapname,
+ 'layers': layers,
+ 'startcount': startcount
+ onSuccess: OpenLayers.Function.bind(this.getSelectionCB, this, userFunc)
+ Fusion.ajaxRequest(s, options);
@@ -1049,6 +1051,14 @@
this.processSelectedFeatureProperties(r);
+ processSelectedFeaturePropertiesNode: function(oNode) {
+ if (oNode.hasSelection) {
+ this.newSelection();
+ } else {
+ this.clearSelection();
Call back function when select functions are called (eg queryRect)
to handle feature attributes
@@ -1057,13 +1067,7 @@
this.mapWidget._removeWorker();
if (r.responseText) { //TODO: make the equivalent change to MapServer.js
var oNode = Fusion.parseJSON(r.responseText);
- if (oNode.hasSelection) {
- this.newSelection();
- } else {
- this.clearSelection();
- return;
+ this.processSelectedFeaturePropertiesNode(oNode);
@@ -1117,6 +1121,25 @@
+ * Checks if we can perform a v2.6.0 QUERYMAPFEATURES request. A v2.6.0 QUERYMAPFEATURES request gives us
+ * - All attributes of selected features if requested (bypassing several follow-up requests to PHP scripts to get this data)
+ * - Slimmer maptip requests.
+ * A much better option, if it is available to us.
+ supportsExtendedQuery: function() {
+ var bSupportsExtended = false;
+ if (this.siteVersion[0] >= 2) { //2.x or higher
+ if (this.siteVersion[0] == 2) { //Major is 2
+ if (this.siteVersion[1] >= 6) { //2.6 or higher 2.x
+ bSupportsExtended = true;
+ } else { //3.x, 4.x, etc
+ return bSupportsExtended;
Do a query on the map
@@ -1140,7 +1163,13 @@
options.filter = '';
- var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(this.getSessionID(),
+ if (this.supportsExtendedQuery()) {
+ var reqData = 1; //attributes
+ //TODO: Can't use inline selection image yet as we'll have to modify OpenLayers to accept an inline selection
+ //over doing a GETDYNAMICMAPOVERLAYIMAGE request. When we can, or the value of 2 into the mask for inline
+ //selection as well
+ var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures2(this.getSessionID(),
this._sMapname,
options.geometry,
maxFeatures,
@@ -1148,9 +1177,25 @@
options.selectionType || this.selectionType,
options.filter,
options.layers,
+ layerAttributeFilter,
+ reqData,
+ this.selectionColor,
+ this.selectionImageFormat);
+ var callback = (options.extendSelection == true) ? OpenLayers.Function.bind(this.processAndMergeExtendedFeatureInfo, this) : OpenLayers.Function.bind(this.processExtendedFeatureInfo, this);
+ Fusion.oBroker.dispatchRequest(r, callback);
+ } else {
+ var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(this.getSessionID(),
+ this._sMapname,
+ options.geometry,
+ maxFeatures,
+ persist,
+ options.selectionType || this.selectionType,
+ options.filter,
+ options.layers,
layerAttributeFilter);
- var callback = (options.extendSelection == true) ? OpenLayers.Function.bind(this.processAndMergeFeatureInfo, this) : OpenLayers.Function.bind(this.processFeatureInfo, this);
- Fusion.oBroker.dispatchRequest(r, callback);
+ var callback = (options.extendSelection == true) ? OpenLayers.Function.bind(this.processAndMergeFeatureInfo, this) : OpenLayers.Function.bind(this.processFeatureInfo, this);
showLayer: function( layer, noDraw ) {
@@ -1210,7 +1255,7 @@
this.drawMap();
* called when there is a click on the map holding the CTRL key: query features at that postion.
mouseUpCRTLClick: function(evt) {
@@ -1353,12 +1398,25 @@
var layerAttributeFilter = 5;
//TODO: possibly make the layer names configurable?
