[fusion-commits] r2819 - in sandbox/robust_error_handling/lib: . TraceKit
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Nov 27 22:49:12 PST 2013
Author: jng
Date: 2013-11-27 22:49:12 -0800 (Wed, 27 Nov 2013)
New Revision: 2819
Added:
   sandbox/robust_error_handling/lib/TraceKit/
   sandbox/robust_error_handling/lib/TraceKit/TraceKit.js
Add head revision of TraceKit (https://github.com/occ/TraceKit)
Added: sandbox/robust_error_handling/lib/TraceKit/TraceKit.js
--- sandbox/robust_error_handling/lib/TraceKit/TraceKit.js	                        (rev 0)
+++ sandbox/robust_error_handling/lib/TraceKit/TraceKit.js	2013-11-28 06:49:12 UTC (rev 2819)
@@ -0,0 +1,1112 @@
+ TraceKit - Cross brower stack traces - github.com/occ/TraceKit
+ MIT license
+(function(window, undefined) {
+var TraceKit = {};
+var _oldTraceKit = window.TraceKit;
+// global reference to slice
+var _slice = [].slice;
+var UNKNOWN_FUNCTION = '?';
+ * _has, a better form of hasOwnProperty
+ * Example: _has(MainHostObject, property) === true/false
+ * @param {Object} host object to check property
+ * @param {string} key to check
+function _has(object, key) {
+    return Object.prototype.hasOwnProperty.call(object, key);
+function _isUndefined(what) {
+    return typeof what === 'undefined';
+ * TraceKit.noConflict: Export TraceKit out to another variable
+ * Example: var TK = TraceKit.noConflict()
+TraceKit.noConflict = function noConflict() {
+    window.TraceKit = _oldTraceKit;
+    return TraceKit;
+ * TraceKit.wrap: Wrap any function in a TraceKit reporter
+ * Example: func = TraceKit.wrap(func);
+ * @param {Function} func Function to be wrapped
+ * @return {Function} The wrapped func
+TraceKit.wrap = function traceKitWrapper(func) {
+    function wrapped() {
+        try {
+            return func.apply(this, arguments);
+        } catch (e) {
+            TraceKit.report(e);
+            throw e;
+    return wrapped;
+ * TraceKit.report: cross-browser processing of unhandled exceptions
+ * Syntax:
+ *   TraceKit.report.subscribe(function(stackInfo) { ... })
+ *   TraceKit.report.unsubscribe(function(stackInfo) { ... })
+ *   TraceKit.report(exception)
+ *   try { ...code... } catch(ex) { TraceKit.report(ex); }
+ * Supports:
+ *   - Firefox: full stack trace with line numbers, plus column number
+ *              on top frame; column number is not guaranteed
+ *   - Opera:   full stack trace with line and column numbers
+ *   - Chrome:  full stack trace with line and column numbers
+ *   - Safari:  line and column number for the top frame only; some frames
+ *              may be missing, and column number is not guaranteed
+ *   - IE:      line and column number for the top frame only; some frames
+ * In theory, TraceKit should work on all of the following versions:
+ *   - IE5.5+ (only 8.0 tested)
+ *   - Firefox 0.9+ (only 3.5+ tested)
+ *   - Opera 7+ (only 10.50 tested; versions 9 and earlier may require
+ *     Exceptions Have Stacktrace to be enabled in opera:config)
+ *   - Safari 3+ (only 4+ tested)
+ *   - Chrome 1+ (only 5+ tested)
+ *   - Konqueror 3.5+ (untested)
+ * Requires TraceKit.computeStackTrace.
+ * Tries to catch all unhandled exceptions and report them to the
+ * subscribed handlers. Please note that TraceKit.report will rethrow the
+ * exception. This is REQUIRED in order to get a useful stack trace in IE.
+ * If the exception does not reach the top of the browser, you will only
+ * get a stack trace from the point where TraceKit.report was called.
+ * Handlers receive a stackInfo object as described in the
+ * TraceKit.computeStackTrace docs.
+TraceKit.report = (function reportModuleWrapper() {
+    var handlers = [],
+        lastException = null,
+        lastExceptionStack = null;
+     * Add a crash handler.
