[fusion-commits] r2780 - sandbox/redline_advanced_stylization/widgets/Redline/templates
svn_fusion at osgeo.org
Thu Sep 12 22:16:04 PDT 2013
Author: jng
Date: 2013-09-12 22:16:04 -0700 (Thu, 12 Sep 2013)
New Revision: 2780
Added:
sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dot.templ
sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dash.templ
sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dashdot.templ
sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dashdotdot.templ
sandbox/redline_advanced_stylization/widgets/Redline/templates/line_divide.templ
sandbox/redline_advanced_stylization/widgets/Redline/templates/line_fenceline1.templ
sandbox/redline_advanced_stylization/widgets/Redline/templates/line_rail.templ
sandbox/redline_advanced_stylization/widgets/Redline/templates/markuplayerdefinition_advanced.xml
#595: Add missing dot line pattern and fix existing line patterns. The issue was bad scale X/Y values causing overlap of underlying symbol geometry thus giving an appearance of solid lines.
Modified: sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dash.templ
--- sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dash.templ 2013-09-12 06:26:30 UTC (rev 2779)
+++ sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dash.templ 2013-09-13 05:16:04 UTC (rev 2780)
@@ -4,13 +4,13 @@
<Graphics>
<Path>
<Geometry>M 0,0 L 6,0</Geometry>
- <ScaleX>%StyleEditorGenerated_ScaleX_0%</ScaleX>
- <ScaleY>%StyleEditorGenerated_ScaleY_0%</ScaleY>
+ <ScaleX>%SCALEX%</ScaleX>
+ <ScaleY>%SCALEY%</ScaleY>
<LineColor>%LINECOLOR%</LineColor>
<LineWeight>%LINEWEIGHT%</LineWeight>
<LineWeightScalable>false</LineWeightScalable>
- <LineCap>%StyleEditorGenerated_LineCap_0%</LineCap>
- <LineJoin>%StyleEditorGenerated_LineJoin_0%</LineJoin>
+ <LineCap>%LINECAP%</LineCap>
+ <LineJoin>%LINEJOIN%</LineJoin>
</Path>
</Graphics>
<LineUsage>
@@ -32,35 +32,32 @@
<DataType>LineWeight</DataType>
</Parameter>
<Parameter>
- <Identifier>StyleEditorGenerated_ScaleX_0</Identifier>
- <DefaultValue>1.0</DefaultValue>
+ <Identifier>SCALEX</Identifier>
+ <DefaultValue>0.166666666666667</DefaultValue>
<DisplayName>Path ScaleX</DisplayName>
<Description>Path ScaleX</Description>
<DataType>Real</DataType>
</Parameter>
<Parameter>
- <Identifier>StyleEditorGenerated_ScaleY_0</Identifier>
+ <Identifier>SCALEY</Identifier>
<DisplayName>Path ScaleY</DisplayName>
<Description>Path ScaleY</Description>
</Parameter>
<Parameter>
- <Identifier>StyleEditorGenerated_LineCap_0</Identifier>
+ <Identifier>LINECAP</Identifier>
<DefaultValue>'Round'</DefaultValue>
<DisplayName>Line Cap</DisplayName>
<Description>The cap type to use at the ends of each segment in the path outline. This must evaluate to one of: None, Round (default), Triangle, or Square.</Description>
<DataType>String</DataType>
</Parameter>
<Parameter>
- <Identifier>StyleEditorGenerated_LineJoin_0</Identifier>
+ <Identifier>LINEJOIN</Identifier>
<DisplayName>Line Join</DisplayName>
<Description>The join type to use at each vertex in the path outline. This must evaluate to one of: None, Bevel, Round (default), or Miter.</Description>
</Parameter>
</ParameterDefinition>
- <ExtendedData1>
- <FileName></FileName>
- </ExtendedData1>
</SimpleSymbolDefinition>
\ No newline at end of file
Modified: sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dashdot.templ
--- sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dashdot.templ 2013-09-12 06:26:30 UTC (rev 2779)
+++ sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dashdot.templ 2013-09-13 05:16:04 UTC (rev 2780)
@@ -4,17 +4,17 @@
<Graphics>
<Path>
<Geometry>M 0,0 L 5,0 M 7.5,0 L 7.5,0 </Geometry>
</Path>
</Graphics>
<LineUsage>
- <Repeat>1.333274223178</Repeat>
+ <Repeat>3.302</Repeat>
</LineUsage>
<ParameterDefinition>
<Parameter>
@@ -32,35 +32,32 @@
</Parameter>
<Parameter>
+ <DefaultValue>0.270931879530363</DefaultValue>
