[fusion-commits] r2806 - trunk/layers/MapGuide
svn_fusion at osgeo.org
Thu Nov 7 19:29:43 PST 2013
Author: jng
Date: 2013-11-07 19:29:43 -0800 (Thu, 07 Nov 2013)
New Revision: 2806
trunk/layers/MapGuide/MapGuide.js
#588: Add support for smarter layer/group toggling. The Fusion.Layer.MapGuide class now supports a configurable DrawDelay extension property which delays the draw call after a layer/group toggle by the specified period. If another layer/group toggle is made within this period, the current pending draw call is aborted and re-scheduled. This allows a user to toggle multiple layers and groups in quick succession and only have to fire off a single image request instead of firing off a request for each layer/group toggle. The default value is 0, which results in our current behaviour (one request per toggle)
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2013-11-08 02:05:41 UTC (rev 2805)
+++ trunk/layers/MapGuide/MapGuide.js 2013-11-08 03:29:43 UTC (rev 2806)
@@ -41,6 +41,11 @@
selectionType: 'INTERSECTS',
bSelectionOn: false,
oSelection: null,
+ //Specifies how long to delay a map redraw (in ms) upon a layer/group toggle.
+ //This allows for rapid layer/group toggling without having a redraw made for each individual toggle
+ //as long as each toggle is done within the time period defined here. If the delay is 0 or less, the
+ //draw is immediate like before.
+ drawDelay: 0,
nCmsScaleTolerance: 2.0, //When checking the scale list of a tiled map to determine if it is compatible with commercial layers, this value determines how much leeway a given scale can have to be considered equal
bUsesCommercialLayerScaleList: false,
//This is the CMS scale list as defined by MG Studio and interpreted by OpenLayers
@@ -86,6 +91,11 @@
if (!this.bIsMapWidgetLayer) {
this.selectionAsOverlay = false;
+ if (mapTag.extension.DrawDelay) {
+ this.drawDelay = parseInt(mapTag.extension.DrawDelay[0]);
+ //console.log("Draw delay set to: " + this.drawDelay + "ms");
//add in the handler for CTRL-click actions for the map, not an overviewmap
if (this.bIsMapWidgetLayer) {
@@ -866,18 +876,14 @@
- drawMap: function() {
- if (!this.bMapLoaded) {
- return;
+ _drawMapInternal: function() {
var params = {
- ts : (new Date()).getTime(), //add a timestamp to prevent caching on the server
- showLayers : this.aShowLayers.length > 0 ? this.aShowLayers.toString() : null,
- hideLayers : this.aHideLayers.length > 0 ? this.aHideLayers.toString() : null,
- showGroups : this.aShowGroups.length > 0 ? this.aShowGroups.toString() : null,
- hideGroups : this.aHideGroups.length > 0 ? this.aHideGroups.toString() : null,
- refreshLayers : this.aRefreshLayers.length > 0 ? this.aRefreshLayers.toString() : null
+ ts : (new Date()).getTime(), //add a timestamp to prevent caching on the server
+ showLayers : this.aShowLayers.length > 0 ? this.aShowLayers.toString() : null,
+ hideLayers : this.aHideLayers.length > 0 ? this.aHideLayers.toString() : null,
+ showGroups : this.aShowGroups.length > 0 ? this.aShowGroups.toString() : null,
+ hideGroups : this.aHideGroups.length > 0 ? this.aHideGroups.toString() : null,
+ refreshLayers : this.aRefreshLayers.length > 0 ? this.aRefreshLayers.toString() : null
this.aShowLayers = [];
@@ -886,14 +892,34 @@
this.aHideGroups = [];
this.aRefreshLayers = [];
- if(this.oLayerOL2) {
+ if (this.oLayerOL2) {
this.oLayerOL2.mergeNewParams(params);
} else {
this.oLayerOL.mergeNewParams(params);
+ //console.log("Draw call completed");
+ this.drawTimeout = null;
+ drawMap: function() {
+ if (!this.bMapLoaded) {
+ return;
+ if (this.drawDelay <= 0) { //No delay, draw immediately
+ //console.log("Draw immediate");
+ this._drawMapInternal();
+ } else {
+ //Check if we have a pending draw call and re-schedule if there is one
+ if (this.drawTimeout) {
+ //console.log("Delay pending draw");
+ clearTimeout(this.drawTimeout);
+ this.drawTimeout = setTimeout(OpenLayers.Function.bind(this._drawMapInternal, this), this.drawDelay);
+ //console.log("Schedule draw in " + this.drawDelay + "ms");
drawSelection: function() {
if (this.queryLayer) {
this.queryLayer.redraw(true);
@@ -1439,6 +1465,12 @@
showLayer: function( layer, noDraw ) {
this.processLayerEvents(layer, true);
this.aShowLayers.push(layer.uniqueId);
+ //A layer cannot be both hidden and shown, which can be the case if there is a draw
+ //delay and the user has toggled on/off the same layer in quick succession before the
+ //delay has elapsed
+ if (this.drawDelay > 0) {
+ this.aHideLayers.erase(layer.uniqueId);
if (!noDraw) {
this.drawMap();
@@ -1447,6 +1479,12 @@
hideLayer: function( layer, noDraw ) {
this.processLayerEvents(layer, false);
this.aHideLayers.push(layer.uniqueId);
+ this.aShowLayers.erase(layer.uniqueId);
if (!noDraw) {
this.drawMap();
@@ -1465,6 +1503,12 @@
} else {
this.aShowGroups.push(group.uniqueId);
+ //A group cannot be both hidden and shown, which can be the case if there is a draw
+ //delay and the user has toggled on/off the same group in quick succession before the
+ this.aHideGroups.erase(group.uniqueId);
if (!noDraw) {
this.drawMap();
@@ -1483,6 +1527,12 @@
} else {
this.aHideGroups.push(group.uniqueId);
+ this.aShowGroups.erase(group.uniqueId);
if (!noDraw) {
this.drawMap();
More information about the fusion-commits