+     * @param {Function} handler
+    function subscribe(handler) {
+        installGlobalHandler();
+        handlers.push(handler);
+     * Remove a crash handler.
+    function unsubscribe(handler) {
+        for (var i = handlers.length - 1; i >= 0; --i) {
+            if (handlers[i] === handler) {
+                handlers.splice(i, 1);
+     * Dispatch stack information to all handlers.
+     * @param {Object.<string, *>} stack
+    function notifyHandlers(stack, windowError) {
+        var exception = null;
+        if (windowError && !TraceKit.collectWindowErrors) {
+          return;
+        for (var i in handlers) {
+            if (_has(handlers, i)) {
+                try {
+                    handlers[i].apply(null, [stack].concat(_slice.call(arguments, 2)));
+                } catch (inner) {
+                    exception = inner;
+        if (exception) {
+            throw exception;
+    var _oldOnerrorHandler, _onErrorHandlerInstalled;
+     * Ensures all global unhandled exceptions are recorded.
+     * Supported by Gecko and IE.
+     * @param {string} message Error message.
+     * @param {string} url URL of script that generated the exception.
+     * @param {(number|string)} lineNo The line number at which the error
+     * occurred.
+    function traceKitWindowOnError(message, url, lineNo) {
+        var stack = null;
+        if (lastExceptionStack) {
+            TraceKit.computeStackTrace.augmentStackTraceWithInitialElement(lastExceptionStack, url, lineNo, message);
+            stack = lastExceptionStack;
+            lastException = null;
+        } else {
+            var location = {
+                'url': url,
+                'line': lineNo
+            location.func = TraceKit.computeStackTrace.guessFunctionName(location.url, location.line);
+            location.context = TraceKit.computeStackTrace.gatherContext(location.url, location.line);
+            stack = {
+                'mode': 'onerror',
+                'message': message,
+                'url': document.location.href,
+                'stack': [location],
+                'useragent': navigator.userAgent
+        notifyHandlers(stack, 'from window.onerror');
+        if (_oldOnerrorHandler) {
+            return _oldOnerrorHandler.apply(this, arguments);
+        return false;
+    function installGlobalHandler ()
+        if (_onErrorHandlerInstalled === true) {
+            return;
+        _oldOnerrorHandler = window.onerror;
+        window.onerror = traceKitWindowOnError;
+        _onErrorHandlerInstalled = true;
+     * Reports an unhandled Error to TraceKit.
+     * @param {Error} ex
+    function report(ex) {
+        var args = _slice.call(arguments, 1);
+            if (lastException === ex) {
+                return; // already caught by an inner catch block, ignore
+            } else {
+                var s = lastExceptionStack;
+                notifyHandlers.apply(null, [s, null].concat(args));
+        var stack = TraceKit.computeStackTrace(ex);
+        lastExceptionStack = stack;
+        lastException = ex;
+        // If the stack trace is incomplete, wait for 2 seconds for
+        // slow slow IE to see if onerror occurs or not before reporting
+        // this exception; otherwise, we will end up with an incomplete
+        // stack trace
+        window.setTimeout(function () {
+                notifyHandlers.apply(null, [stack, null].concat(args));
+        }, (stack.incomplete ? 2000 : 0));
+        throw ex; // re-throw to propagate to the top level (and cause window.onerror)
+    report.subscribe = subscribe;
+    report.unsubscribe = unsubscribe;
+    return report;
+ * TraceKit.computeStackTrace: cross-browser stack traces in JavaScript
+ * Syntax:
+ *   s = TraceKit.computeStackTrace.ofCaller([depth])
+ *   s = TraceKit.computeStackTrace(exception) // consider using TraceKit.report instead (see below)
+ * Returns:
+ *   s.name              - exception name
+ *   s.message           - exception message
+ *   s.stack[i].url      - JavaScript or HTML file URL
+ *   s.stack[i].func     - function name, or empty for anonymous functions (if guessing did not work)
+ *   s.stack[i].args     - arguments passed to the function, if known
+ *   s.stack[i].line     - line number, if known
+ *   s.stack[i].column   - column number, if known
+ *   s.stack[i].context  - an array of source code lines; the middle element corresponds to the correct line#
+ *   s.mode              - 'stack', 'stacktrace', 'multiline', 'callers', 'onerror', or 'failed' -- method used to collect the stack trace
+ * Supports:
+ *   - Firefox:  full stack trace with line numbers and unreliable column
+ *               number on top frame
+ *   - Opera 10: full stack trace with line and column numbers
+ *   - Opera 9-: full stack trace with line numbers
+ *   - Safari:   line and column number for the topmost stacktrace element
+ *               only
+ *   - IE:       no line numbers whatsoever
+ * Tries to guess names of anonymous functions by looking for assignments
+ * in the source code. In IE and Safari, we have to guess source file names
+ * by searching for function bodies inside all page scripts. This will not
+ * work for scripts that are loaded cross-domain.