</Parameter>
<Parameter>
+ <DefaultValue>0.0507995157437665</DefaultValue>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
- <ExtendedData1>
- <FileName>acad.lin</FileName>
- </ExtendedData1>
Modified: sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dashdotdot.templ
--- sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dashdotdot.templ 2013-09-12 06:26:30 UTC (rev 2779)
+++ sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dashdotdot.templ 2013-09-13 05:16:04 UTC (rev 2780)
@@ -4,17 +4,17 @@
<Graphics>
<Path>
<Geometry>M 0,0 L 40,0 M 80,0 L 120,0 M 160,0 L 200,0 M 240,0 L 320,0 </Geometry>
</Path>
</Graphics>
<LineUsage>
- <Repeat>0.9999472</Repeat>
+ <Repeat>7.62</Repeat>
</LineUsage>
<Parameter>
@@ -32,35 +32,32 @@
</Parameter>
<Parameter>
+ <DefaultValue>0.0198437896875794</DefaultValue>
</Parameter>
<Parameter>
+ <DefaultValue>0.00211667090000846</DefaultValue>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
- <ExtendedData1>
- <FileName>pixelrun.lin</FileName>
- </ExtendedData1>
Modified: sandbox/redline_advanced_stylization/widgets/Redline/templates/line_divide.templ
--- sandbox/redline_advanced_stylization/widgets/Redline/templates/line_divide.templ 2013-09-12 06:26:30 UTC (rev 2779)
+++ sandbox/redline_advanced_stylization/widgets/Redline/templates/line_divide.templ 2013-09-13 05:16:04 UTC (rev 2780)
@@ -4,17 +4,17 @@
<Graphics>
<Path>
<Geometry>M 0,0 L 5,0 M 7.5,0 L 7.5,0 M 10,0 L 10,0 </Geometry>
</Path>
</Graphics>
<LineUsage>
- <Repeat>1.24994669935484</Repeat>
+ <Repeat>7.93758064516129</Repeat>
</LineUsage>
<Parameter>
@@ -32,35 +32,32 @@
</Parameter>
<Parameter>
+ <DefaultValue>0.63500127000254</DefaultValue>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
- <ExtendedData1>
- </ExtendedData1>
Added: sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dot.templ
--- sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dot.templ (rev 0)
+++ sandbox/redline_advanced_stylization/widgets/Redline/templates/line_dot.templ 2013-09-13 05:16:04 UTC (rev 2780)
@@ -0,0 +1,66 @@
+<SimpleSymbolDefinition>
+ <Name>LINE_SYMBOL</Name>
+ <Description>line_dot.templ</Description>
+ <Graphics>
+ <Path>
+ <Geometry>M 0,0 L 0,0 </Geometry>
+ <LineColor>%LINECOLOR%</LineColor>
+ <LineWeight>%LINEWEIGHT%</LineWeight>
+ <LineWeightScalable>false</LineWeightScalable>
+ </Path>
+ </Graphics>
+ <LineUsage>
+ <Repeat>2.54</Repeat>
+ </LineUsage>
+ <ParameterDefinition>
+ <Parameter>
+ <Identifier>LINECOLOR</Identifier>
+ <DefaultValue>ff000000</DefaultValue>
+ <DisplayName>Line &Color</DisplayName>
+ <Description>Line Color</Description>
+ <DataType>LineColor</DataType>
+ </Parameter>
+ <Parameter>
+ <Identifier>LINEWEIGHT</Identifier>
+ <DefaultValue>0.0</DefaultValue>
+ <DisplayName>Line &Thickness</DisplayName>
+ <Description>Line Thickness</Description>
+ <DataType>LineWeight</DataType>
+ </Parameter>
+ <Parameter>
+ <DefaultValue>6.3500127000254</DefaultValue>
+ <DisplayName>Path ScaleX</DisplayName>
+ <Description>Path ScaleX</Description>
+ <DataType>Real</DataType>
+ </Parameter>
+ <Parameter>
+ <DisplayName>Path ScaleY</DisplayName>
+ <Description>Path ScaleY</Description>
+ </Parameter>
+ <Parameter>
+ <DefaultValue>'Round'</DefaultValue>
+ <DisplayName>Line Cap</DisplayName>
+ <Description>The cap type to use at the ends of each segment in the path outline. This must evaluate to one of: None, Round (default), Triangle, or Square.</Description>
+ <DataType>String</DataType>
+ </Parameter>
+ <Parameter>
+ <DisplayName>Line Join</DisplayName>
+ <Description>The join type to use at each vertex in the path outline. This must evaluate to one of: None, Bevel, Round (default), or Miter.</Description>
+ </Parameter>
+ </ParameterDefinition>
+ <ExtendedData1>
+ <FileName>acad.lin</FileName>
+ </ExtendedData1>
+ </SimpleSymbolDefinition>
