[fusion-commits] r2939 - trunk/widgets/widgetinfo
svn_fusion at osgeo.org
Wed May 4 09:04:31 PDT 2016
Author: jng
Date: 2016-05-04 09:04:31 -0700 (Wed, 04 May 2016)
New Revision: 2939
trunk/widgets/widgetinfo/search.xml
Clear up search widgetinfo
Modified: trunk/widgets/widgetinfo/search.xml
--- trunk/widgets/widgetinfo/search.xml 2016-05-04 15:13:20 UTC (rev 2938)
+++ trunk/widgets/widgetinfo/search.xml 2016-05-04 16:04:31 UTC (rev 2939)
@@ -35,7 +35,7 @@
</Parameter>
<Parameter>
<Name>Filter</Name>
- <Description>The search expression template to return features</Description>
+ <Description>The search expression template to return features. The filter must include a $USER_VARIABLE placeholder (that will contain the search term)</Description>
<Type>String</Type>
<Label>Filter</Label>
<DefaultValue>String</DefaultValue>
More information about the fusion-commits