+ * Here be dragons: some function names may be guessed incorrectly, and
+ * duplicate functions may be mismatched.
+ * TraceKit.computeStackTrace should only be used for tracing purposes.
+ * Logging of unhandled exceptions should be done with TraceKit.report,
+ * which builds on top of TraceKit.computeStackTrace and provides better
+ * IE support by utilizing the window.onerror event to retrieve information
+ * about the top of the stack.
+ * Note: In IE and Safari, no stack trace is recorded on the Error object,
+ * so computeStackTrace instead walks its *own* chain of callers.
+ * This means that:
+ *  * in Safari, some methods may be missing from the stack trace;
+ *  * in IE, the topmost function in the stack trace will always be the
+ *    caller of computeStackTrace.
+ * This is okay for tracing (because you are likely to be calling
+ * computeStackTrace from the function you want to be the topmost element
+ * of the stack trace anyway), but not okay for logging unhandled
+ * exceptions (because your catch block will likely be far away from the
+ * inner function that actually caused the exception).
+ * Tracing example:
+ *     function trace(message) {
+ *         var stackInfo = TraceKit.computeStackTrace.ofCaller();
+ *         var data = message + "\n";
+ *         for(var i in stackInfo.stack) {
+ *             var item = stackInfo.stack[i];
+ *             data += (item.func || '[anonymous]') + "() in " + item.url + ":" + (item.line || '0') + "\n";
+ *         if (window.console)
+ *             console.info(data);
+ *         else
+ *             alert(data);
+TraceKit.computeStackTrace = (function computeStackTraceWrapper() {
+    var debug = false,
+        sourceCache = {};
+     * Attempts to retrieve source code via XMLHttpRequest, which is used
+     * to look up anonymous function names.
+     * @param {string} url URL of source code.
+     * @return {string} Source contents.
+    function loadSource(url) {
+        if (!TraceKit.remoteFetching) { //Only attempt request if remoteFetching is on.
+            return '';
+        try {
+            var getXHR = function() {
+                try {
+                    return new window.XMLHttpRequest();
+                } catch (e) {
+                    // explicitly bubble up the exception if not found
+                    return new window.ActiveXObject('Microsoft.XMLHTTP');
+            var request = getXHR();
+            request.open('GET', url, false);
+            request.send('');
+            return request.responseText;
+        } catch (e) {
+            return '';
+     * Retrieves source code from the source code cache.
+     * @return {Array.<string>} Source contents.
+    function getSource(url) {
+        if (!_has(sourceCache, url)) {
+            // URL needs to be able to fetched within the acceptable domain.  Otherwise,
+            // cross-domain errors will be triggered.
+            var source = '';
+            if (url.indexOf(document.domain) !== -1) {
+                source = loadSource(url);
+            sourceCache[url] = source ? source.split('\n') : [];
+        return sourceCache[url];
+     * Tries to use an externally loaded copy of source code to determine
+     * the name of a function by looking at the name of the variable it was
+     * assigned to, if any.
+     * @param {(string|number)} lineNo Line number in source code.
+     * @return {string} The function name, if discoverable.
+    function guessFunctionName(url, lineNo) {
+        var reFunctionArgNames = /function ([^(]*)\(([^)]*)\)/,
+            reGuessFunction = /['"]?([0-9A-Za-z$_]+)['"]?\s*[:=]\s*(function|eval|new Function)/,
+            line = '',
+            maxLines = 10,
+            source = getSource(url),
+            m;
+        if (!source.length) {
+            return UNKNOWN_FUNCTION;
+        // Walk backwards from the first line in the function until we find the line which
+        // matches the pattern above, which is the function definition
+        for (var i = 0; i < maxLines; ++i) {
+            line = source[lineNo - i] + line;
+            if (!_isUndefined(line)) {
+                if ((m = reGuessFunction.exec(line))) {
+                    return m[1];
+                } else if ((m = reFunctionArgNames.exec(line))) {
+                    return m[1];
+     * Retrieves the surrounding lines from where an exception occurred.
