[fusion-commits] r2808 - trunk/widgets/QuickPlot
svn_fusion at osgeo.org
Wed Nov 13 20:15:18 PST 2013
Author: jng
Date: 2013-11-13 20:15:17 -0800 (Wed, 13 Nov 2013)
New Revision: 2808
trunk/widgets/QuickPlot/GenerateLegend.php
Update PHP-based legend image renderer to handle cases where we have a layer with multiple basic style types. Such layers should be treated as a themed layer to match how they're represented in the Legend widget.
Modified: trunk/widgets/QuickPlot/GenerateLegend.php
--- trunk/widgets/QuickPlot/GenerateLegend.php 2013-11-13 05:27:56 UTC (rev 2807)
+++ trunk/widgets/QuickPlot/GenerateLegend.php 2013-11-14 04:15:17 UTC (rev 2808)
@@ -63,19 +63,50 @@
<?php
function IsThemed($scaleRange, &$gt) {
- $typeStyles = array("PointTypeStyle", "LineTypeStyle", "AreaTypeStyle", "CompositeTypeStyle");
- $ruleNames = array("PointRule", "LineRule", "AreaRule", "CompositeRule");
+ $typeStyles = array("PointTypeStyle", "LineTypeStyle", "AreaTypeStyle");
+ $ruleNames = array("PointRule", "LineRule", "AreaRule");
$totalRules = 0;
- for ($i = 0; $i < count($typeStyles); $i++) {
- $styleNodes = $scaleRange->getElementsByTagName($typeStyles[$i]);
- for ($j = 0; $j < $styleNodes->length; $j++) {
- $ruleNodes = $styleNodes->item($j)->getElementsByTagName($ruleNames[$i]);
+ $geomTypes = array();
+ //CompositeStyle is mutually exclusive to the others so check if this exists and take
+ //a separate code path if that's the case
+ $styleNodes = $scaleRange->getElementsByTagName("CompositeTypeStyle");
+ if ($styleNodes->length > 0) {
+ for ($i = 0; $i < $styleNodes->length; $i++) {
+ $showInLegend = $styleNodes->item($i)->getElementsByTagName("ShowInLegend");
+ if($showInLegend->length > 0) {
+ if($showInLegend->item(0)->nodeValue == "false") {
+ continue; // This typestyle does not need to be shown in the legend
+ $ruleNodes = $styleNodes->item($i)->getElementsByTagName("CompositeRule");
$totalRules += $ruleNodes->length;
if ($ruleNodes->length > 0)
$gt = ($i + 1);
+ return $totalRules > 1;
+ } else {
+ for ($i = 0; $i < count($typeStyles); $i++) {
+ $styleNodes = $scaleRange->getElementsByTagName($typeStyles[$i]);
+ for ($j = 0; $j < $styleNodes->length; $j++) {
+ $showInLegend = $styleNodes->item($j)->getElementsByTagName("ShowInLegend");
+ $ruleNodes = $styleNodes->item($j)->getElementsByTagName($ruleNames[$i]);
+ $totalRules += $ruleNodes->length;
+ if ($ruleNodes->length > 0)
+ array_push($geomTypes, ($i + 1));
+ //A themed layer has # rules > # style types, implying at least one or more style types
+ //has > 1 rule attached
+ if (count($geomTypes) == 1) { //Single type, need to set the geom type
+ $gt = $geomTypes[0];
- return $totalRules > 1;
function GenerateLegend()
@@ -99,20 +130,31 @@
imagefilledrectangle($image, 0, 0, $width, $height, $white);
+ //Uncomment regions marked with BEGIN DEBUG / END DEBUG and comment out regions marked with
+ //BEGIN COMMENT OUT IF DEBUGGING / END COMMENT OUT IF DEBUGGING to see what PHP-isms get spewed out
+ //that may be tripping up rendering
+ //Also replace instances of "////print_r" with "//print_r" to insta-uncomment all debugging calls
+ //==BEGIN DEBUG==
+ //header("Content-type: text/html", true);
+ //==END DEBUG==
ProcessGroupsForLegend($mappingService, $resourceService, $map, $scale, NULL, $image);
+ //==BEGIN COMMENT OUT IF DEBUGGING==
header("Content-type: image/png");
imagepng($image);
+ //==END COMMENT OUT IF DEBUGGING==
- //Uncomment to see what PHP-isms get spewed out that may be tripping up rendering
- //Also replace instances of "////print_r" with "//print_r" to insta-uncomment all debugging calls
+ //==BEGIN DEBUG==
ob_start();
imagepng($image);
$im = base64_encode(ob_get_contents());
ob_end_clean();
- header("Content-type: text/html", true);
echo "<img src='data:image/png;base64,".$im."' alt='legend image'></img>";
+ //==END DEBUG==
imagecolordeallocate($image, $white);
imagecolordeallocate($image, $textColor);
@@ -298,10 +340,12 @@
$styleObj = NULL;
// We will check if this typestyle is going to be shown in the legend
$showInLegend = $typeStyle->item($st)->getElementsByTagName("ShowInLegend");
- if($showInLegend->length > 0)
- if($showInLegend->item(0)->nodeValue == "false")
+ //print_r("Skipping $styleName in (".$layer->GetLegendLabel().") because ShowInLegend is: ".$showInLegend->item(0)->nodeValue."<br/>");
$rules = $typeStyle->item($st)->getElementsByTagName($ruleNames[$ts]);
for($r = 0; $r < $rules->length; $r++) {
More information about the fusion-commits
