[fusion-commits] r2844 - in sandbox/tiling: . lib/OpenLayers lib/OpenLayers/ext/OpenLayers/Layer
svn_fusion at osgeo.org
Sat Jun 14 08:45:09 PDT 2014
Author: jng
Date: 2014-06-14 08:45:09 -0700 (Sat, 14 Jun 2014)
New Revision: 2844
Removed:
sandbox/tiling/lib/OpenLayers/ext/OpenLayers/Layer/MapGuide.js
sandbox/tiling/
sandbox/tiling/lib/OpenLayers/OpenLayers.js
Merged revision(s) 2841-2842 from trunk:
#614: Fix defect where only the top-left tile is shown. Our OpenLayers.Layer.MapGuide has a bad and/or obsolete implementation of calculateGridLayout(). Compare this with the implementation in OL 2.13 proper, that one has no such method. Since tiles are working fine on un-modified OL 2.13 (proven with the tiled map example bundled with MapGuide that uses OL 2.13), we can only presume this method is no longer needed.
#614: Actually, after removing that method in our custom MapGuide.js, the only difference between it and the official OL copy are several whitespace differences, meaning our custom MapGuide.js is pretty much the one that is in OpenLayers proper. So we don't need this file anymore.
Property changes on: sandbox/tiling
___________________________________________________________________
Modified: svn:mergeinfo
- /branches/fusion-mg24:2560
/sandbox/createruntimemap:2699-2708
/sandbox/jxlib-3.0:1957-2248
/sandbox/ol213:2801-2803
/sandbox/robust_error_handling:2818-2825
+ /branches/fusion-mg24:2560
/trunk:2841-2842
Modified: sandbox/tiling/lib/OpenLayers/OpenLayers.js
--- sandbox/tiling/lib/OpenLayers/OpenLayers.js 2014-06-14 13:20:28 UTC (rev 2843)
+++ sandbox/tiling/lib/OpenLayers/OpenLayers.js 2014-06-14 15:45:09 UTC (rev 2844)
@@ -42160,7 +42160,7 @@
-/* Copyright (c) 2006-2012 by OpenLayers Contributors (see authors.txt for
+/* Copyright (c) 2006-2013 by OpenLayers Contributors (see authors.txt for
* full list of contributors). Published under the 2-clause BSD license.
* See license.txt in the OpenLayers distribution or repository for the
* full text of the license. */
@@ -42270,7 +42270,7 @@
tileRowsPerFolder: 30,
format: 'png',
querystring: null
* Property: defaultSize
@@ -42456,13 +42456,13 @@
rowidx = Math.round(rowidx/this.tileSize.h);
if (this.useHttpTile){
- url = this.getImageFilePath(
+ url = this.getImageFilePath(
tilecol: colidx,
tilerow: rowidx,
scaleindex: this.resolutions.length - this.map.zoom - 1
} else {
url = this.getFullRequestString(
@@ -42583,7 +42583,7 @@
tileColGroup += '0';
} else {
tileColGroup += Math.floor(Math.abs(newParams.tilecol/this.params.tileColumnsPerFolder)) * this.params.tileColumnsPerFolder;
var tilePath = '/S' + Math.floor(newParams.scaleindex)
+ '/' + this.params.basemaplayergroupname
@@ -42601,42 +42601,6 @@
return requestString;
- * Method: calculateGridLayout
- * Generate parameters for the grid layout. This
- * Parameters:
- * bounds - {<OpenLayers.Bound>}
- * origin - {<OpenLayers.LonLat>}
- * resolution - {Number}
- * Returns:
- * {Object} Object containing properties tilelon, tilelat, tileoffsetlat,
- * tileoffsetlat, tileoffsetx, tileoffsety
- calculateGridLayout: function(bounds, origin, resolution) {
- var tilelon = resolution * this.tileSize.w;
- var tilelat = resolution * this.tileSize.h;
- var offsetlon = bounds.left - origin.lon;
- var tilecol = Math.floor(offsetlon/tilelon) - this.buffer;
- var tilecolremain = offsetlon/tilelon - tilecol;
- var tileoffsetx = -tilecolremain * this.tileSize.w;
- var tileoffsetlon = origin.lon + tilecol * tilelon;
- var offsetlat = origin.lat - bounds.top + tilelat;
- var tilerow = Math.floor(offsetlat/tilelat) - this.buffer;
- var tilerowremain = tilerow - offsetlat/tilelat;
- var tileoffsety = tilerowremain * this.tileSize.h;
- var tileoffsetlat = origin.lat - tilelat*tilerow;
- return {
- tilelon: tilelon, tilelat: tilelat,
- tileoffsetlon: tileoffsetlon, tileoffsetlat: tileoffsetlat,
- tileoffsetx: tileoffsetx, tileoffsety: tileoffsety
CLASS_NAME: "OpenLayers.Layer.MapGuide"
Deleted: sandbox/tiling/lib/OpenLayers/ext/OpenLayers/Layer/MapGuide.js
--- sandbox/tiling/lib/OpenLayers/ext/OpenLayers/Layer/MapGuide.js 2014-06-14 13:20:28 UTC (rev 2843)
+++ sandbox/tiling/lib/OpenLayers/ext/OpenLayers/Layer/MapGuide.js 2014-06-14 15:45:09 UTC (rev 2844)
@@ -1,479 +0,0 @@
- * full list of contributors). Published under the 2-clause BSD license.