+     * @param {(string|number)} line Line number in source code to centre
+     * around for context.
+     * @return {?Array.<string>} Lines of source code.
+    function gatherContext(url, line) {
+        var source = getSource(url);
+            return null;
+        var context = [],
+            // linesBefore & linesAfter are inclusive with the offending line.
+            // if linesOfContext is even, there will be one extra line
+            //   *before* the offending line.
+            linesBefore = Math.floor(TraceKit.linesOfContext / 2),
+            // Add one extra line if linesOfContext is odd
+            linesAfter = linesBefore + (TraceKit.linesOfContext % 2),
+            start = Math.max(0, line - linesBefore - 1),
+            end = Math.min(source.length, line + linesAfter - 1);
+        line -= 1; // convert to 0-based index
+        for (var i = start; i < end; ++i) {
+            if (!_isUndefined(source[i])) {
+                context.push(source[i]);
+        return context.length > 0 ? context : null;
+     * Escapes special characters, except for whitespace, in a string to be
+     * used inside a regular expression as a string literal.
+     * @param {string} text The string.
+     * @return {string} The escaped string literal.
+    function escapeRegExp(text) {
+        return text.replace(/[\-\[\]{}()*+?.,\\\^$|#]/g, '\\$&');
+     * Escapes special characters in a string to be used inside a regular
+     * expression as a string literal. Also ensures that HTML entities will
+     * be matched the same as their literal friends.
+     * @param {string} body The string.
+     * @return {string} The escaped string.
+    function escapeCodeAsRegExpForMatchingInsideHTML(body) {
+        return escapeRegExp(body).replace('<', '(?:<|<)').replace('>', '(?:>|>)').replace('&', '(?:&|&)').replace('"', '(?:"|")').replace(/\s+/g, '\\s+');
+     * Determines where a code fragment occurs in the source code.
+     * @param {RegExp} re The function definition.
+     * @param {Array.<string>} urls A list of URLs to search.
+     * @return {?Object.<string, (string|number)>} An object containing
+     * the url, line, and column number of the defined function.
+    function findSourceInUrls(re, urls) {
+        var source, m;
+        for (var i = 0, j = urls.length; i < j; ++i) {
+            // console.log('searching', urls[i]);
+            if ((source = getSource(urls[i])).length) {
+                source = source.join('\n');
+                if ((m = re.exec(source))) {
+                    // console.log('Found function in ' + urls[i]);
+                    return {
+                        'url': urls[i],
+                        'line': source.substring(0, m.index).split('\n').length,
+                        'column': m.index - source.lastIndexOf('\n', m.index) - 1
+        // console.log('no match');
+        return null;
+     * Determines at which column a code fragment occurs on a line of the
+     * source code.
+     * @param {string} fragment The code fragment.
+     * @param {string} url The URL to search.
+     * @param {(string|number)} line The line number to examine.
+     * @return {?number} The column number.
+    function findSourceInLine(fragment, url, line) {
+        var source = getSource(url),
+            re = new RegExp('\\b' + escapeRegExp(fragment) + '\\b'),
+            m;
+        line -= 1;
+        if (source && source.length > line && (m = re.exec(source[line]))) {
+            return m.index;
+        return null;
+     * Determines where a function was defined within the source code.
+     * @param {(Function|string)} func A function reference or serialized
+     * function definition.
+    function findSourceByFunctionBody(func) {
+        var urls = [window.location.href],
+            scripts = document.getElementsByTagName('script'),
+            body,
+            code = '' + func,
+            codeRE = /^function(?:\s+([\w$]+))?\s*\(([\w\s,]*)\)\s*\{\s*(\S[\s\S]*\S)\s*\}\s*$/,
+            eventRE = /^function on([\w$]+)\s*\(event\)\s*\{\s*(\S[\s\S]*\S)\s*\}\s*$/,
+            re,
+            parts,
+            result;
+        for (var i = 0; i < scripts.length; ++i) {
+            var script = scripts[i];
+            if (script.src) {
+                urls.push(script.src);
+        if (!(parts = codeRE.exec(code))) {
+            re = new RegExp(escapeRegExp(code).replace(/\s+/g, '\\s+'));
+        // not sure if this is really necessary, but I don’t have a test
+        // corpus large enough to confirm that and it was in the original.
