[fusion-commits] r2899 - trunk/layers/MapGuide
svn_fusion at osgeo.org
Tue Apr 21 05:28:09 PDT 2015
Author: jng
Date: 2015-04-21 05:28:08 -0700 (Tue, 21 Apr 2015)
New Revision: 2899
trunk/layers/MapGuide/MapGuide.js
#566: Allow buffer/redline and other widgets that introduce temporary layers to work against fully tiled maps
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2015-04-02 07:15:30 UTC (rev 2898)
+++ trunk/layers/MapGuide/MapGuide.js 2015-04-21 12:28:08 UTC (rev 2899)
@@ -639,13 +639,12 @@
- //if we have a tiled map that also contains dynamic layers, we need to create
- //an additional overlay layer to render them on top of the tiles
- if(!this.bSingleTile && o.hasDynamicLayers) {
- this.oLayerOL2 = this.createOLLayer(this._sMapname + "_DynamicOverlay",true,2,true, "");
- this.mapWidget.oMapOL.addLayer(this.oLayerOL2);
- this.oLayerOL2.setVisibility(true);
+ // Whether this tiled map has untiled layers or not, create a dynamic overlay anyways
+ // so that buffer, redline and other tools whose changes will only be visible in a dynamic
+ // overlay will be visible
+ this.oLayerOL2 = this.createOLLayer(this._sMapname + "_DynamicOverlay",true,2,true, "");
+ this.mapWidget.oMapOL.addLayer(this.oLayerOL2);
+ this.oLayerOL2.setVisibility(true);
//Fix Defect: the Base Layer Group should be invisible when the "initially visiable in map" is set to false
More information about the fusion-commits
