[fusion-commits] r2777 - in sandbox/redline_advanced_stylization: common/php layers/MapGuide/php widgets/FeatureInfo widgets/QuickPlot widgets/Theme/classes
svn_fusion at osgeo.org
Wed Sep 11 01:01:44 PDT 2013
Author: jng
Date: 2013-09-11 01:01:44 -0700 (Wed, 11 Sep 2013)
New Revision: 2777
sandbox/redline_advanced_stylization/common/php/Xml2JSON.php
sandbox/redline_advanced_stylization/layers/MapGuide/php/GetSelectionProperties.php
sandbox/redline_advanced_stylization/layers/MapGuide/php/Legend.php
sandbox/redline_advanced_stylization/layers/MapGuide/php/LoadMap.php
sandbox/redline_advanced_stylization/layers/MapGuide/php/LoadScaleRanges.php
sandbox/redline_advanced_stylization/layers/MapGuide/php/MapMenu.php
sandbox/redline_advanced_stylization/layers/MapGuide/php/Query.php
sandbox/redline_advanced_stylization/layers/MapGuide/php/SaveSelection.php
sandbox/redline_advanced_stylization/layers/MapGuide/php/UserManager.php
sandbox/redline_advanced_stylization/layers/MapGuide/php/Utilities.php
sandbox/redline_advanced_stylization/widgets/FeatureInfo/featureinfocontroller.php
sandbox/redline_advanced_stylization/widgets/QuickPlot/GenerateLegend.php
sandbox/redline_advanced_stylization/widgets/Theme/classes/theme.php
Fix more PHP 5.5 compatibility issues:
- Use "new stdClass()" for anonymous objects that are to be converted as JSON
- Do not use static DOMDocument::loadXML() as this is not allowed in strict mode. Use instance-based proceess (make a DOMDocument, call loadXML() on the instance)
Modified: sandbox/redline_advanced_stylization/common/php/Xml2JSON.php
--- sandbox/redline_advanced_stylization/common/php/Xml2JSON.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/common/php/Xml2JSON.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -62,7 +62,8 @@
//echo "/*";
//print_r($xml);
//echo "*/";
-$document = DOMDocument::loadXML($xml);
+$document = new DOMDocument();
+$document->loadXML($xml);
if ($document == null) {
die ('/* invalid xml document:'.$xml.' */');
Modified: sandbox/redline_advanced_stylization/layers/MapGuide/php/GetSelectionProperties.php
--- sandbox/redline_advanced_stylization/layers/MapGuide/php/GetSelectionProperties.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/layers/MapGuide/php/GetSelectionProperties.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -58,14 +58,14 @@
$srsMap = $srsFactory->Create($srsDefMap);
/*holds selection array*/
- $properties = NULL;
+ $properties = new stdClass();
$properties->layers = array();
//process
header('Content-type: application/json');
header('X-JSON: true');
$layers = $selection->GetLayers();
- $result = NULL;
+ $result = new stdClass();
if ($layers != null)
$nLayers = $layers->GetCount();
@@ -160,14 +160,14 @@
$oMin = $oExtents->GetLowerLeftCoordinate();
$oMax = $oExtents->GetUpperRightCoordinate();
- $result->extents = NULL;
+ $result->extents = new stdClass();
$result->extents->minx = $oMin->GetX();
$result->extents->miny = $oMin->GetY();
$result->extents->maxx = $oMax->GetX();
$result->extents->maxy = $oMax->GetY();
/*keep the full extents of the selection when saving the selection in the session*/
- $properties->extents = NULL;
+ $properties->extents = new stdClass();
$properties->extents->minx = $oMin->GetX();
$properties->extents->miny = $oMin->GetY();
$properties->extents->maxx = $oMax->GetX();
@@ -179,6 +179,7 @@
$layerName = $layer->GetName();
array_push($result->layers, $layerName);
$layerClassName = $layer->GetFeatureClassName();
+ $result->$layerName = new stdClass();
$result->$layerName->featureCount = $selection->GetSelectedFeaturesCount($layer, $layerClassName);
Modified: sandbox/redline_advanced_stylization/layers/MapGuide/php/Legend.php
--- sandbox/redline_advanced_stylization/layers/MapGuide/php/Legend.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/layers/MapGuide/php/Legend.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -118,7 +118,8 @@
$resID = $layer->GetLayerDefinition();
$layerContent = $resourceService->GetResourceContent($resID);