- * See license.txt in the OpenLayers distribution or repository for the
- * full text of the license. */
- * @requires OpenLayers/Request/XMLHttpRequest.js
- * @requires OpenLayers/Layer/Grid.js
- * Class: OpenLayers.Layer.MapGuide
- * Instances of OpenLayers.Layer.MapGuide are used to display
- * data from a MapGuide OS instance.
- * Inherits from:
- * - <OpenLayers.Layer.Grid>
-OpenLayers.Layer.MapGuide = OpenLayers.Class(OpenLayers.Layer.Grid, {
- * APIProperty: isBaseLayer
- * {Boolean} Treat this layer as a base layer. Default is true.
- isBaseLayer: true,
- * APIProperty: useHttpTile
- * {Boolean} use a tile cache exposed directly via a webserver rather than the
- * via mapguide server. This does require extra configuration on the Mapguide Server,
- * and will only work when singleTile is false. The url for the layer must be set to the
- * webserver path rather than the Mapguide mapagent.
- * See http://trac.osgeo.org/mapguide/wiki/CodeSamples/Tiles/ServingTilesViaHttp
- useHttpTile: false,
- * APIProperty: singleTile
- * {Boolean} use tile server or request single tile image.
- singleTile: false,
- * APIProperty: useOverlay
- * {Boolean} flag to indicate if the layer should be retrieved using
- * GETMAPIMAGE (default) or using GETDYNAMICOVERLAY requests.
- useOverlay: false,
- * APIProperty: useAsyncOverlay
- * {Boolean} indicates if the MapGuide site supports the asynchronous
- * GETDYNAMICOVERLAY requests which is available in MapGuide Enterprise 2010
- * and MapGuide Open Source v2.0.3 or higher. The newer versions of MG
- * is called asynchronously, allows selections to be drawn separately from
- * the map and offers styling options.
- * With older versions of MapGuide, set useAsyncOverlay=false. Note that in
- * this case a synchronous AJAX call is issued and the mapname and session
- * parameters must be used to initialize the layer, not the mapdefinition
- * parameter. Also note that this will issue a synchronous AJAX request
- * before the image request can be issued so the users browser may lock
- * up if the MG Web tier does not respond in a timely fashion.
- useAsyncOverlay: true,
- * Constant: TILE_PARAMS
- * {Object} Hashtable of default parameter key/value pairs for tiled layer
- TILE_PARAMS: {
- operation: 'GETTILEIMAGE',
- version: '1.2.0'
- * Constant: SINGLE_TILE_PARAMS
- * {Object} Hashtable of default parameter key/value pairs for untiled layer
- SINGLE_TILE_PARAMS: {
- operation: 'GETMAPIMAGE',
- format: 'PNG',
- locale: 'en',
- clip: '1',
- version: '1.0.0'
- * Constant: OVERLAY_PARAMS
- OVERLAY_PARAMS: {
- operation: 'GETDYNAMICMAPOVERLAYIMAGE',
- format: 'PNG',
- locale: 'en',
- clip: '1',
- version: '2.0.0'
- * Constant: FOLDER_PARAMS
- * {Object} Hashtable of parameter key/value pairs which describe
- * the folder structure for tiles as configured in the mapguide
- * serverconfig.ini section [TileServiceProperties]
- FOLDER_PARAMS: {
- tileColumnsPerFolder: 30,
- tileRowsPerFolder: 30,
- format: 'png',
- querystring: null
- * Property: defaultSize
- * {<OpenLayers.Size>} Tile size as produced by MapGuide server
- defaultSize: new OpenLayers.Size(300,300),
- * Property: tileOriginCorner
- * {String} MapGuide tile server uses top-left as tile origin
- tileOriginCorner: "tl",
- * Constructor: OpenLayers.Layer.MapGuide
- * Create a new Mapguide layer, either tiled or untiled.
- * For tiled layers, the 'groupName' and 'mapDefinition' values
- * must be specified as parameters in the constructor.
- * For untiled base layers, specify either combination of 'mapName' and
- * 'session', or 'mapDefinition' and 'locale'.
