[fusion-commits] r2849 - sandbox/adsk/2.5k/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Jun 19 23:48:03 PDT 2014
Author: liuar
Date: 2014-06-19 23:48:03 -0700 (Thu, 19 Jun 2014)
New Revision: 2849
   sandbox/adsk/2.5k/widgets/Legend.js
ticket #616 http://trac.osgeo.org/fusion/ticket/616
Don't show empty group folders in legend of flexible layout.
Modified: sandbox/adsk/2.5k/widgets/Legend.js
--- sandbox/adsk/2.5k/widgets/Legend.js	2014-06-17 12:45:14 UTC (rev 2848)
+++ sandbox/adsk/2.5k/widgets/Legend.js	2014-06-20 06:48:03 UTC (rev 2849)
@@ -249,7 +249,13 @@
     bIncludeVisToggle: true,
     offsetsCalculated: false,
+     * Property: bHideEmptyGroups
+     * {Boolean} Determine if a group which has non-visible layer must be draw in the legend.
+    bHideEmptyGroups: true,
     initialize: function(legend, widgetTag) {
         Fusion.Widget.Legend.LegendRenderer.prototype.initialize.apply(this, [legend]);
@@ -287,7 +293,8 @@
         this.showRootFolder = (json.ShowRootFolder && json.ShowRootFolder[0] == 'true') ? true:false;
         //do show the map folder by default
         this.showMapFolder = (json.ShowMapFolder && json.ShowMapFolder[0] == 'false') ? false:true;
+        this.bHideEmptyGroups = true;
         if (!this.showRootFolder) {
             //console.log('supressing root folder');
             this.oRoot = this.oTree;
@@ -515,8 +522,25 @@
         for (var i=0; i<map.layerRoot.layers.length; i++) {
             this.updateLayer(map.layerRoot.layers[i], currentScale);
+        if (this.bHideEmptyGroups) {
+            for (var i=0; i<map.layerRoot.groups.length; i++) {
+                this.hideEmptyGroup(map.layerRoot.groups[i]);
+    hideEmptyGroup: function(group) {
+        for (var i=0; i<group.groups.length; i++) {
+            this.hideEmptyGroup(group.groups[i])
+        if (group.hasVisibleLayers) {
+            if (group.parentGroup.legend && group.parentGroup.legend.treeItem)
+                group.parentGroup.legend.treeItem.add(group.legend.treeItem);
+        } else {
+            group.parentGroup.legend.treeItem.remove(group.legend.treeItem);
      * remove the dom objects representing the legend layers and groups
@@ -547,18 +571,39 @@
     updateGroupLayers: function(group, fScale) {
+        group.hasVisibleLayers = false;
             this.updateGroupLayers(group.groups[i], fScale);
         for (var i=0; i<group.layers.length; i++) {
             this.updateLayer(group.layers[i], fScale);
+        // Hide empty groups if necessary.
+        if (!this.bHideEmptyGroups)
+            return;
+        // Check if the group has visible layers
+        for (var i=0; i<group.layers.length; i++) {
+            if (group.layers[i].visibleInGroupLegend) {
+                group.hasVisibleLayers = true;
+                break;
+            return;
+            if (group.groups[i].hasVisibleLayers) {
+                break;
     updateLayer: function(layer, fScale) {
         /* no need to do anything if we are hiding the layer */
         if (!layer.displayInLegend || !layer.legend) {
+            layer.visibleInGroupLegend = false;
             return;
         /* check the layer's current scale range against the previous one
@@ -664,9 +709,12 @@
         if (layer.legend.treeItem) {
+            layer.visibleInGroupLegend = true;
             layer.legend.treeItem.options.data = layer;
             if (!layer.isBaseMapLayer) //Tiled layers don't have a checkbox so there's nothing to check
                 layer.legend.treeItem.check(layer.visible);
+        } else {
     getThemeExpandContextMenu: function(node) {
More information about the fusion-commits mailing list