- $xmldoc = DOMDocument::loadXML(ByteReaderToString($layerContent));
+ $xmldoc = new DOMDocument();
+ $xmldoc->loadXML(ByteReaderToString($layerContent));
$type = 0;
$scaleRanges = $xmldoc->getElementsByTagName('VectorScaleRange');
if($scaleRanges->length == 0) {
Modified: sandbox/redline_advanced_stylization/layers/MapGuide/php/LoadMap.php
--- sandbox/redline_advanced_stylization/layers/MapGuide/php/LoadMap.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/layers/MapGuide/php/LoadMap.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -123,7 +123,8 @@
//Any code that may need the map definition xml document can use $mdfDoc
$mapContent = $resourceService->GetResourceContent(new MgResourceIdentifier($mapid));
- $mdfDoc = DOMDocument::loadXML(ByteReaderToString($mapContent));
+ $mdfDoc = new DOMDocument();
+ $mdfDoc->loadXML(ByteReaderToString($mapContent));
$mapObj->backgroundColor = getMapBackgroundColor($map, $mdfDoc);
@@ -151,10 +152,12 @@
for($i=0;$i<$layers->GetCount();$i++)
$ldfContent = $layerDefinitionContents->GetItem($i);
- $ldfdoc = DOMDocument::LoadXML($ldfContent);
+ $ldfdoc = new DOMDocument();
+ $ldfdoc->loadXML($ldfContent);
array_push($layerDocs, $ldfdoc);
$fsContent = $featureSourceContents->GetItem($i);
- $fsDoc = DOMDocument::LoadXML($fsContent);
+ $fsDoc = new DOMDocument();
+ $fsDoc->loadXML($fsContent);
array_push($fsDocs, $fsDoc);
@@ -264,7 +267,8 @@
if ($xmldoc == NULL) {
$gridlayers = $xmldoc->getElementsByTagName('GridLayerDefinition');
if ($gridlayers->length > 0)
@@ -301,7 +305,8 @@
$resId = $map->GetMapDefinition();
$mapContent = $resourceService->GetResourceContent($resId);
- $xmldoc = DOMDocument::loadXML(ByteReaderToString($mapContent));
+ $xmldoc->loadXML(ByteReaderToString($mapContent));
$bgColor = $xmldoc->getElementsByTagName('BackgroundColor');
if ($bgColor->length > 0) {
@@ -318,7 +323,8 @@
$type = 0;
Modified: sandbox/redline_advanced_stylization/layers/MapGuide/php/LoadScaleRanges.php
--- sandbox/redline_advanced_stylization/layers/MapGuide/php/LoadScaleRanges.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/layers/MapGuide/php/LoadScaleRanges.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -63,7 +63,7 @@
$map->Open($resourceService, $mapName);
$layers=$map->GetLayers();
-$scaleObj = NULL;
+$scaleObj = new stdClass();
$scaleObj->layers = array();
@@ -73,10 +73,8 @@
isset($_SESSION['scale_ranges'][$layer->GetObjectId()]))
$scaleranges = $_SESSION['scale_ranges'][$layer->GetObjectId()];
- $layerObj = NULL;
+ $layerObj = new stdClass();
$layerObj->uniqueId = $layer->GetObjectId();
- $layerObj = NULL;
- $layerObj->uniqueId = $layer->GetObjectId();
$ldfId = $layer->GetLayerDefinition();
foreach ($scaleranges as $sr)
Modified: sandbox/redline_advanced_stylization/layers/MapGuide/php/MapMenu.php
--- sandbox/redline_advanced_stylization/layers/MapGuide/php/MapMenu.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/layers/MapGuide/php/MapMenu.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -44,7 +44,8 @@
$maps = $resourceService->EnumerateResources($rootId, -1, 'MapDefinition');
//make a list of maps to query for names
-$mapListXml = DOMDocument::loadXML(ByteReaderToString($maps));
+$mapListXml = new DOMDocument();
+$mapListXml->loadXML(ByteReaderToString($maps));
//$aMapAssoc = Array();
$aMapIds = $mapListXml->getElementsByTagName('ResourceId');
Modified: sandbox/redline_advanced_stylization/layers/MapGuide/php/Query.php
--- sandbox/redline_advanced_stylization/layers/MapGuide/php/Query.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/layers/MapGuide/php/Query.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -156,7 +156,8 @@
//get the layer filter value if supplied
$layerReader = $resourceService->GetResourceContent($layerObj->GetLayerDefinition());
- $xmldoc = DOMDocument::loadXML(ByteReaderToString($layerReader));
+ $xmldoc->loadXML(ByteReaderToString($layerReader));
$xpathObj = new domXPath($xmldoc);
$xpathStr = "/LayerDefinition/VectorLayerDefinition/Filter"; //TODO: need this for DWF or Grid layers?
