[fusion-commits] r2966 - in branches/fusion-mg30: . layers/MapGuide lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Nov 24 03:36:06 PST 2016
Author: jng
Date: 2016-11-24 03:36:06 -0800 (Thu, 24 Nov 2016)
New Revision: 2966
   branches/fusion-mg30/
   branches/fusion-mg30/layers/MapGuide/MapGuide.js
   branches/fusion-mg30/lib/Map.js
   branches/fusion-mg30/widgets/Legend.js
Merged revision(s) 2964 from trunk:
#654: Fusion update to handle the fixed CREATERUNTIMEMAP response (https://trac.osgeo.org/mapguide/changeset/9094)
Property changes on: branches/fusion-mg30
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/fusion-mg24:2560
/branches/fusion-mg26:2855,2869
/sandbox/adsk/2.6l:2911
/sandbox/adsk/3.1n:2925-2927
/sandbox/createruntimemap:2699-2708
/sandbox/jxlib-3.0:1957-2248
/sandbox/ol213:2801-2803
/sandbox/robust_error_handling:2818-2825
/sandbox/stamen:2873-2875
/sandbox/tiling:2845-2846
/trunk:2896-2899,2905-2908,2915,2920-2932,2936-2942,2946,2950,2956,2960
   + /branches/fusion-mg24:2560
/trunk:2896-2899,2905-2908,2915,2920-2932,2936-2942,2946,2950,2956,2960,2964
Modified: branches/fusion-mg30/layers/MapGuide/MapGuide.js
--- branches/fusion-mg30/layers/MapGuide/MapGuide.js	2016-11-24 11:35:58 UTC (rev 2965)
+++ branches/fusion-mg30/layers/MapGuide/MapGuide.js	2016-11-24 11:36:06 UTC (rev 2966)
@@ -440,6 +440,16 @@
                                     csr.styles.push(cr);
+                        } else {
+                            //A vector layer without a feature style is technically illegal. Therefore, this has
+                            //to be a raster or drawing (both do not have feature styles)
+                            var fsId = lyr.FeatureSource[0].ResourceId[0];
+                            var DRAWING_SOURCE = "DrawingSource";
+                            if (fsId.indexOf(DRAWING_SOURCE, fsId.length - DRAWING_SOURCE.length) !== -1) {
+                                ltypes[Fusion.Constant.LAYER_DWF_TYPE] = Fusion.Constant.LAYER_DWF_TYPE;
+                            } else {
+                                ltypes[Fusion.Constant.LAYER_RASTER_TYPE] = Fusion.Constant.LAYER_RASTER_TYPE;
                         clsr.scaleRanges.push(csr);
Modified: branches/fusion-mg30/lib/Map.js
--- branches/fusion-mg30/lib/Map.js	2016-11-24 11:35:58 UTC (rev 2965)
+++ branches/fusion-mg30/lib/Map.js	2016-11-24 11:36:06 UTC (rev 2966)
@@ -95,26 +95,27 @@
  * Constant: Fusion.Event.MAP_BASE_LAYER_CHANGED
 Fusion.Event.MAP_BASE_LAYER_CHANGED = Fusion.Event.lastEventId++;
  * Constant: Fusion.Constant.LAYER_POINT_TYPE
 Fusion.Constant.LAYER_POINT_TYPE = 0;
- * Constant: Fusion.Constant.LAYER_POINT_TYPE
+ * Constant: Fusion.Constant.LAYER_LINE_TYPE
-Fusion.Constant.LAYER_POINT_TYPE = 1;
+Fusion.Constant.LAYER_LINE_TYPE = 1;
+ * Constant: Fusion.Constant.LAYER_POLYGON_TYPE
-Fusion.Constant.LAYER_POINT_TYPE = 2;
+Fusion.Constant.LAYER_POLYGON_TYPE = 2;
+ * Constant: Fusion.Constant.LAYER_SOLID_TYPE
-Fusion.Constant.LAYER_POINT_TYPE = 3;
+Fusion.Constant.LAYER_SOLID_TYPE = 3;
+ * Constant: Fusion.Constant.LAYER_RASTER_TYPE
-Fusion.Constant.LAYER_POINT_TYPE = 4;
+Fusion.Constant.LAYER_RASTER_TYPE = 4;
  * Constant: Fusion.Constant.LAYER_DWF_TYPE
Modified: branches/fusion-mg30/widgets/Legend.js
--- branches/fusion-mg30/widgets/Legend.js	2016-11-24 11:35:58 UTC (rev 2965)
+++ branches/fusion-mg30/widgets/Legend.js	2016-11-24 11:36:06 UTC (rev 2966)
@@ -817,15 +817,12 @@
           opt.selectable = false;
-        var LAYER_RASTER = 4;
-        var LAYER_DWF = 5;
         if (!style) {
             //This could be a DWF or Raster layer
             if (layer.layerTypes.length == 1) {
-                if (layer.layerTypes[0] == LAYER_RASTER) {
+                if (layer.layerTypes[0] == Fusion.Constant.LAYER_RASTER_TYPE) {
                     opt.image = this.imgLayerRasterIcon;
-                } else if (layer.layerTypes[0] == LAYER_DWF) {
+                } else if (layer.layerTypes[0] == Fusion.Constant.LAYER_DWF_TYPE) {
                     opt.image = this.imgLayerDWFIcon;
                 } else {
                     opt.image = this.imgDisabledLayerIcon;
More information about the fusion-commits mailing list