var layerNames = mapTipWidget.aLayers.toString();
- this._sMapname,
- sGeometry,
- maxFeatures, persist, selection, filter, layerNames,
- layerAttributeFilter);
- oBroker.dispatchRequest(r, OpenLayers.Function.bind(this.parseMapTip, this));
+ var reqData = (4 | 8); //Tooltips and hyperlinks
+ this._sMapname,
+ sGeometry,
+ maxFeatures, persist, selection, filter, layerNames,
+ reqData,
+ oBroker.dispatchRequest(r, OpenLayers.Function.bind(this.parseMapTip, this));
+ } else {
+ this._sMapname,
+ sGeometry,
+ layerAttributeFilter);
parseMapTip: function(xhr) {
@@ -1408,10 +1466,138 @@
return url;
+ typeNameToValue: function(name) {
+ switch(name) { //Values from MgPropertyType
+ case "byte":
+ return 2;
+ case "boolean":
+ return 1;
+ case "blob":
+ return 10;
+ case "clob":
+ return 11;
+ case "datetime":
+ return 3;
+ case "double":
+ return 5;
+ case "int16":
+ return 6;
+ case "int32":
+ return 7;
+ case "int64":
+ return 8;
+ case "single":
+ return 4;
+ case "string":
+ return 9;
+ return -1;
+ convertExtendedFeatureInfo: function(efi) {
+ var bHasSelection = false;
+ var result = {};
+ var layerNames = [];
+ var featuresByLayer = {};
+ if (efi.FeatureInformation.SelectedFeatures) {
+ var selLayers = efi.FeatureInformation.SelectedFeatures[0].SelectedLayer;
+ bHasSelection = (selLayers.length > 0);
+ var box = new OpenLayers.Bounds();
+ for (var i = 0; i < selLayers.length; i++) {
+ var selLayer = selLayers[i];
+ var layerName = selLayer["@name"];
+ if (!result[layerName]) {
+ var layerMeta = selLayer.LayerMetadata[0];
+ var pnames = [];
+ var ptypes = [];
+ var pvals = [];
+ for (var j = 0; j < layerMeta.Property.length; j++) {
+ var metaProp = layerMeta.Property[j];
+ pnames.push(metaProp.Name[0]);
+ ptypes.push(metaProp.Type[0]);
+ pvals.push(metaProp.DisplayName[0]);
+ result[layerName] = {
+ metadata: [], //NOTE: Probably a defect, but regular code path is putting blank string arrays here too
+ metadatanames: ["dimension", "bbox", "center", "area", "length"],
+ numelements: selLayer.Feature.length,
+ propertynames: pnames,
+ propertytypes: ptypes,
+ propertyvalues: pvals,
+ values: []
+ layerNames.push(layerName);
+ for (var j = 0; j < selLayer.Feature.length; j++) {
+ var feat = selLayer.Feature[j];
+ var featVals = [];
+ for (var k = 0; k < feat.Property.length; k++) {
+ //Fusion represents null as empty string. Don't think that's right but we'll run with whatever
+ //the old code path produces
+ featVals.push(feat.Property[k].Value == null ? "" : feat.Property[k].Value[0]);
+ result[layerName].values.push(featVals);
+ //NOTE: Probably a defect, but regular code path is putting blank string arrays here too, so let's do the same
+ result[layerName].metadata.push(["","","","",""]);
+ var bounds = feat.Bounds[0].split(" "); //minx miny maxx maxy
+ box.extend(new OpenLayers.LonLat(parseFloat(bounds[0]), parseFloat(bounds[1])));
+ box.extend(new OpenLayers.LonLat(parseFloat(bounds[2]), parseFloat(bounds[3])));
+ return OpenLayers.Util.extend(result, {
+ hasSelection: bHasSelection,
+ extents: {
+ minx: box.left,
+ miny: box.bottom,
+ maxx: box.right,
+ maxy: box.top
+ layers: layerNames
+ } else {
+ result.hasSelection = false;
+ return result;
+ processAndMergeExtendedFeatureInfo: function(r) {
+ this.processSelectedExtendedFeatureInfo(r, true);
+ //this.processSelectedFeatureInfo(r, true);
+ processExtendedFeatureInfo: function(r) {
+ this.processSelectedExtendedFeatureInfo(r, false);