$xpathQuery = $xpathObj->query($xpathStr);
Modified: sandbox/redline_advanced_stylization/layers/MapGuide/php/SaveSelection.php
--- sandbox/redline_advanced_stylization/layers/MapGuide/php/SaveSelection.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/layers/MapGuide/php/SaveSelection.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -63,7 +63,7 @@
if ($layers && $layers->GetCount() >= 0)
$result->hasSelection = true;
if($getExtents)
$featureService = $siteConnection->CreateService(MgServiceType::FeatureService);
Modified: sandbox/redline_advanced_stylization/layers/MapGuide/php/UserManager.php
--- sandbox/redline_advanced_stylization/layers/MapGuide/php/UserManager.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/layers/MapGuide/php/UserManager.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -296,7 +296,8 @@
} else {
$byteReader = $site->EnumerateGroups();
- $xmldoc = DOMDocument::loadXML(ByteReaderToString($byteReader));
+ $xmldoc->loadXML(ByteReaderToString($byteReader));
$groupNodeList = $xmldoc->getElementsByTagName('Group');
for ($i=0; $i<$groupNodeList->length; $i++) {
$group = $groupNodeList->item($i);
Modified: sandbox/redline_advanced_stylization/layers/MapGuide/php/Utilities.php
--- sandbox/redline_advanced_stylization/layers/MapGuide/php/Utilities.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/layers/MapGuide/php/Utilities.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -612,7 +612,8 @@
$mappings = array();
$byteReader = $resourceService->GetResourceContent($layer->GetLayerDefinition());
$mappingNodeList = $xmldoc->getElementsByTagName('PropertyMapping');
for ($i=0; $i<$mappingNodeList->length; $i++) {
@@ -632,7 +633,8 @@
$dataSourceId = new MgResourceIdentifier($layer->GetFeatureSourceId());
$byteReader = $resourceService->GetResourceContent($dataSourceId);
$parameterList = $xmldoc->getElementsByTagName('Parameter');
for ($i=0; $i<$parameterList->length; $i++) {
@@ -775,6 +777,7 @@
$layerName = GetEncodedLayerName($layerName);
+ $properties->$layerName = new stdClass();
$properties->$layerName->propertynames = array();
$properties->$layerName->propertyvalues = array();
$properties->$layerName->propertytypes = array();
Modified: sandbox/redline_advanced_stylization/widgets/FeatureInfo/featureinfocontroller.php
--- sandbox/redline_advanced_stylization/widgets/FeatureInfo/featureinfocontroller.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/widgets/FeatureInfo/featureinfocontroller.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -52,7 +52,7 @@
$selection = new MgSelection($map);
$selection->Open($resourceService, $mapName);
if ($selection->Contains($layer, $className)) {
$featureReader = $selection->GetSelectedFeatures($layer, $className, new MgStringCollection());
Modified: sandbox/redline_advanced_stylization/widgets/QuickPlot/GenerateLegend.php
--- sandbox/redline_advanced_stylization/widgets/QuickPlot/GenerateLegend.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/widgets/QuickPlot/GenerateLegend.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -190,7 +190,8 @@
$layerContent = $resourceService->GetResourceContent($ldfId);
if ($scaleRanges->length == 0) {
$scaleRanges = $xmldoc->getElementsByTagName('GridScaleRange');
Modified: sandbox/redline_advanced_stylization/widgets/Theme/classes/theme.php
--- sandbox/redline_advanced_stylization/widgets/Theme/classes/theme.php 2013-09-11 07:28:51 UTC (rev 2776)
+++ sandbox/redline_advanced_stylization/widgets/Theme/classes/theme.php 2013-09-11 08:01:44 UTC (rev 2777)
@@ -122,7 +122,8 @@
$layerDefResId = $layer->GetLayerDefinition();
$byteReader = $resourceService->GetResourceContent($layerDefResId);
- $doc = DOMDocument::loadXML($byteReader->ToString());
+ $doc = new DOMDocument();
+ $doc->loadXML($byteReader->ToString());
$nodeList = $doc->getElementsByTagName('VectorScaleRange');
foreach ($nodeList as $node)
@@ -240,7 +241,8 @@
// Load the Layer Definition and Navigate to the specified <VectorScaleRange>
$version = $doc->documentElement->getAttribute('version');
$template = 'templates/arearuletemplate-'.$version.'.xml';
$layerDefList = $doc->getElementsByTagName('VectorLayerDefinition');
@@ -342,7 +344,8 @@
$this->InterpolateColor($portion, $this->args['FILLFROM'], $this->args['FILLTO'], $this->args['FILLTRANS']),
$this->InterpolateColor($portion, $this->args['LINEFROM'], $this->args['LINETO'], 0));
- $areaDoc = DOMDocument::loadXML($areaRuleXML);
+ $areaDoc = new DOMDocument();
+ $areaDoc->loadXML($areaRuleXML);
$areaNode = $doc->importNode($areaDoc->documentElement, true);
if($areaTypeStyle != null)
@@ -396,7 +399,8 @@
More information about the fusion-commits