Modified: sandbox/redline_advanced_stylization/widgets/Redline/templates/line_fenceline1.templ
--- sandbox/redline_advanced_stylization/widgets/Redline/templates/line_fenceline1.templ 2013-09-12 06:26:30 UTC (rev 2779)
+++ sandbox/redline_advanced_stylization/widgets/Redline/templates/line_fenceline1.templ 2013-09-13 05:16:04 UTC (rev 2780)
@@ -4,27 +4,27 @@
<Graphics>
<Path>
<Geometry>M 2.5,0 A 1,1 0 0 0 4.5,-3.67394039744206e-016 M 4.5,-3.67394039744206e-016 A 1,1 0 0 0 2.5,2.44929359829471e-016 </Geometry>
+ <ScaleX>%SCALEX0%</ScaleX>
+ <ScaleY>%SCALEY0%</ScaleY>
+ <LineCap>%LINECAP0%</LineCap>
+ <LineJoin>%LINEJOIN0%</LineJoin>
</Path>
<Path>
<Geometry>M 0,0 L 2.5,0 M 4.5,0 L 14.5,0 </Geometry>
- <ScaleX>%StyleEditorGenerated_ScaleX_1%</ScaleX>
- <ScaleY>%StyleEditorGenerated_ScaleY_1%</ScaleY>
+ <ScaleX>%SCALEX1%</ScaleX>
+ <ScaleY>%SCALEY1%</ScaleY>
- <LineCap>%StyleEditorGenerated_LineCap_1%</LineCap>
- <LineJoin>%StyleEditorGenerated_LineJoin_1%</LineJoin>
+ <LineCap>%LINECAP1%</LineCap>
+ <LineJoin>%LINEJOIN1%</LineJoin>
</Path>
</Graphics>
<LineUsage>
+ <Repeat>6.35</Repeat>
</LineUsage>
<Parameter>
@@ -42,63 +42,60 @@
</Parameter>
<Parameter>
+ <Identifier>SCALEX0</Identifier>
+ <DefaultValue>0.437928074693012</DefaultValue>
</Parameter>
<Parameter>
+ <Identifier>SCALEY0</Identifier>
</Parameter>
<Parameter>
+ <Identifier>LINECAP0</Identifier>
</Parameter>
<Parameter>
+ <Identifier>LINEJOIN0</Identifier>
</Parameter>
<Parameter>
- <Identifier>StyleEditorGenerated_ScaleX_1</Identifier>
+ <Identifier>SCALEX1</Identifier>
</Parameter>
<Parameter>
- <Identifier>StyleEditorGenerated_ScaleY_1</Identifier>
+ <Identifier>SCALEY1</Identifier>
</Parameter>
<Parameter>
- <Identifier>StyleEditorGenerated_LineCap_1</Identifier>
+ <Identifier>LINECAP1</Identifier>
</Parameter>
<Parameter>
- <Identifier>StyleEditorGenerated_LineJoin_1</Identifier>
+ <Identifier>LINEJOIN1</Identifier>
</Parameter>
- <ExtendedData1>
- </ExtendedData1>
Modified: sandbox/redline_advanced_stylization/widgets/Redline/templates/line_rail.templ
--- sandbox/redline_advanced_stylization/widgets/Redline/templates/line_rail.templ 2013-09-12 06:26:30 UTC (rev 2779)
+++ sandbox/redline_advanced_stylization/widgets/Redline/templates/line_rail.templ 2013-09-13 05:16:04 UTC (rev 2780)
@@ -4,27 +4,27 @@
<Graphics>
<Path>
<Geometry>M 2.0,0 l 0,2.5 M 2.0,0 l 0,-2.5 </Geometry>
</Path>
<Path>
<Geometry>M 0,0 L 9,0</Geometry>
</Path>
</Graphics>
<LineUsage>
- <Repeat>0.999947200000002</Repeat>
</LineUsage>
<Parameter>
@@ -42,56 +42,56 @@
</Parameter>
<Parameter>
+ <DefaultValue>0.705556966669489</DefaultValue>
</Parameter>
<Parameter>
+ <DefaultValue>0.70555696666949</DefaultValue>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
</Parameter>
<Parameter>
Modified: sandbox/redline_advanced_stylization/widgets/Redline/templates/markuplayerdefinition_advanced.xml
--- sandbox/redline_advanced_stylization/widgets/Redline/templates/markuplayerdefinition_advanced.xml 2013-09-12 06:26:30 UTC (rev 2779)
+++ sandbox/redline_advanced_stylization/widgets/Redline/templates/markuplayerdefinition_advanced.xml 2013-09-13 05:16:04 UTC (rev 2780)
@@ -705,26 +705,6 @@
<ParameterIdentifier>LINECOLOR</ParameterIdentifier>
<ParameterValue>0x#{LINE_COLOR}</ParameterValue>
</Override>
- <Override>
- <SymbolName>LINE_SYMBOL</SymbolName>
- <ParameterIdentifier>SCALEX</ParameterIdentifier>
- <ParameterValue>1.0</ParameterValue>
- </Override>
- <Override>
- <ParameterIdentifier>SCALEY</ParameterIdentifier>
- </Override>
- <Override>
- <ParameterIdentifier>LINECAP</ParameterIdentifier>
- <ParameterValue>'Round'</ParameterValue>
- </Override>
- <Override>
- <ParameterIdentifier>LINEJOIN</ParameterIdentifier>
- </Override>
</ParameterOverrides>
<UsageContext>Line</UsageContext>
<GeometryContext>LineString</GeometryContext>
More information about the fusion-commits
