[fusion-commits] r2855 - branches/fusion-mg26/layers/MapGuide
svn_fusion at osgeo.org
Tue Jun 24 22:00:08 PDT 2014
Author: jng
Date: 2014-06-24 22:00:08 -0700 (Tue, 24 Jun 2014)
New Revision: 2855
branches/fusion-mg26/layers/MapGuide/MapGuide.js
#618: Undo r2739. This was causing problems with Map Definitions with multiple base groups. In fact I suspect that revision should not have been in there in the first place and probably landed there as a result of various merges.
Modified: branches/fusion-mg26/layers/MapGuide/MapGuide.js
--- branches/fusion-mg26/layers/MapGuide/MapGuide.js 2014-06-25 03:59:22 UTC (rev 2854)
+++ branches/fusion-mg26/layers/MapGuide/MapGuide.js 2014-06-25 05:00:08 UTC (rev 2855)
@@ -639,6 +639,19 @@
this.oLayerOL2.setVisibility(true);
+ //Fix Defect: the Base Layer Group should be invisible when the "initially visiable in map" is set to false
+ var i = 0;
+ var j = 0;
+ for(i = 0;i < this.layerRoot.groups.length; i++){
+ if(this.layerRoot.groups[i].isBaseMapGroup && !this.layerRoot.groups[i].initiallyVisible){
+ for(j = 0; j<this.oLayersOLTile.length; j++) {
+ if(this.oLayersOLTile[j].params.basemaplayergroupname === this.layerRoot.groups[i].name) {
+ this.oLayersOLTile[j].setVisibility(false);
* Callback function from a LoadMap.php request
More information about the fusion-commits
