[fusion-commits] r2871 - in trunk: . layers/MapGuide
svn_fusion at osgeo.org
Tue Aug 12 08:04:49 PDT 2014
Author: jng
Date: 2014-08-12 08:04:49 -0700 (Tue, 12 Aug 2014)
New Revision: 2871
trunk/
trunk/layers/MapGuide/MapGuide.js
Merged revision(s) 2845-2846 from sandbox/tiling:
Add support for tile set definitions and the updated CREATERUNTIMEMAP/DESCRIBERUNTIMEMAP response format
Revert tile set checking instead of being always on
Property changes on: trunk
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/fusion-mg24:2560
/branches/fusion-mg26:2855,2869
/sandbox/createruntimemap:2699-2708
/sandbox/jxlib-3.0:1957-2248
/sandbox/ol213:2801-2803
/sandbox/robust_error_handling:2818-2825
+ /branches/fusion-mg24:2560
/sandbox/tiling:2845-2846
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2014-07-30 07:22:43 UTC (rev 2870)
+++ trunk/layers/MapGuide/MapGuide.js 2014-08-12 15:04:49 UTC (rev 2871)
@@ -55,7 +55,9 @@
1155581.153, 2311162.307, 4622324.614, 9244649.227, 18489298.45,
36978596.91, 73957193.82, 147914387.6, 295828775.3, 591657550.5
+ defaultTileSize: [300,300],
bUseNativeServices: false,
+ bHasTileSetSupport: false,
selectionAsOverlay: true,
useAsyncOverlay: false,
defaultFormat: 'PNG',
@@ -169,10 +171,12 @@
//that use layer property mappings as they will be lazy loaded due to us not calling LoadMap.php, which
//would've pre-cached such information. but we get much better map init performance
this.bUseNativeServices = false;
+ this.bHasTileSetSupport = false;
var vMajor = this.siteVersion[0];
var vMinor = this.siteVersion[1];
if (vMajor > 2) { // 3.0 or higher
this.bUseNativeServices = true;
+ this.bHasTileSetSupport = true;
} else {
if (vMajor == 2) { // 2.x
if (vMinor >= 6) { // >= 2.6
@@ -285,6 +289,9 @@
if (this.bUseNativeServices) {
var features = (1 | 2 | 4); //We want the whole lot
var r = new Fusion.Lib.MGRequest.MGCreateRuntimeMap(resourceId, features, 25);
+ if (this.bHasTileSetSupport) {
+ r.setParams({ version: "3.0.0" });
var mapName = this.calcMapName(resourceId, true);
r.setParams({
targetMapName: mapName,
@@ -352,9 +359,9 @@
parentUniqueId: grp.ParentId ? grp.ParentId[0] : "",
visible: (grp.Visible[0] == "true"),
actuallyVisible: (grp.ActuallyVisible[0] == "true"),
- isBaseMapGroup: (grp.Type[0] == "2")
+ isBaseMapGroup: (grp.Type[0] == "2" || grp.Type[0] == "3")
- if (grp.Type[0] == "2")
+ if (cg.isBaseMapGroup)
lm.hasBaseMapLayers = true;
else
lm.hasDynamicLayers = true;
@@ -665,14 +672,28 @@
this.triggerEvent(Fusion.Event.LAYER_LOADED);
+ convertAndLoadMapResponse: function(o) {
+ var co = this.convertResponse(o);
+ if (this.bHasTileSetSupport && o.RuntimeMap.TileSetDefinition) {
+ //Override default tile size based on what's in the
+ if (o.RuntimeMap.TileWidth && o.RuntimeMap.TileHeight) {
+ this.defaultTileSize = [
+ parseInt(o.RuntimeMap.TileWidth[0]),
+ parseInt(o.RuntimeMap.TileHeight[0])
+ this._tileSetId = o.RuntimeMap.TileSetDefinition[0];
+ this.initLoadMapResponse(co.LoadMap);
+ return co;
* Callback function from a CREATERUNTIMEMAP request
onRuntimeMapCreated: function(r) {
if (r.status == 200) {
var o = Fusion.parseJSON(r.responseText);
- var co = this.convertResponse(o);
- this.initLoadMapResponse(co.LoadMap);
+ var co = this.convertAndLoadMapResponse(o);
//Need to wait for the right event to trigger loadScaleRanges, so stash our
//prepared result for when it comes
this._initScaleRanges = co.LoadScaleRanges;
@@ -1008,7 +1029,7 @@
} else {
params = { //tiled version
- mapdefinition: this._sResourceId,
+ mapdefinition: this._tileSetId || this._sResourceId,
basemaplayergroupname: baselayerGroupName,
session: this.getSessionID(),
clientagent: this.clientAgent
@@ -1046,6 +1067,9 @@
+ if (!bSingleTile)
+ layerOptions.defaultSize = new OpenLayers.Size(this.defaultTileSize[0], this.defaultTileSize[1]);
var oNewLayerOL = new OpenLayers.Layer.MapGuide( layerName, url, params, layerOptions );
if (!bSingleTile) {
if (oNewLayerOL.scales.length == this.aCmsScales.length) {
More information about the fusion-commits