- * For older versions of MapGuide and overlay layers, set useAsyncOverlay
- * to false and in this case mapName and session are required parameters
- * for the constructor.
- * NOTE: MapGuide OS uses a DPI value and degrees to meters conversion
- * factor that are different than the defaults used in OpenLayers,
- * so these must be adjusted accordingly in your application.
- * See the MapGuide example for how to set these values for MGOS.
- * Parameters:
- * name - {String} Name of the layer displayed in the interface
- * url - {String} Location of the MapGuide mapagent executable
- * (e.g. http://localhost:8008/mapguide/mapagent/mapagent.fcgi)
- * params - {Object} hashtable of additional parameters to use. Some
- * parameters may require additional code on the server. The ones that
- * you may want to use are:
- * - mapDefinition - {String} The MapGuide resource definition
- * (e.g. Library://Samples/Gmap/Maps/gmapTiled.MapDefinition)
- * - locale - Locale setting
- * (for untiled overlays layers only)
- * - mapName - {String} Name of the map as stored in the MapGuide session.
- * (for untiled layers with a session parameter only)
- * - session - { String} MapGuide session ID
- * - basemaplayergroupname - {String} GroupName for tiled MapGuide layers only
- * - format - Image format to be returned (for untiled overlay layers only)
- * - showLayers - {String} A comma separated list of GUID's for the
- * layers to display eg: 'cvc-xcv34,453-345-345sdf'.
- * - hideLayers - {String} A comma separated list of GUID's for the
- * layers to hide eg: 'cvc-xcv34,453-345-345sdf'.
- * - showGroups - {String} A comma separated list of GUID's for the
- * groups to display eg: 'cvc-xcv34,453-345-345sdf'.
- * - hideGroups - {String} A comma separated list of GUID's for the
- * groups to hide eg: 'cvc-xcv34,453-345-345sdf'
- * - selectionXml - {String} A selection xml string Some server plumbing
- * is required to read such a value.
- * options - {Object} Hashtable of extra options to tag onto the layer;
- * will vary depending if tiled or untiled maps are being requested
- initialize: function(name, url, params, options) {
- OpenLayers.Layer.Grid.prototype.initialize.apply(this, arguments);
- // unless explicitly set in options, if the layer is transparent,
- // it will be an overlay
- if (options == null || options.isBaseLayer == null) {
- this.isBaseLayer = ((this.transparent != "true") &&
- (this.transparent != true));
- if (options && options.useOverlay!=null) {
- this.useOverlay = options.useOverlay;
- //initialize for untiled layers
- if (this.singleTile) {
- if (this.useOverlay) {
- OpenLayers.Util.applyDefaults(
- this.params,
- this.OVERLAY_PARAMS
- if (!this.useAsyncOverlay) {
- this.params.version = "1.0.0";
- } else {
- this.params,
- this.SINGLE_TILE_PARAMS
- } else {
- //initialize for tiled layers
- if (this.useHttpTile) {
- this.params,
- this.FOLDER_PARAMS
- } else {
- this.params,
- this.TILE_PARAMS
- this.setTileSize(this.defaultSize);
- * Method: clone
- * Create a clone of this layer
- * Returns:
- * {<OpenLayers.Layer.MapGuide>} An exact clone of this layer
- clone: function (obj) {
- if (obj == null) {
- obj = new OpenLayers.Layer.MapGuide(this.name,
- this.url,
- this.params,
- this.getOptions());
- //get all additions from superclasses
- obj = OpenLayers.Layer.Grid.prototype.clone.apply(this, [obj]);
- return obj;
- * Method: getURL
- * Return a query string for this layer
- * Parameters:
- * bounds - {<OpenLayers.Bounds>} A bounds representing the bbox
- * for the request
- * Returns:
- * {String} A string with the layer's url and parameters and also
- * the passed-in bounds and appropriate tile size specified
- * as parameters.
