[fusion-commits] r2874 - in sandbox/stamen: layers/Generic lib text widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Sep 5 06:03:19 PDT 2014
Author: jng
Date: 2014-09-05 06:03:18 -0700 (Fri, 05 Sep 2014)
New Revision: 2874
   sandbox/stamen/layers/Generic/Generic.js
   sandbox/stamen/lib/fusion.js
   sandbox/stamen/text/en.json
   sandbox/stamen/widgets/BasemapSwitcher.js
Add stamen layer support:
 - Add support for a StamenScript element. Authoring tools will be expected to add the following script URL for stamen map layer support:
    - http://maps.stamen.com/js/tile.stamen.js?v1.3.0
 - Update layers/Generic/Generic.js to recognize and instantiate stamen layer objects
 - Add stamen layer support to the BasemapSwitcher widget
Modified: sandbox/stamen/layers/Generic/Generic.js
--- sandbox/stamen/layers/Generic/Generic.js	2014-09-05 12:45:21 UTC (rev 2873)
+++ sandbox/stamen/layers/Generic/Generic.js	2014-09-05 13:03:18 UTC (rev 2874)
@@ -180,6 +180,9 @@
                 this.mapTag.layerOptions.type = 'Mapnik';
             break;
+         case 'Stamen':
+            this.oLayerOL = new OpenLayers.Layer[this.layerType](this.mapTag.layerOptions.type);
+            break;
          case 'XYZ':
                                   this.getMapName(),
Modified: sandbox/stamen/lib/fusion.js
--- sandbox/stamen/lib/fusion.js	2014-09-05 12:45:21 UTC (rev 2873)
+++ sandbox/stamen/lib/fusion.js	2014-09-05 13:03:18 UTC (rev 2874)
@@ -1681,11 +1681,13 @@
                 var yahooElement = appDefXML.getElementsByTagName("YahooScript")[0];
                 var veElement = appDefXML.getElementsByTagName("VirtualEarthScript")[0];
                 var osmElement = appDefXML.getElementsByTagName("OpenStreetMapScript")[0];
+                var stamenElement = appDefXML.getElementsByTagName("StamenScript")[0];
                 addElement(googleElement);
                 addElement(yahooElement);
                 addElement(veElement);
                 addElement(osmElement);
+                addElement(stamenElement);
Modified: sandbox/stamen/text/en.json
--- sandbox/stamen/text/en.json	2014-09-05 12:45:21 UTC (rev 2873)
+++ sandbox/stamen/text/en.json	2014-09-05 13:03:18 UTC (rev 2874)
@@ -86,6 +86,9 @@
 'openStreetMap':'Open Street Map',
 'openStreetMapTransportMap':'Open Street Map (TransportMap)',
 'openStreetMapCycleMap':'Open Street Map (CycleMap)',
+'stamenToner':'Stamen Toner',
+'stamenTerrain':'Stamen Terrain',
+'stamenWatercolor':'Stamen Watercolor',
 'end': '',
 'currentPositionOutsideInitialView': 'Your position is outside of the initial view of the map',
 'currentPositionOutsideMaxExtent': 'Your position is outside of the maximum extent of the map',
Modified: sandbox/stamen/widgets/BasemapSwitcher.js
--- sandbox/stamen/widgets/BasemapSwitcher.js	2014-09-05 12:45:21 UTC (rev 2873)
+++ sandbox/stamen/widgets/BasemapSwitcher.js	2014-09-05 13:03:18 UTC (rev 2874)
@@ -251,6 +251,41 @@
                     break;
+                case 'Stamen':
+                    switch (map.mapTag.extension.Options[0].type[0]) {
+                        case 'terrain':
+                            if (map.mapTag.extension.Options[0].name) {
+                                this.options['terrain'] = map.mapTag.extension.Options[0].name[0];
+                            else {
+                                this.options['terrain'] = OpenLayers.i18n('stamenTerrain');
+                            this.baseMaps['terrain'] = map;
+                            break;
+                        case 'watercolor':
+                                this.options['watercolor'] = map.mapTag.extension.Options[0].name[0];
+                            else {
+                                this.options['watercolor'] =  OpenLayers.i18n('stamenWatercolor');
+                            this.baseMaps['watercolor'] = map;
+                            break;
+                        default: //Default to toner tileset
+                                this.options['toner'] = map.mapTag.extension.Options[0].name[0];
+                            else {
+                                this.options['toner'] =  OpenLayers.i18n('stamenToner');
+                            this.baseMaps['toner'] = map;
+                            break;
+                    // The first non-MapGuide basemap will be the default basemap
+                    if (!this.defaultBasemap) {
+                        this.defaultBasemap = map.mapTag.extension.Options[0].type[0];
+                    break;
                 case 'OpenStreetMap':
                     // if user didn't indicate basemap types, use the default OSM Mapnik render
                     if (!map.mapTag.extension.Options || !map.mapTag.extension.Options[0].type) {
More information about the fusion-commits mailing list