+        else {
+            var name = parts[1] ? '\\s+' + parts[1] : '',
+                args = parts[2].split(',').join('\\s*,\\s*');
+            body = escapeRegExp(parts[3]).replace(/;$/, ';?'); // semicolon is inserted if the function ends with a comment.replace(/\s+/g, '\\s+');
+            re = new RegExp('function' + name + '\\s*\\(\\s*' + args + '\\s*\\)\\s*{\\s*' + body + '\\s*}');
+        // look for a normal function definition
+        if ((result = findSourceInUrls(re, urls))) {
+            return result;
+        // look for an old-school event handler function
+        if ((parts = eventRE.exec(code))) {
+            var event = parts[1];
+            body = escapeCodeAsRegExpForMatchingInsideHTML(parts[2]);
+            // look for a function defined in HTML as an onXXX handler
+            re = new RegExp('on' + event + '=[\\\'"]\\s*' + body + '\\s*[\\\'"]', 'i');
+            if ((result = findSourceInUrls(re, urls[0]))) {
+                return result;
+            // look for ???
+            re = new RegExp(body);
+                return result;
+        return null;
+    // Contents of Exception in various browsers.
+    // SAFARI:
+    // ex.message = Can't find variable: qq
+    // ex.line = 59
+    // ex.sourceId = 580238192
+    // ex.sourceURL = http://...
+    // ex.expressionBeginOffset = 96
+    // ex.expressionCaretOffset = 98
+    // ex.expressionEndOffset = 98
+    // ex.name = ReferenceError
+    // FIREFOX:
+    // ex.message = qq is not defined
+    // ex.fileName = http://...
+    // ex.lineNumber = 59
+    // ex.stack = ...stack trace... (see the example below)
+    // CHROME:
+    // ex.type = not_defined
+    // ex.arguments = ['aa']
+    // INTERNET EXPLORER:
+    // ex.message = ...
+    // OPERA:
+    // ex.message = ...message... (see the example below)
+    // ex.opera#sourceloc = 11  (pretty much useless, duplicates the info in ex.message)
+    // ex.stacktrace = n/a; see 'opera:config#UserPrefs|Exceptions Have Stacktrace'
+     * Computes stack trace information from the stack property.
+     * Chrome and Gecko use this property.
+     * @return {?Object.<string, *>} Stack trace information.
+    function computeStackTraceFromStackProp(ex) {
+        if (!ex.stack) {
+            return null;
+        var chrome = /^\s*at (?:((?:\[object object\])?\S+(?: \[as \S+\])?) )?\(?((?:file|http|https):.*?):(\d+)(?::(\d+))?\)?\s*$/i,
+            gecko = /^\s*(\S*)(?:\((.*?)\))?@((?:file|http|https).*?):(\d+)(?::(\d+))?\s*$/i,
+            lines = ex.stack.split('\n'),
+            stack = [],
+            parts,
+            element,
+            reference = /^(.*) is undefined$/.exec(ex.message);
+        for (var i = 0, j = lines.length; i < j; ++i) {
+            if ((parts = gecko.exec(lines[i]))) {
+                element = {
+                    'url': parts[3],
+                    'func': parts[1] || UNKNOWN_FUNCTION,
+                    'args': parts[2] ? parts[2].split(',') : '',
+                    'line': +parts[4],
+                    'column': parts[5] ? +parts[5] : null
+            } else if ((parts = chrome.exec(lines[i]))) {
+                element = {
+                    'url': parts[2],
+                    'line': +parts[3],
+                    'column': parts[4] ? +parts[4] : null
+            } else {
+                continue;
+            if (!element.func && element.line) {
+                element.func = guessFunctionName(element.url, element.line);
+            if (element.line) {
+                element.context = gatherContext(element.url, element.line);
+            stack.push(element);
+        if (stack[0] && stack[0].line && !stack[0].column && reference) {
+            stack[0].column = findSourceInLine(reference[1], stack[0].url, stack[0].line);
+        if (!stack.length) {
+            return null;
+        return {
+            'mode': 'stack',
+            'name': ex.name,
+            'message': ex.message,
+            'stack': stack,
+     * Computes stack trace information from the stacktrace property.
