[fusion-commits] r2816 - trunk/layers/MapGuide/php
svn_fusion at osgeo.org
Thu Nov 21 19:13:31 PST 2013
Author: jng
Date: 2013-11-21 19:13:31 -0800 (Thu, 21 Nov 2013)
New Revision: 2816
trunk/layers/MapGuide/php/LoadMap.php
#608: Remove all traces of addslashes() from LoadMap.php as var2json() that is called on the final object takes care of any unruly string characters.
Modified: trunk/layers/MapGuide/php/LoadMap.php
--- trunk/layers/MapGuide/php/LoadMap.php 2013-11-18 02:12:54 UTC (rev 2815)
+++ trunk/layers/MapGuide/php/LoadMap.php 2013-11-22 03:13:31 UTC (rev 2816)
@@ -117,9 +117,9 @@
$mapObj->wkt = $srs;
$mapObj->epsg = $epsgCode;
- $mapObj->mapTitle=addslashes($mapTitle);
+ $mapObj->mapTitle = $mapTitle;
- $mapObj->mapName=addslashes($mapName);
+ $mapObj->mapName = $mapName;
//Any code that may need the map definition xml document can use $mdfDoc
$mapContent = $resourceService->GetResourceContent(new MgResourceIdentifier($mapid));
@@ -174,7 +174,7 @@
$_SESSION['property_mappings'][$layer->GetObjectId()] = $mappings;
$layerObj->uniqueId = $layer->GetObjectId();
- $layerObj->layerName = addslashes($layer->GetName());
+ $layerObj->layerName = $layer->GetName();
//$aLayerTypes = GetLayerTypes($featureService, $layer);
$aLayerTypes = GetLayerTypesFromResourceContent($layer, $layerContent);
@@ -419,8 +419,8 @@
$groupObj = NULL;
- $groupObj->groupName = addslashes($group->GetName());
- $groupObj->legendLabel = addslashes($group->GetLegendLabel());
+ $groupObj->groupName = $group->GetName();
+ $groupObj->legendLabel = $group->GetLegendLabel();
$groupObj->uniqueId = $group->GetObjectId();
$groupObj->displayInLegend = $group->GetDisplayInLegend();
$groupObj->expandInLegend = $group->GetExpandInLegend();
More information about the fusion-commits
