[fusion-commits] r2902 - sandbox/adsk/3.0m/lib/OpenLayers
svn_fusion at osgeo.org
Thu Apr 23 21:38:37 PDT 2015
Author: liuar
Date: 2015-04-23 21:38:37 -0700 (Thu, 23 Apr 2015)
New Revision: 2902
sandbox/adsk/3.0m/lib/OpenLayers/OpenLayers.js
#631, set base layer's visibility only when zoom is defined and the base layer is not commercial layer.
Modified: sandbox/adsk/3.0m/lib/OpenLayers/OpenLayers.js
--- sandbox/adsk/3.0m/lib/OpenLayers/OpenLayers.js 2015-04-23 05:36:15 UTC (rev 2901)
+++ sandbox/adsk/3.0m/lib/OpenLayers/OpenLayers.js 2015-04-24 04:38:37 UTC (rev 2902)
@@ -8728,10 +8728,12 @@
var bounds = this.getExtent();
//send the move call to the baselayer and all the overlays
- if (zoom >= this.baseLayer.MAX_ZOOM_LEVEL)
- this.baseLayer.setVisibility(false);
- else
- this.baseLayer.setVisibility(this.baseLayer.visibility);
+ if (zoom && this.baseLayer.CLASS_NAME != "OpenLayers.Layer.MapGuide") {
+ if (zoom >= this.baseLayer.MAX_ZOOM_LEVEL)
+ this.baseLayer.setVisibility(false);
+ else
+ this.baseLayer.setVisibility(true);
if(this.baseLayer.visibility) {
this.baseLayer.moveTo(bounds, zoomChanged, options.dragging);
options.dragging || this.baseLayer.events.triggerEvent(
@@ -9113,10 +9115,12 @@
if (map.baseLayer.wrapDateLine) {
zoom = map.adjustZoom(zoom);
- if (zoom >= map.baseLayer.MAX_ZOOM_LEVEL)
- map.baseLayer.setVisibility(false);
- else
- map.baseLayer.setVisibility(map.baseLayer.visibility);
+ if (zoom && map.baseLayer.CLASS_NAME != "OpenLayers.Layer.MapGuide") {
+ if (zoom >= map.baseLayer.MAX_ZOOM_LEVEL)
+ map.baseLayer.setVisibility(false);
+ else
+ map.baseLayer.setVisibility(true);
if (map.zoomTween) {
var currentRes = map.getResolution(),
targetRes = map.getResolutionForZoom(zoom),
More information about the fusion-commits