+     * Opera 10 uses this property.
+    function computeStackTraceFromStacktraceProp(ex) {
+        // Access and store the stacktrace property before doing ANYTHING
+        // else to it because Opera is not very good at providing it
+        // reliably in other circumstances.
+        var stacktrace = ex.stacktrace;
+        var testRE = / line (\d+), column (\d+) in (?:<anonymous function: ([^>]+)>|([^\)]+))\((.*)\) in (.*):\s*$/i,
+            lines = stacktrace.split('\n'),
+            stack = [],
+            parts;
+        for (var i = 0, j = lines.length; i < j; i += 2) {
+            if ((parts = testRE.exec(lines[i]))) {
+                var element = {
+                    'line': +parts[1],
+                    'column': +parts[2],
+                    'func': parts[3] || parts[4],
+                    'args': parts[5] ? parts[5].split(',') : [],
+                    'url': parts[6]
+                    try {
+                    } catch (exc) {}
+                if (!element.context) {
+                    element.context = [lines[i + 1]];
+            return null;
+        return {
+            'mode': 'stacktrace',
+            'name': ex.name,
+            'stack': stack,
+     * NOT TESTED.
+     * Computes stack trace information from an error message that includes
+     * the stack trace.
+     * Opera 9 and earlier use this method if the option to show stack
+     * traces is turned on in opera:config.
+     * @return {?Object.<string, *>} Stack information.
+    function computeStackTraceFromOperaMultiLineMessage(ex) {
+        // Opera includes a stack trace into the exception message. An example is:
+        // Statement on line 3: Undefined variable: undefinedFunc
+        // Backtrace:
+        //   Line 3 of linked script file://localhost/Users/andreyvit/Projects/TraceKit/javascript-client/sample.js: In function zzz
+        //         undefinedFunc(a);
+        //   Line 7 of inline#1 script in file://localhost/Users/andreyvit/Projects/TraceKit/javascript-client/sample.html: In function yyy
+        //           zzz(x, y, z);
+        //   Line 3 of inline#1 script in file://localhost/Users/andreyvit/Projects/TraceKit/javascript-client/sample.html: In function xxx
+        //           yyy(a, a, a);
+        //   Line 1 of function script
+        //     try { xxx('hi'); return false; } catch(ex) { TraceKit.report(ex); }
+        var lines = ex.message.split('\n');
+        if (lines.length < 4) {
+            return null;
+        var lineRE1 = /^\s*Line (\d+) of linked script ((?:file|http|https)\S+)(?:: in function (\S+))?\s*$/i,
+            lineRE2 = /^\s*Line (\d+) of inline#(\d+) script in ((?:file|http|https)\S+)(?:: in function (\S+))?\s*$/i,
+            lineRE3 = /^\s*Line (\d+) of function script\s*$/i,
+            stack = [],
+            inlineScriptBlocks = [],
+            parts,
+            i,
+            len,
+            source;
+        for (i in scripts) {
+            if (_has(scripts, i) && !scripts[i].src) {
+                inlineScriptBlocks.push(scripts[i]);
+        for (i = 2, len = lines.length; i < len; i += 2) {
+            var item = null;
+            if ((parts = lineRE1.exec(lines[i]))) {
+                item = {
+                    'url': parts[2],
+                    'func': parts[3],
+                    'line': +parts[1]
+            } else if ((parts = lineRE2.exec(lines[i]))) {
+                item = {
+                    'url': parts[3],
+                    'func': parts[4]
+                var relativeLine = (+parts[1]); // relative to the start of the <SCRIPT> block
+                var script = inlineScriptBlocks[parts[2] - 1];
+                if (script) {
+                    source = getSource(item.url);
+                    if (source) {
+                        var pos = source.indexOf(script.innerText);
+                        if (pos >= 0) {
+                            item.line = relativeLine + source.substring(0, pos).split('\n').length;
+            } else if ((parts = lineRE3.exec(lines[i]))) {
+                var url = window.location.href.replace(/#.*$/, ''),
+                    line = parts[1];
+                var re = new RegExp(escapeCodeAsRegExpForMatchingInsideHTML(lines[i + 1]));
+                source = findSourceInUrls(re, [url]);
+                item = {
+                    'url': url,
+                    'line': source ? source.line : line,
+                    'func': ''
+            if (item) {
+                if (!item.func) {
+                    item.func = guessFunctionName(item.url, item.line);
+                var context = gatherContext(item.url, item.line);
+                var midline = (context ? context[Math.floor(context.length / 2)] : null);
+                if (context && midline.replace(/^\s*/, '') === lines[i + 1].replace(/^\s*/, '')) {
+                    item.context = context;