+ //this.processSelectedFeatureInfo(r, false);
+ processSelectedExtendedFeatureInfo: function(r, mergeSelection) {
+ var o = Fusion.parseJSON(r.responseText);
+ var sel = new Fusion.SimpleSelectionObject(o);
+ var attributes = this.convertExtendedFeatureInfo(o);
+ var selText = sel.getSelectionXml();
+ if (mergeSelection == true)
+ sel.merge(this.previousSelection);
+ this.previousSelection = sel;
+ //Because the QUERYMAPFEATURES 2.6.0 response contains mostly everything we need, we cut down
+ //on lots of async request ping-pong. So we can just update the selection image and notify any
+ //interested parties of the new selection attributes
+ if (selText != "" && selText != null) {
+ this.previousAttributes = attributes;
+ this.updateMapSelection(selText, false);
+ this.processSelectedFeaturePropertiesNode(attributes);
+ } else {
+ this.previousAttributes = null;
+ this.mapWidget._removeWorker();
processAndMergeFeatureInfo: function (r) {
Modified: trunk/lib/MGBroker.js
--- trunk/lib/MGBroker.js 2013-05-29 08:25:25 UTC (rev 2724)
+++ trunk/lib/MGBroker.js 2013-05-30 07:37:05 UTC (rev 2725)
@@ -641,6 +641,59 @@
+ * Class: Fusion.Lib.MGRequest.MGQueryMapFeatures2
+ * encapsulate a request to the server to query map features on
+ * selectable layers
+ * Inherits from:
+ * - <Fusion.Lib.MGRequest>
+Fusion.Lib.MGRequest.MGQueryMapFeatures2 = OpenLayers.Class(Fusion.Lib.MGRequest, {
+ * Constructor: Fusion.Lib.MGRequest.MGQueryMapFeatures2
+ * initialize a new instance of Fusion.Lib.MGRequest.MGQueryMapFeatures2
+ * Parameters:
+ * sessionId - {String} the id of the session to restore
+ * mapName - {String} the id of the session to restore
+ * geometry (sting wkt} gemetry to use for selection. Example : POLYGON(x1 y1, x2,y2)
+ * maxFeatures - {integer} number of maximum results (-1 to indicate no maximum)
+ * selectionPersist - {boolean} save the selection (valid values are 0 and 1)
+ * selectionVariant - {String} indicates the spatial operation. Valid values are 'INTERSECTS', ...
+ * featureFilter - {String} filter crieteria to be applied for selection.
+ * layerNames - {String} comma separated list of layer names to include in the query
+ * layerAttributeFilter - {integer} bitmask determining layer selection behaviour (1=visible layers,
+ * 2=selectable layers, 4=layers with tooltips)
+ * requestData - {integer} a bitmask of the desired information to return (Attributes = 1 InlineSelection? = 2 Tooltip = 4 Hyperlink = 8)
+ * selectionColor - {String} the html color for the inline selection image (if requested)
+ * selectionFormat - {String} the format of the inline selection image (if requested)
+ initialize : function( sessionId, mapName, geometry, maxFeatures, persist, selectionVariant, featureFilter, layerNames, layerAttributeFilter, requestData, selectionColor, selectionFormat)
+ this.initializeRequest();
+ this.setParams( {
+ operation : 'QUERYMAPFEATURES',
+ format: "application/json",
+ version: "2.6.0",
+ session: sessionId,
+ mapname: mapName,
+ geometry: geometry,
+ maxFeatures: maxFeatures,
+ persist: persist,
+ selectionVariant: selectionVariant,
+ featureFilter: featureFilter,
+ layerNames: layerNames,
+ layerAttributeFilter: layerAttributeFilter,
+ requestData: requestData,
+ selectionColor: selectionColor,
+ selectionFormat: selectionFormat
* Class: Fusion.Lib.MGRequest.MGGetFeatureSetEnvelope
More information about the fusion-commits