- getURL: function (bounds) {
- var url;
- var center = bounds.getCenterLonLat();
- var mapSize = this.map.getSize();
- //set up the call for GETMAPIMAGE or GETDYNAMICMAPOVERLAY with
- //dynamic map parameters
- var params = {
- setdisplaydpi: OpenLayers.DOTS_PER_INCH,
- setdisplayheight: mapSize.h*this.ratio,
- setdisplaywidth: mapSize.w*this.ratio,
- setviewcenterx: center.lon,
- setviewcentery: center.lat,
- setviewscale: this.map.getScale()
- if (this.useOverlay && !this.useAsyncOverlay) {
- //first we need to call GETVISIBLEMAPEXTENT to set the extent
- var getVisParams = {};
- getVisParams = OpenLayers.Util.extend(getVisParams, params);
- getVisParams.operation = "GETVISIBLEMAPEXTENT";
- getVisParams.version = "1.0.0";
- getVisParams.session = this.params.session;
- getVisParams.mapName = this.params.mapName;
- getVisParams.format = 'text/xml';
- url = this.getFullRequestString( getVisParams );
- OpenLayers.Request.GET({url: url, async: false});
- //construct the full URL
- url = this.getFullRequestString( params );
- } else {
- //tiled version
- var currentRes = this.map.getResolution();
- var colidx = Math.floor((bounds.left-this.maxExtent.left)/currentRes);
- colidx = Math.round(colidx/this.tileSize.w);
- var rowidx = Math.floor((this.maxExtent.top-bounds.top)/currentRes);
- rowidx = Math.round(rowidx/this.tileSize.h);
- if (this.useHttpTile){
- tilecol: colidx,
- tilerow: rowidx,
- scaleindex: this.resolutions.length - this.map.zoom - 1
- } else {
- tilecol: colidx,
- tilerow: rowidx,
- return url;
- * Method: getFullRequestString
- * getFullRequestString on MapGuide layers is special, because we
- * do a regular expression replace on ',' in parameters to '+'.
- * This is why it is subclassed here.
- * Parameters:
- * altUrl - {String} Alternative base URL to use.
- * Returns:
- * {String} A string with the layer's url appropriately encoded for MapGuide
- getFullRequestString:function(newParams, altUrl) {
- // use layer's url unless altUrl passed in
- var url = (altUrl == null) ? this.url : altUrl;
- // if url is not a string, it should be an array of strings,
- // in which case we will randomly select one of them in order
- // to evenly distribute requests to different urls.
- if (typeof url == "object") {
- url = url[Math.floor(Math.random()*url.length)];
- // requestString always starts with url
- var requestString = url;
- // create a new params hashtable with all the layer params and the
- // new params together. then convert to string
- var allParams = OpenLayers.Util.extend({}, this.params);
- allParams = OpenLayers.Util.extend(allParams, newParams);
- // ignore parameters that are already in the url search string
- var urlParams = OpenLayers.Util.upperCaseObject(
- OpenLayers.Util.getParameters(url));
- for(var key in allParams) {
- if(key.toUpperCase() in urlParams) {
- delete allParams[key];
- var paramsString = OpenLayers.Util.getParameterString(allParams);
- /* MapGuide needs '+' seperating things like bounds/height/width.
- Since typically this is URL encoded, we use a slight hack: we
- depend on the list-like functionality of getParameterString to
- leave ',' only in the case of list items (since otherwise it is
- encoded) then do a regular expression replace on the , characters
- to '+' */
- paramsString = paramsString.replace(/,/g, "+");
- if (paramsString != "") {
- var lastServerChar = url.charAt(url.length - 1);
- if ((lastServerChar == "&") || (lastServerChar == "?")) {
- requestString += paramsString;
- } else {
- if (url.indexOf('?') == -1) {
- //serverPath has no ? -- add one
- requestString += '?' + paramsString;
- } else {
- //serverPath contains ?, so must already have paramsString at the end
- requestString += '&' + paramsString;
- return requestString;
- * Method: getImageFilePath
- * special handler to request mapguide tiles from an http exposed tilecache
- * Parameters:
- * Returns:
- * {String} A string with the url for the tile image
- getImageFilePath:function(newParams, altUrl) {
- var tileRowGroup = "";
- var tileColGroup = "";
- if (newParams.tilerow < 0) {
- tileRowGroup = '-';
- if (newParams.tilerow == 0 ) {
- tileRowGroup += '0';
- } else {
- tileRowGroup += Math.floor(Math.abs(newParams.tilerow/this.params.tileRowsPerFolder)) * this.params.tileRowsPerFolder;
- if (newParams.tilecol < 0) {
- tileColGroup = '-';
- if (newParams.tilecol == 0) {
- tileColGroup += '0';
- } else {
- tileColGroup += Math.floor(Math.abs(newParams.tilecol/this.params.tileColumnsPerFolder)) * this.params.tileColumnsPerFolder;
- var tilePath = '/S' + Math.floor(newParams.scaleindex)
- + '/' + this.params.basemaplayergroupname
- + '/R' + tileRowGroup
- + '/C' + tileColGroup
- + '/' + (newParams.tilerow % this.params.tileRowsPerFolder)
- + '_' + (newParams.tilecol % this.params.tileColumnsPerFolder)
- + '.' + this.params.format;
- if (this.params.querystring) {
- tilePath += "?" + this.params.querystring;
- requestString += tilePath;
- * Parameters:
- * Returns:
- return {
- CLASS_NAME: "OpenLayers.Layer.MapGuide"
More information about the fusion-commits