+                } else {
+                    // if (context) alert("Context mismatch. Correct midline:\n" + lines[i+1] + "\n\nMidline:\n" + midline + "\n\nContext:\n" + context.join("\n") + "\n\nURL:\n" + item.url);
+                    item.context = [lines[i + 1]];
+                stack.push(item);
+            return null; // could not parse multiline exception message as Opera stack trace
+        return {
+            'mode': 'multiline',
+            'name': ex.name,
+            'message': lines[0],
+            'stack': stack,
+     * Adds information about the first frame to incomplete stack traces.
+     * Safari and IE require this to get complete data on the first frame.
+     * @param {Object.<string, *>} stackInfo Stack trace information from
+     * one of the compute* methods.
+     * @param {string} url The URL of the script that caused an error.
+     * @param {(number|string)} lineNo The line number of the script that
+     * caused an error.
+     * @param {string=} message The error generated by the browser, which
+     * hopefully contains the name of the object that caused the error.
+     * @return {boolean} Whether or not the stack information was
+     * augmented.
+    function augmentStackTraceWithInitialElement(stackInfo, url, lineNo, message) {
+        var initial = {
+            'url': url,
+            'line': lineNo
+        if (initial.url && initial.line) {
+            stackInfo.incomplete = false;
+            if (!initial.func) {
+                initial.func = guessFunctionName(initial.url, initial.line);
+            if (!initial.context) {
+                initial.context = gatherContext(initial.url, initial.line);
+            var reference = / '([^']+)' /.exec(message);
+            if (reference) {
+                initial.column = findSourceInLine(reference[1], initial.url, initial.line);
+            if (stackInfo.stack.length > 0) {
+                if (stackInfo.stack[0].url === initial.url) {
+                    if (stackInfo.stack[0].line === initial.line) {
+                        return false; // already in stack trace
+                    } else if (!stackInfo.stack[0].line && stackInfo.stack[0].func === initial.func) {
+                        stackInfo.stack[0].line = initial.line;
+                        stackInfo.stack[0].context = initial.context;
+                        return false;
+            stackInfo.stack.unshift(initial);
+            stackInfo.partial = true;
+            return true;
+        } else {
+            stackInfo.incomplete = true;
+        return false;
+     * Computes stack trace information by walking the arguments.caller
+     * chain at the time the exception occurred. This will cause earlier
+     * frames to be missed but is the only way to get any stack trace in
+     * Safari and IE. The top frame is restored by
+     * {@link augmentStackTraceWithInitialElement}.
+    function computeStackTraceByWalkingCallerChain(ex, depth) {
+        var functionName = /function\s+([_$a-zA-Z\xA0-\uFFFF][_$a-zA-Z0-9\xA0-\uFFFF]*)?\s*\(/i,
+            stack = [],
+            funcs = {},
+            recursion = false,
+            parts,
+            item,
+            source;
+        for (var curr = computeStackTraceByWalkingCallerChain.caller; curr && !recursion; curr = curr.caller) {
+            if (curr === computeStackTrace || curr === TraceKit.report) {
+                // console.log('skipping internal function');
+                continue;
+            item = {
+                'url': null,
+                'func': UNKNOWN_FUNCTION,
+                'line': null,
+                'column': null
+            if (curr.name) {
+                item.func = curr.name;
+            } else if ((parts = functionName.exec(curr.toString()))) {
+                item.func = parts[1];
+            if ((source = findSourceByFunctionBody(curr))) {
+                item.url = source.url;
+                item.line = source.line;
+                if (item.func === UNKNOWN_FUNCTION) {
+                var reference = / '([^']+)' /.exec(ex.message || ex.description);
+                if (reference) {
+                    item.column = findSourceInLine(reference[1], source.url, source.line);
+            if (funcs['' + curr]) {
+                recursion = true;
+            }else{
+                funcs['' + curr] = true;
+            stack.push(item);
+        if (depth) {
+            // console.log('depth is ' + depth);
+            // console.log('stack is ' + stack.length);
+            stack.splice(0, depth);
+        var result = {
+            'mode': 'callers',
+            'name': ex.name,
+            'stack': stack,
+        augmentStackTraceWithInitialElement(result, ex.sourceURL || ex.fileName, ex.line || ex.lineNumber, ex.message || ex.description);
+        return result;
+     * Computes a stack trace for an exception.
+     * @param {(string|number)=} depth
+    function computeStackTrace(ex, depth) {
+        var stack = null;
+        depth = (depth == null ? 0 : +depth);
+        try {
+            // This must be tried first because Opera 10 *destroys*
+            // its stacktrace property if you try to access the stack
+            // property first!!
+            stack = computeStackTraceFromStacktraceProp(ex);
+            if (stack) {
+                return stack;
+        } catch (e) {
+            if (debug) {
+                throw e;
+        try {
+            stack = computeStackTraceFromStackProp(ex);
+            if (stack) {
+                return stack;
+        } catch (e) {
+            if (debug) {
+                throw e;
+        try {
+            stack = computeStackTraceFromOperaMultiLineMessage(ex);
+            if (stack) {
+                return stack;
+        } catch (e) {
+            if (debug) {
+                throw e;
+        try {
+            stack = computeStackTraceByWalkingCallerChain(ex, depth + 1);
+            if (stack) {
+                return stack;
+        } catch (e) {
+            if (debug) {
+                throw e;
+        return {
+            'mode': 'failed'
+     * Logs a stacktrace starting from the previous call and working down.
+     * @param {(number|string)=} depth How many frames deep to trace.
+     * @return {Object.<string, *>} Stack trace information.
+    function computeStackTraceOfCaller(depth) {
+        depth = (depth == null ? 0 : +depth) + 1; // "+ 1" because "ofCaller" should drop one frame
+        try {
+            throw new Error();
+        } catch (ex) {
+            return computeStackTrace(ex, depth + 1);
+    computeStackTrace.augmentStackTraceWithInitialElement = augmentStackTraceWithInitialElement;
+    computeStackTrace.guessFunctionName = guessFunctionName;
+    computeStackTrace.gatherContext = gatherContext;
+    computeStackTrace.ofCaller = computeStackTraceOfCaller;
+    return computeStackTrace;
+ * Extends support for global error handling for asynchronous browser
+ * functions. Adopted from Closure Library's errorhandler.js
+(function extendToAsynchronousCallbacks() {
+    var _helper = function _helper(fnName) {
+        var originalFn = window[fnName];
+        window[fnName] = function traceKitAsyncExtension() {
+            // Make a copy of the arguments
+            var args = _slice.call(arguments);
+            var originalCallback = args[0];
+            if (typeof (originalCallback) === 'function') {
+                args[0] = TraceKit.wrap(originalCallback);
+            // IE < 9 doesn't support .call/.apply on setInterval/setTimeout, but it
+            // also only supports 2 argument and doesn't care what "this" is, so we
+            // can just call the original function directly.
+            if (originalFn.apply) {
+                return originalFn.apply(this, args);
+            } else {
+                return originalFn(args[0], args[1]);
+    _helper('setTimeout');
+    _helper('setInterval');
+//Default options:
+if (!TraceKit.remoteFetching) {
+  TraceKit.remoteFetching = true;
+if (!TraceKit.collectWindowErrors) {
+  TraceKit.collectWindowErrors = true;
+if (!TraceKit.linesOfContext || TraceKit.linesOfContext < 1) {
+  // 5 lines before, the offending line, 5 lines after
+  TraceKit.linesOfContext = 11;
+// Export to global object
+window.TraceKit = TraceKit;
+}(window));
\ No newline at end of file
More information about the fusion-commits mailing list
